mkv wont play
siriusblack
Post Thu Jun 13, 2013 7:02 am
mkv wont play
HI
On my Samsung bdp my mkv files wont play on my siriusblack profile, however it plays on Samsung c/d/e
is there away to modify the sb profile to get it to work
Here is my profile
profiles.xml
(92.24 KiB) Downloaded 593 times
Hope this can help
Here is my ffmpeg-i
ffmpeg version N-42477-gcb59e62 Copyright (c) 2000-2012 the FFmpeg developers
built on Jul 13 2012 13:56:52 with gcc 4.7.1
configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-ru
ntime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libass
--enable-libcelt --enable-libopencore-amrnb --enable-libopencore-amrwb --enable
-libfreetype --enable-libgsm --enable-libmp3lame --enable-libnut --enable-libope
njpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libth
eora --enable-libutvideo --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-
libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --e
nable-zlib
libavcodec 54. 35.100 / 54. 35.100
libavformat 54. 16.104 / 54. 16.104
libavfilter 3. 2.100 / 3. 2.100
[matroska,webm @ 01e7bea0] Unknown entry 0xC6
[matroska,webm @ 01e7bea0] Unknown entry 0xEA
[matroska,webm @ 01e7bea0] Unknown entry 0x2AD1D3
Input #0, matroska,webm, from 'Episode 01 - The Longest Night.mkv':
Duration: 00:43:07.66, start: 0.000000, bitrate: 599 kb/s
Stream #0:0(eng): Video: h264 (High), yuvj420p, 624x352 [SAR 1:1 DAR 39:22],
23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
Stream #0:1(eng): Audio: mp3, 48000 Hz, stereo, s16, 128 kb/s (default)
Press any key to continue . . .
Here is my Mediainfo
Unique ID : 117362113332852257711533347062084537017 (0x584B1EEF6602963EAD397DA11AE80AB9)
Complete name : C:\Users\mark\Downloads\Criminal Minds Season 6\Episode 01 - The Longest Night.mkv
Format : Matroska
Format version : Version 1
File size : 185 MiB
Duration : 43mn 7s
Overall bit rate : 599 Kbps
Writing application : DivXMKVMux 3.4.1.0004
Writing library : libDivXMediaFormat 3.4.1.0004
Format : AVC
Format profile : High@L4.0
MultiView_Count : 2
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 43mn 7s
Bit rate : 459 Kbps
Width : 624 pixels
Height : 352 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.087
Stream size : 142 MiB (77%)
Language : English
Default : Yes
Forced : No
Color primaries : BT.601 NTSC
Transfer characteristics : BT.601
Matrix coefficients : BT.601
Format : MPEG Audio
Format profile : Layer 3
Mode : Joint stereo
Codec ID : A_MPEG/L3
Codec ID/Hint : MP3
Duration : 42mn 14s
Bit rate mode : Variable
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 38.7 MiB (21%)
Writing library : LAME3.90.
Encoding settings : -m j -V 4 -q 2 -lowpass 17.6 --abr 128
Language : English
Default : Yes
Forced : No
Thanks really appreciate it
Beta Tester
Post Thu Jun 13, 2013 7:31 am
Re: mkv wont play
Try this:
   <Profile id="sb" name="siriusblack" extendsProfileId="1">
     <MediaFormatProfiles>
         <MediaFormatProfile mime-type="video/x-mkv">MATROSKA</MediaFormatProfile>
     </MediaFormatProfiles>
      <OnlineTranscoding>
         <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384">
            <Matches container="*"/>
      </OnlineTranscoding>
siriusblack
Post Thu Jun 13, 2013 8:13 am
Re: mkv wont play
Hi Illico
Thanks for quick response
just tried it out
it comes up with cannot connect to serviio server, it does not seem to be running .Exiting....
Beta Tester
Post Thu Jun 13, 2013 9:10 am
Re: mkv wont play
Probably a syntax error on profiles.xml...
Could you post your profiles.xml ?
Could you enable detailed logging and post serviio.log after a serviio service restart ?
