High CPU
• Page 1 of 1
Re: High CPU
Is this while streaming? Or library updates?
Petr
Help translate Serviio
Re: High CPU
Zip
This is from doing nothing, but since I deleted these links
http://feeds.bbc.co.uk/iplayer/highlights/tv
http://feeds.bbc.co.uk/iplayer/popular/tv
http://feeds.bbc.co.uk/iplayer/categories/drama/tv/list
from my serviio console
It seams to be ok at the mo
Is this normal ?
Is this normal ?
Beta Tester
Beta Tester
Re: High CPU
Some online plugins might cause this. There has been a new version of IPlayer plugin recently so try to upgrade it.
Petr
Re: High CPU
Thxs Zip
Will try that when I get home
Beta Tester
Beta Tester
Re: High CPU
Thxs Zip
Once I used the new plugin it idols much less
Beta Tester
Beta Tester
• Page 1 of 1
Users browsing this forum: Google [Bot] and 78 guests
