Installing Serviio multiple times.....
AndrewW
Post Mon Jun 10, 2013 4:37 pm
Is it possible to install serviio multiple times on windows, each instance bound to separate IP addresses, and with its own and separate content
Post Mon Jun 10, 2013 5:11 pm
Re: Installing Serviio multiple times.....
No. If you really want it you can run them in VMs, else the Pro version lets you set some level of control over which devices can access different content.
g4r3thone
Post Fri Jun 14, 2013 11:53 am
Sorry to hijack but looking for an answer and search result lead me here.
My Question is:
Is it possible to have more than one client being served simultaneously? And if so what scenario/setup would I need?
Currently I'm finding from experiance one or the other will usually stutter usually the one that was served second.
So just wandering if thats something that can be solved or is it just something that can't be done with serviio successfully?
The pc running Serviio is a Windows 8 64bit Enterprise Build, Intel Qaud Core i5 2500 running @ 3.30 Ghz with 8gb ram and the files are served from a seperate nas4free raid5 box also with 8gb i5 coreduo both hardwired to a netgear R6300 which can support multable streaming.
Post Sat Jun 15, 2013 12:46 pm
Yes, it should not be a prolem, unless you need to transcode both. Also, the connection between the server and the NAS might be a bottleneck (content going NAS -> Serviio -> TV), so make sure the network there has no latency.
Users browsing this forum: Google [Bot] and 115 guests