siriusblack
Post Thu Jun 13, 2013 1:40 pm
Re: mkv wont play
Thanks Illico
Here is my profile
profiles.xml
(92.43 KiB) Downloaded 757 times
Here is my Detailed log
It was too big to send it all
2013-06-13 14:20:25,715 INFO [MediaServer] ------------------------------------------------------------------------
2013-06-13 14:20:25,715 INFO [MediaServer] Serviio DLNA media streaming server v 1.2.1 (rev. a2aa56064460+)
2013-06-13 14:20:25,715 INFO [MediaServer] Petr Nejedly 2009-2013
2013-06-13 14:20:25,715 INFO [MediaServer] http://www.serviio.org
2013-06-13 14:20:25,715 INFO [MediaServer] Java 1.7.0_05-Oracle Corporation
2013-06-13 14:20:25,715 INFO [MediaServer] OS Windows NT (unknown) amd64 6.2
2013-06-13 14:20:25,715 INFO [MediaServer] File encoding: windows-1252
2013-06-13 14:20:25,715 INFO [MediaServer] Headless mode enabled: true
2013-06-13 14:20:25,715 INFO [MediaServer] User: MARK$
2013-06-13 14:20:25,715 INFO [MediaServer] User home dir: C:\
2013-06-13 14:20:25,715 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2013-06-13 14:20:26,231 INFO [WebServer] Socket buffer set to 65535 bytes
2013-06-13 14:20:26,231 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2013-06-13 14:20:26,356 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2013-06-13 14:20:26,356 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2013-06-13 14:20:26,387 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2013-06-13 14:20:26,434 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2013-06-13 14:20:28,544 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2013-06-13 14:20:28,544 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2013-06-13 14:20:28,544 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2013-06-13 14:20:28,544 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2013-06-13 14:20:28,544 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2013-06-13 14:20:28,544 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2013-06-13 14:20:28,544 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2013-06-13 14:20:28,544 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2013-06-13 14:20:28,544 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2013-06-13 14:20:28,544 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2013-06-13 14:20:28,544 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2013-06-13 14:20:28,544 DEBUG [DBLogDAOImpl] Checking if script 'script-1.0.sql' has been run
2013-06-13 14:20:28,544 DEBUG [DBLogDAOImpl] Checking if script 'script-1.1.sql' has been run
2013-06-13 14:20:28,544 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.sql' has been run
2013-06-13 14:20:28,544 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.1.sql' has been run
2013-06-13 14:20:28,606 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2013-06-13 14:20:28,637 DEBUG [LicenseValidator] Validating license file (375 bytes)
2013-06-13 14:20:28,747 INFO [MediaServer] ------------------------------------------------------------------------
2013-06-13 14:20:28,747 INFO [MediaServer] License: PRO (NORMAL, id: 22dfd1c5-192d-42e8-aaa8-ca2c44d702e7)
2013-06-13 14:20:28,762 DEBUG [LocalAddressResolverStrategy] Resolving host IP address automatically
2013-06-13 14:20:29,278 INFO [Device] Created UPnP Device with UUID: 8eda6066-4ca3-3622-adc9-b1740bc8c845, bound address: 192.168.0.9
2013-06-13 14:20:30,184 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2013-06-13 14:20:30,184 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2013-06-13 14:20:30,356 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2013-06-13 14:20:30,356 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2013-06-13 14:20:30,419 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2013-06-13 14:20:30,419 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2013-06-13 14:20:30,419 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2013-06-13 14:20:30,419 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2013-06-13 14:20:30,419 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2013-06-13 14:20:30,419 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2013-06-13 14:20:30,419 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2013-06-13 14:20:30,419 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2013-06-13 14:20:30,434 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2013-06-13 14:20:30,434 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2013-06-13 14:20:30,450 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E-series)' (id=7)
2013-06-13 14:20:30,450 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2013-06-13 14:20:30,450 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2013-06-13 14:20:30,450 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012
2013-06-13 14:20:30,450 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2013-06-13 14:20:30,450 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2012
2013-06-13 14:20:30,450 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2013-06-13 14:20:30,450 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010
2013-06-13 14:20:30,450 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2013-06-13 14:20:30,450 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010us
2013-06-13 14:20:30,450 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2013-06-13 14:20:30,450 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2011
2013-06-13 14:20:30,450 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2013-06-13 14:20:30,450 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2013-06-13 14:20:30,450 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2013-06-13 14:20:30,450 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2013-06-13 14:20:30,466 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2013-06-13 14:20:30,466 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2013-06-13 14:20:30,466 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2013-06-13 14:20:30,466 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2013-06-13 14:20:30,466 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2013-06-13 14:20:30,466 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2013-06-13 14:20:30,466 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2013-06-13 14:20:30,466 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2013-06-13 14:20:30,466 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2013-06-13 14:20:30,466 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011
2013-06-13 14:20:30,466 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2013-06-13 14:20:30,466 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2010
2013-06-13 14:20:30,466 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2013-06-13 14:20:30,466 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile plps2010
