ServiiDroid (Android Console) - Get it on Google Play
Re: ServiiDroid (Android Console) - Get it on Google Play
I am working on a couple of major changes on the way the API works and where it resides. I am putting the mysql server and the API web server on a seperate VPN, and then running just the serviidb drupal site on the current VPN, it should speed everything up.
I am optimizing the PHP code that generates the mysql queries to make the queries faster.
Both of these should get the API and site working alot better.
will wrote:2.0.1 should fix that, check for the update and let me know if it doesn't.
Thanks! Hopefully it should help anyone with low res screens. I personally cant wait to get a 1080p handsets this year.
I have stage one of the changes complete, please check responses and let me know if there is any problems.
In version 2.0.2 new strings (subtitles section) are still in English, but on getlocalization.com are already translated (Czech).
Ok thanks for letting me know, I'll do a new release tonight, must have missed them when I did my last pass over the site.
Small update should be available soonish.
ServiiDroid has now been downloaded over 50,000 times!
I'm going to be busy working on ServiiGo for the next few weeks, but have some plans for an update that will finish off the revised ServiiDB.com intergration once I'm done. Other than that it looks like aside from adding support for new versions of Serviio, ServiiDroid is now pretty feature complete. I'm am however thinking about updating the icon, I've tried to do some mockups using part of the Serviio rings combined with Android style cogs used for settings, but I'm not that great at the execution, so if you are up for it let me know.
will wrote:ServiiDroid has now been downloaded over 50,000 times!![]()
Congrats, mate.
Petr
Help translate Serviio
Hi Will, is it possible to display logs?
There's a mod made for webui. Think this will be extremely useful.
No, for the same reason I cannot display a folder structure when setting up a shared folder, or install a plugin from ServiiDB, my app cannot execute any code on the server, whereas the WebUI's can (provided they are running on the same machine, which they almost always would be), so I'm limited to what is available via the console API http://docs.serviio.apiary.io/
@will, is a beta ServiioDroid for Serviio 1.3?
Beta programme for ServiiDroid is ready, same deal as for ServiiGo. Sign up to https://groups.google.com/forum/?fromgr ... ta-testers and follow the instructions.
Cant find any instructions after joining, used the previous URL and edited to ServiiDroid and works good - https://play.google.com/apps/testing/co ... droid/join
Xmantium wrote:Cant find any instructions after joining, used the previous URL and edited to ServiiDroid and works good - https://play.google.com/apps/testing/co ... droid/join
Can you not see the "How to join the ServiiDroid Beta Testing Programme" post once you join the group? And on the desktop site it is written in the welcome message at the top.
It says "ServiiDroid Beta Testers
You cannot view topics in this forum.
You do not have the necessary permissions to view topics in this group."
On ServiiGo group i can view the posts
Thanks, all good now. Should beta testers post all feedback here or Google Group post?