2013-06-13 14:20:30,466 INFO [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2013-06-13 14:20:30,466 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2013-06-13 14:20:30,466 INFO [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2013-06-13 14:20:30,466 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2009
2013-06-13 14:20:30,466 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2013-06-13 14:20:30,466 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 22
2013-06-13 14:20:30,466 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2013-06-13 14:20:30,466 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011a
2013-06-13 14:20:30,466 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2013-06-13 14:20:30,466 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2013-06-13 14:20:30,466 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2010
2013-06-13 14:20:30,466 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2013-06-13 14:20:30,466 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012us
2013-06-13 14:20:30,466 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2013-06-13 14:20:30,466 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011us
2013-06-13 14:20:30,466 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2013-06-13 14:20:30,466 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonySTR
2013-06-13 14:20:30,466 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2013-06-13 14:20:30,466 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonyCMT
2013-06-13 14:20:30,466 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2013-06-13 14:20:30,466 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viziotv
2013-06-13 14:20:30,466 INFO [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2013-06-13 14:20:30,466 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile win8metro
2013-06-13 14:20:30,481 INFO [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2013-06-13 14:20:30,481 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sb
2013-06-13 14:20:30,481 INFO [ProfilesDefinitionParser] Added profile 'siriusblack' (id=sb)
2013-06-13 14:20:30,544 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2013-06-13 14:20:30,544 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile flv_player
2013-06-13 14:20:30,544 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2013-06-13 14:20:30,544 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo
2013-06-13 14:20:30,544 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo' (id=serviigo)
2013-06-13 14:20:30,544 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile wp8
2013-06-13 14:20:30,544 INFO [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2013-06-13 14:20:30,794 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2013-06-13 14:20:30,794 INFO [UpdateChecker] Checking if a new version is available
2013-06-13 14:20:30,794 INFO [PluginCompilerThread] Started looking for plugins
2013-06-13 14:20:30,919 DEBUG [PluginCompilerThread] Starting plugin ABC.groovy compilation
2013-06-13 14:20:30,997 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2013-06-13 14:20:31,028 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2013-06-13 14:20:31,778 DEBUG [DCRawWrapper] Invoking DCRAW to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/dcraw.exe
2013-06-13 14:20:31,778 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/dcraw.exe
2013-06-13 14:20:33,404 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2013-06-13 14:20:33,404 DEBUG [AbstractTranscodingDeliveryEngine] Deleting temporary transcoded files from: C:\Windows\TEMP\Serviio
2013-06-13 14:20:33,702 INFO [WebServer] WebServer starting on port 8895
2013-06-13 14:20:33,702 DEBUG [DiscoveryManager] UPNP device 8eda6066-4ca3-3622-adc9-b1740bc8c845 (192.168.0.9) is available
2013-06-13 14:20:33,702 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-06-13 14:20:33,702 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-06-13 14:20:33,702 INFO [EventDispatcher] Starting EventDispatcher
2013-06-13 14:20:33,720 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2013-06-13 14:20:33,861 INFO [RendererSearchSender] Searching for Renderer devices
2013-06-13 14:20:35,924 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net7 (Intel(R) Centrino(R) Advanced-N 6235) and address 192.168.0.9, timeout = 0
2013-06-13 14:20:35,924 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net7 (Intel(R) Centrino(R) Advanced-N 6235) and address 192.168.0.9, timeout = 0
2013-06-13 14:20:35,924 DEBUG [RendererSearchSender$RendererSearchWorker] Multicasting SSDP M-SEARCH using interface net7 (Intel(R) Centrino(R) Advanced-N 6235) and address 192.168.0.9, timeout = 0
2013-06-13 14:20:35,939 INFO [PluginCompilerThread] Added Feed plugin ABC (ABC.groovy), version: 1
2013-06-13 14:20:35,939 DEBUG [PluginCompilerThread] Starting plugin ABCiView.groovy compilation
2013-06-13 14:20:36,064 DEBUG [RendererSearchSender$RendererSearchWorker] Sending 1 'm-search' messages
2013-06-13 14:20:36,064 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 8eda6066-4ca3-3622-adc9-b1740bc8c845
2013-06-13 14:20:36,095 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.0.9:64688s
2013-06-13 14:20:36,095 DEBUG [ServiioHttpService] Incoming request from /192.168.0.9:59464: GET /deviceDescription/8eda6066-4ca3-3622-adc9-b1740bc8c845 HTTP/1.0, headers = [Host: 192.168.0.9:8895,User-Agent: Windows/6.2 UPnP/1.0 DLNADOC/1.50 Mezzmo/3.2.0.0,friendlyName.DLNA.ORG: Mezzmo]]
2013-06-13 14:20:36,095 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2013-06-13 14:20:37,142 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 8eda6066-4ca3-3622-adc9-b1740bc8c845 from 192.168.0.9 (headers = [Host: 192.168.0.9:8895,User-Agent: Windows/6.2 UPnP/1.0 DLNADOC/1.50 Mezzmo/3.2.0.0,friendlyName.DLNA.ORG: Mezzmo])
2013-06-13 14:20:37,142 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2013-06-13 14:20:37,142 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.0.9:8895,User-Agent: Windows/6.2 UPnP/1.0 DLNADOC/1.50 Mezzmo/3.2.0.0,friendlyName.DLNA.ORG: Mezzmo]
2013-06-13 14:20:37,721 INFO [PluginCompilerThread] Added Feed plugin ABC iView (Australia only) (ABCiView.groovy), version: 1
2013-06-13 14:20:37,721 DEBUG [PluginCompilerThread] Starting plugin AlloCine.groovy compilation
2013-06-13 14:20:37,924 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2013-06-13 14:20:37,924 DEBUG [ServiioHttpService] Incoming request from /192.168.0.9:55705: GET /deviceDescription/serviceDescription/X_MS_MediaReceiverRegistrar HTTP/1.0, headers = [Host: 192.168.0.9:8895,User-Agent: Windows/6.2 UPnP/1.0 DLNADOC/1.50 Mezzmo/3.2.0.0,friendlyName.DLNA.ORG: Mezzmo]]
2013-06-13 14:20:37,924 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2013-06-13 14:20:37,986 INFO [PluginCompilerThread] Added Web Resouce plugin AlloCine (AlloCine.groovy), version: 1
2013-06-13 14:20:37,986 DEBUG [PluginCompilerThread] Starting plugin AnOriant.groovy compilation
2013-06-13 14:20:38,033 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:05 (advertisement duration is 1800 sec.)
2013-06-13 14:20:38,126 INFO [PluginCompilerThread] Added Feed plugin AnOriant (AnOriant.groovy), version: 1
2013-06-13 14:20:38,126 DEBUG [PluginCompilerThread] Starting plugin APVideo.groovy compilation
2013-06-13 14:20:38,320 INFO [PluginCompilerThread] Added Web Resouce plugin APVideo (APVideo.groovy), version: 5
2013-06-13 14:20:38,320 DEBUG [PluginCompilerThread] Starting plugin ARDMediathek.groovy compilation
2013-06-13 14:20:38,405 INFO [PluginCompilerThread] Added Feed plugin ARD Mediathek RSS Extractor (ARDMediathek.groovy), version: 1
2013-06-13 14:20:38,406 DEBUG [PluginCompilerThread] Starting plugin Arte.groovy compilation
2013-06-13 14:20:38,484 INFO [PluginCompilerThread] Added Feed plugin Arte (Arte.groovy), version: 1
2013-06-13 14:20:38,484 DEBUG [PluginCompilerThread] Starting plugin Beeg.groovy compilation
2013-06-13 14:20:38,580 INFO [PluginCompilerThread] Added Web Resouce plugin Beeg (Beeg.groovy), version: 10
2013-06-13 14:20:38,580 DEBUG [PluginCompilerThread] Starting plugin BillboardTop20.groovy compilation
2013-06-13 14:20:38,739 INFO [PluginCompilerThread] Added Web Resouce plugin BillboardTop20 (BillboardTop20.groovy), version: 6
2013-06-13 14:20:38,739 DEBUG [PluginCompilerThread] Starting plugin BlipTVUrlExtractor.groovy compilation
2013-06-13 14:20:38,813 INFO [PluginCompilerThread] Added Feed plugin BlipTVUrlExtractor (BlipTVUrlExtractor.groovy), version: 1
2013-06-13 14:20:38,813 DEBUG [PluginCompilerThread] Starting plugin CanalPlus.groovy compilation
2013-06-13 14:20:39,018 INFO [PluginCompilerThread] Added Web Resouce plugin CanalPlus (CanalPlus.groovy), version: 12
2013-06-13 14:20:39,018 DEBUG [PluginCompilerThread] Starting plugin Castalba.groovy compilation
2013-06-13 14:20:39,095 INFO [PluginCompilerThread] Added Web Resouce plugin Castalba (Castalba.groovy), version: 4
2013-06-13 14:20:39,095 DEBUG [PluginCompilerThread] Starting plugin CBS.groovy compilation
2013-06-13 14:20:39,201 INFO [PluginCompilerThread] Added Web Resouce plugin CBS.com (CBS.groovy), version: 1
2013-06-13 14:20:39,202 DEBUG [PluginCompilerThread] Starting plugin Channel4od.groovy compilation
2013-06-13 14:20:39,561 INFO [PluginCompilerThread] Added Web Resouce plugin 4OD (UK only) (Channel4od.groovy), version: 1
2013-06-13 14:20:39,561 DEBUG [PluginCompilerThread] Starting plugin CNN.groovy compilation
2013-06-13 14:20:39,709 INFO [PluginCompilerThread] Added Feed plugin CNN (CNN.groovy), version: 1
2013-06-13 14:20:39,709 DEBUG [PluginCompilerThread] Starting plugin ComedyCentral.groovy compilation
2013-06-13 14:20:39,951 INFO [PluginCompilerThread] Added Web Resouce plugin ComedyCentral (ComedyCentral.groovy), version: 1
2013-06-13 14:20:39,951 DEBUG [PluginCompilerThread] Starting plugin CONECTATE.groovy compilation
2013-06-13 14:20:40,026 INFO [PluginCompilerThread] Added Web Resouce plugin CONECTATE (CONECTATE.groovy), version: 1
2013-06-13 14:20:40,026 DEBUG [PluginCompilerThread] Starting plugin Coolsport.groovy compilation
2013-06-13 14:20:40,309 INFO [PluginCompilerThread] Added Web Resouce plugin coolsport (Coolsport.groovy), version: 21
2013-06-13 14:20:40,309 DEBUG [PluginCompilerThread] Starting plugin Crackle.groovy compilation
2013-06-13 14:20:40,381 INFO [PluginCompilerThread] Added Web Resouce plugin Crackle (Crackle.groovy), version: 4
2013-06-13 14:20:40,381 DEBUG [PluginCompilerThread] Starting plugin CW.groovy compilation
2013-06-13 14:20:40,426 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.0.9:60380s
2013-06-13 14:20:40,484 INFO [PluginCompilerThread] Added Web Resouce plugin cwtv.com (CW.groovy), version: 1
2013-06-13 14:20:40,484 DEBUG [PluginCompilerThread] Starting plugin DailyMotion.groovy compilation
2013-06-13 14:20:40,558 INFO [PluginCompilerThread] Added Feed plugin DailyMotion (DailyMotion.groovy), version: 1
2013-06-13 14:20:40,558 DEBUG [PluginCompilerThread] Starting plugin DesiStreams.groovy compilation
2013-06-13 14:20:40,653 INFO [PluginCompilerThread] Added Web Resouce plugin desistreams.tv (DesiStreams.groovy), version: 1
2013-06-13 14:20:40,653 DEBUG [PluginCompilerThread] Starting plugin digitallyimported.groovy compilation
2013-06-13 14:20:40,793 INFO [PluginCompilerThread] Added Web Resouce plugin DI.FM - SKY.FM - JAZZRADIO.COM v1.0 (digitallyimported.groovy), version: 1
2013-06-13 14:20:40,793 DEBUG [PluginCompilerThread] Starting plugin EightTracks.groovy compilation
2013-06-13 14:20:40,868 INFO [PluginCompilerThread] Added Web Resouce plugin EightTracks (EightTracks.groovy), version: 1
2013-06-13 14:20:40,868 DEBUG [PluginCompilerThread] Starting plugin Escapist.groovy compilation
2013-06-13 14:20:40,915 INFO [PluginCompilerThread] Added Web Resouce plugin Escapist (Escapist.groovy), version: 1
2013-06-13 14:20:40,915 DEBUG [PluginCompilerThread] Starting plugin ESPN Radio.groovy compilation
2013-06-13 14:20:40,942 INFO [PluginCompilerThread] Added Feed plugin ReutersCom (ESPN Radio.groovy), version: 1
2013-06-13 14:20:40,942 DEBUG [PluginCompilerThread] Starting plugin Gamespot.groovy compilation
2013-06-13 14:20:40,981 INFO [PluginCompilerThread] Added Feed plugin Gamespot (Gamespot.groovy), version: 2
2013-06-13 14:20:40,981 DEBUG [PluginCompilerThread] Starting plugin GameTrailers.groovy compilation
2013-06-13 14:20:41,018 INFO [PluginCompilerThread] Added Feed plugin GameTrailers (GameTrailers.groovy), version: 2
2013-06-13 14:20:41,018 DEBUG [PluginCompilerThread] Starting plugin Gulli.groovy compilation
2013-06-13 14:20:41,060 INFO [PluginCompilerThread] Added Feed plugin Gulli (Gulli.groovy), version: 1
2013-06-13 14:20:41,060 DEBUG [PluginCompilerThread] Starting plugin HaHaSport.groovy compilation
2013-06-13 14:20:41,521 INFO [PluginCompilerThread] Added Web Resouce plugin HaHaSport (HaHaSport.groovy), version: 30
2013-06-13 14:20:41,522 DEBUG [PluginCompilerThread] Starting plugin HDTrailers.groovy compilation
2013-06-13 14:20:42,064 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2013-06-13 14:20:43,427 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.0.9:60380s
2013-06-13 14:20:43,861 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net7 (Intel(R) Centrino(R) Advanced-N 6235) and address 192.168.0.9, timeout = 0
2013-06-13 14:20:43,861 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 8eda6066-4ca3-3622-adc9-b1740bc8c845
2013-06-13 14:20:44,471 INFO [PluginCompilerThread] Added Web Resouce plugin HDTrailers (HDTrailers.groovy), version: 11
2013-06-13 14:20:44,471 DEBUG [PluginCompilerThread] Starting plugin Hulu.groovy compilation
2013-06-13 14:20:44,627 INFO [PluginCompilerThread] Added Feed plugin Hulu (US only) (Hulu.groovy), version: 1
2013-06-13 14:20:44,627 DEBUG [PluginCompilerThread] Starting plugin Hypem.groovy compilation
2013-06-13 14:20:44,658 INFO [PluginCompilerThread] Added Feed plugin Hypem (Hypem.groovy), version: 1
2013-06-13 14:20:44,658 DEBUG [PluginCompilerThread] Starting plugin ILive.groovy compilation
2013-06-13 14:20:44,783 INFO [PluginCompilerThread] Added Web Resouce plugin ILive (ILive.groovy), version: 16
2013-06-13 14:20:44,783 DEBUG [PluginCompilerThread] Starting plugin IPlayer.groovy compilation
2013-06-13 14:20:44,940 INFO [PluginCompilerThread] Added Feed plugin BBC iPlayer (UK only) (IPlayer.groovy), version: 2
2013-06-13 14:20:44,940 DEBUG [PluginCompilerThread] Starting plugin ITVPlayer.groovy compilation
2013-06-13 14:20:45,190 INFO [PluginCompilerThread] Added Web Resouce plugin ITVPlayer (UK only) (ITVPlayer.groovy), version: 3
2013-06-13 14:20:45,190 DEBUG [PluginCompilerThread] Starting plugin LiveFeeds.groovy compilation
2013-06-13 14:20:45,221 INFO [PluginCompilerThread] Added Feed plugin LiveFeeds (LiveFeeds.groovy), version: 1
2013-06-13 14:20:45,221 DEBUG [PluginCompilerThread] Starting plugin M6group.groovy compilation
2013-06-13 14:20:45,408 INFO [PluginCompilerThread] Added Web Resouce plugin M6 group channels replay (M6group.groovy), version: 3
2013-06-13 14:20:45,408 DEBUG [PluginCompilerThread] Starting plugin MyiPlayer.groovy compilation
2013-06-13 14:20:45,549 INFO [PluginCompilerThread] Added Web Resouce plugin myiplayer.com (MyiPlayer.groovy), version: 1
2013-06-13 14:20:45,549 DEBUG [PluginCompilerThread] Starting plugin NBA.groovy compilation
2013-06-13 14:20:45,580 INFO [PluginCompilerThread] Added Feed plugin NBA (NBA.groovy), version: 1
2013-06-13 14:20:45,580 DEBUG [PluginCompilerThread] Starting plugin Nickelodeon.groovy compilation
2013-06-13 14:20:45,627 INFO [PluginCompilerThread] Added Web Resouce plugin Nickelodeon (Nickelodeon.groovy), version: 1
2013-06-13 14:20:45,627 DEBUG [PluginCompilerThread] Starting plugin OmroepNL.groovy compilation
2013-06-13 14:20:45,752 INFO [PluginCompilerThread] Added Web Resouce plugin Omroep NL (OmroepNL.groovy), version: 1
2013-06-13 14:20:45,752 DEBUG [PluginCompilerThread] Starting plugin Orf.groovy compilation
2013-06-13 14:20:45,799 INFO [PluginCompilerThread] Added Feed plugin Orf (Orf.groovy), version: 1
2013-06-13 14:20:45,799 DEBUG [PluginCompilerThread] Starting plugin Packers.groovy compilation
2013-06-13 14:20:45,815 INFO [PluginCompilerThread] Added Feed plugin Packers (Packers.groovy), version: 1
2013-06-13 14:20:45,815 DEBUG [PluginCompilerThread] Starting plugin PBS.groovy compilation
2013-06-13 14:20:45,862 INFO [PluginCompilerThread] Added Feed plugin PBSURLExtractor (PBS.groovy), version: 1
2013-06-13 14:20:45,862 DEBUG [PluginCompilerThread] Starting plugin PBSKids.groovy compilation
2013-06-13 14:20:45,924 INFO [PluginCompilerThread] Added Web Resouce plugin pbskids.org (PBSKids.groovy), version: 1
2013-06-13 14:20:45,924 DEBUG [PluginCompilerThread] Starting plugin PennyArcade.groovy compilation
2013-06-13 14:20:45,940 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:07 (advertisement duration is 1800 sec.)
2013-06-13 14:20:46,003 INFO [PluginCompilerThread] Added Feed plugin PennyArcade (PennyArcade.groovy), version: 1
2013-06-13 14:20:46,003 DEBUG [PluginCompilerThread] Starting plugin Playlist.groovy compilation
2013-06-13 14:20:46,427 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.0.9:60380s
2013-06-13 14:20:46,915 DEBUG [FeedItemUrlExtractor] Playlist extractor: --- ready deleting cover art files
2013-06-13 14:20:46,923 DEBUG [FeedItemUrlExtractor] Playlist extractor: - deleted cover art list: C:\Windows\TEMP\PlaylistPluginCovers.txt, true
2013-06-13 14:20:46,938 DEBUG [FeedItemUrlExtractor] Playlist extractor: --- ready writing in cover art list from scratch
2013-06-13 14:20:46,939 INFO [PluginCompilerThread] Added Web Resouce plugin Playlist extractor (Playlist.groovy), version: 1
2013-06-13 14:20:46,939 DEBUG [PluginCompilerThread] Starting plugin Pluzz.groovy compilation
2013-06-13 14:20:47,124 INFO [PluginCompilerThread] Added Web Resouce plugin Pluzz (Pluzz.groovy), version: 15
2013-06-13 14:20:47,125 DEBUG [PluginCompilerThread] Starting plugin RadioBremen.groovy compilation
2013-06-13 14:20:47,184 INFO [PluginCompilerThread] Added Feed plugin Radio Bremen RSS Extractor (RadioBremen.groovy), version: 1
2013-06-13 14:20:47,184 DEBUG [PluginCompilerThread] Starting plugin Rage.groovy compilation
2013-06-13 14:20:47,258 INFO [PluginCompilerThread] Added Web Resouce plugin Rage (Rage.groovy), version: 1
2013-06-13 14:20:47,258 DEBUG [PluginCompilerThread] Starting plugin RedTube.groovy compilation
2013-06-13 14:20:47,345 INFO [PluginCompilerThread] Added Web Resouce plugin RedTube (RedTube.groovy), version: 3
2013-06-13 14:20:47,345 DEBUG [PluginCompilerThread] Starting plugin Refresh.groovy compilation
2013-06-13 14:20:47,401 INFO [PluginCompilerThread] Added Web Resouce plugin Refresh (Refresh.groovy), version: 1
2013-06-13 14:20:47,401 DEBUG [PluginCompilerThread] Starting plugin ReutersCom.groovy compilation
2013-06-13 14:20:47,452 INFO [PluginCompilerThread] Added Feed plugin ReutersCom (ReutersCom.groovy), version: 1
2013-06-13 14:20:47,453 DEBUG [PluginCompilerThread] Starting plugin RTLXL.groovy compilation
2013-06-13 14:20:47,517 INFO [PluginCompilerThread] Added Web Resouce plugin RTL XL (RTLXL.groovy), version: 1
2013-06-13 14:20:47,517 DEBUG [PluginCompilerThread] Starting plugin RTVE.groovy compilation
2013-06-13 14:20:47,572 INFO [PluginCompilerThread] Added Feed plugin RTVE (RTVE.groovy), version: 1
2013-06-13 14:20:47,572 DEBUG [PluginCompilerThread] Starting plugin SeasonVar.groovy compilation
2013-06-13 14:20:47,699 INFO [PluginCompilerThread] Added Web Resouce plugin SeasonVar (SeasonVar.groovy), version: 1
2013-06-13 14:20:47,699 DEBUG [PluginCompilerThread] Starting plugin Shoutcast.groovy compilation
2013-06-13 14:20:47,763 INFO [PluginCompilerThread] Added Web Resouce plugin Shoutcast (Shoutcast.groovy), version: 4
2013-06-13 14:20:47,763 DEBUG [PluginCompilerThread] Starting plugin SkysportsPlus.groovy compilation
2013-06-13 14:20:48,065 INFO [PluginCompilerThread] Added Web Resouce plugin skysportsplus (SkysportsPlus.groovy), version: 24
2013-06-13 14:20:48,065 DEBUG [PluginCompilerThread] Starting plugin Snotr.groovy compilation
2013-06-13 14:20:48,107 INFO [PluginCompilerThread] Added Feed plugin SnotrUrlExtractor (Snotr.groovy), version: 1
2013-06-13 14:20:48,107 DEBUG [PluginCompilerThread] Starting plugin Sopcast.groovy compilation
2013-06-13 14:20:48,179 INFO [PluginCompilerThread] Added Web Resouce plugin Sopcast (Sopcast.groovy), version: 6
2013-06-13 14:20:48,180 DEBUG [PluginCompilerThread] Starting plugin Stepashka.groovy compilation
2013-06-13 14:20:48,245 INFO [PluginCompilerThread] Added Web Resouce plugin Stepashka (Stepashka.groovy), version: 1
2013-06-13 14:20:48,245 DEBUG [PluginCompilerThread] Starting plugin Stopstream.groovy compilation
2013-06-13 14:20:48,668 INFO [PluginCompilerThread] Added Web Resouce plugin Stopstream (Stopstream.groovy), version: 30
2013-06-13 14:20:48,668 DEBUG [PluginCompilerThread] Starting plugin SvtPlay.groovy compilation
2013-06-13 14:20:48,804 INFO [PluginCompilerThread] Added Web Resouce plugin SvtPlay (SvtPlay.groovy), version: 9
2013-06-13 14:20:48,805 DEBUG [PluginCompilerThread] Starting plugin Syfy.groovy compilation
2013-06-13 14:20:48,858 INFO [PluginCompilerThread] Added Web Resouce plugin Syfy.com (Syfy.groovy), version: 1
2013-06-13 14:20:48,858 DEBUG [PluginCompilerThread] Starting plugin TeamCoco.groovy compilation
2013-06-13 14:20:49,032 INFO [PluginCompilerThread] Added Web Resouce plugin TeamCoco (TeamCoco.groovy), version: 1
2013-06-13 14:20:49,032 DEBUG [PluginCompilerThread] Starting plugin TED.groovy compilation
2013-06-13 14:20:49,083 INFO [PluginCompilerThread] Added Web Resouce plugin TED (TED.groovy), version: 1
2013-06-13 14:20:49,083 DEBUG [PluginCompilerThread] Starting plugin Top100.groovy compilation
2013-06-13 14:20:49,125 INFO [PluginCompilerThread] Added Web Resouce plugin YouTubeTop100 (Top100.groovy), version: 21
2013-06-13 14:20:49,125 DEBUG [PluginCompilerThread] Starting plugin TouTV.groovy compilation
2013-06-13 14:20:49,228 INFO [PluginCompilerThread] Added Web Resouce plugin TouTV (TouTV.groovy), version: 1
2013-06-13 14:20:49,228 DEBUG [PluginCompilerThread] Starting plugin TrailerAddict.groovy compilation
2013-06-13 14:20:49,267 INFO [PluginCompilerThread] Added Web Resouce plugin TrailerAddict (TrailerAddict.groovy), version: 15
2013-06-13 14:20:49,267 DEBUG [PluginCompilerThread] Starting plugin TuneIn.groovy compilation
2013-06-13 14:20:49,321 INFO [PluginCompilerThread] Added Web Resouce plugin Tune In (TuneIn.groovy), version: 3
2013-06-13 14:20:49,321 DEBUG [PluginCompilerThread] Starting plugin TurboTVIndia.groovy compilation
2013-06-13 14:20:49,383 INFO [PluginCompilerThread] Added Web Resouce plugin turbotv.in (TurboTVIndia.groovy), version: 1
2013-06-13 14:20:49,383 DEBUG [PluginCompilerThread] Starting plugin TurboTVTamil.groovy compilation
2013-06-13 14:20:49,448 INFO [PluginCompilerThread] Added Web Resouce plugin tamiltv.tv (TurboTVTamil.groovy), version: 1
2013-06-13 14:20:49,448 DEBUG [PluginCompilerThread] Starting plugin Tv3Play.groovy compilation
2013-06-13 14:20:49,484 INFO [PluginCompilerThread] Added Feed plugin Tv3Play (Tv3Play.groovy), version: 1
2013-06-13 14:20:49,484 DEBUG [PluginCompilerThread] Starting plugin Tv4Play.groovy compilation
2013-06-13 14:20:49,521 INFO [PluginCompilerThread] Added Feed plugin Tv4Play (Tv4Play.groovy), version: 1
2013-06-13 14:20:49,521 DEBUG [PluginCompilerThread] Starting plugin Tv6Play.groovy compilation
2013-06-13 14:20:49,536 INFO [PluginCompilerThread] Added Feed plugin Tv6Play (Tv6Play.groovy), version: 1
2013-06-13 14:20:49,536 DEBUG [PluginCompilerThread] Starting plugin Tv8Play.groovy compilation
2013-06-13 14:20:49,567 INFO [PluginCompilerThread] Added Feed plugin Tv8Play (Tv8Play.groovy), version: 1
2013-06-13 14:20:49,567 DEBUG [PluginCompilerThread] Starting plugin twitch.groovy compilation
2013-06-13 14:20:49,602 INFO [PluginCompilerThread] Added Web Resouce plugin twitch.tv (twitch.groovy), version: 3
2013-06-13 14:20:49,602 DEBUG [PluginCompilerThread] Starting plugin UitzendingGemist.groovy compilation
2013-06-13 14:20:49,635 INFO [PluginCompilerThread] Added Web Resouce plugin Uitzending Gemist (UitzendingGemist.groovy), version: 1
2013-06-13 14:20:49,635 DEBUG [PluginCompilerThread] Starting plugin USTREAM.groovy compilation
2013-06-13 14:20:49,674 INFO [PluginCompilerThread] Added Web Resouce plugin ustream.tv (USTREAM.groovy), version: 1
2013-06-13 14:20:49,674 DEBUG [PluginCompilerThread] Starting plugin uzg.groovy compilation
2013-06-13 14:20:49,718 INFO [PluginCompilerThread] Added Web Resouce plugin Uitzending Gemist (uzg.groovy), version: 1
2013-06-13 14:20:49,718 DEBUG [PluginCompilerThread] Starting plugin Veetle.groovy compilation
2013-06-13 14:20:49,783 INFO [PluginCompilerThread] Added Web Resouce plugin veetle.com (Veetle.groovy), version: 1
2013-06-13 14:20:49,783 DEBUG [PluginCompilerThread] Starting plugin Vimeo.groovy compilation
2013-06-13 14:20:49,806 INFO [PluginCompilerThread] Added Feed plugin Vimeo (Vimeo.groovy), version: 2
2013-06-13 14:20:49,806 DEBUG [PluginCompilerThread] Starting plugin Walla.groovy compilation
2013-06-13 14:20:49,868 INFO [PluginCompilerThread] Added Web Resouce plugin Walla (Walla.groovy), version: 1
2013-06-13 14:20:49,869 DEBUG [PluginCompilerThread] Starting plugin WAT.groovy compilation
2013-06-13 14:20:49,938 INFO [PluginCompilerThread] Added Feed plugin WAT (WAT.groovy), version: 13
2013-06-13 14:20:49,938 DEBUG [PluginCompilerThread] Starting plugin WimpCom.groovy compilation
2013-06-13 14:20:49,971 INFO [PluginCompilerThread] Added Feed plugin WimpCom (WimpCom.groovy), version: 1
2013-06-13 14:20:49,971 DEBUG [PluginCompilerThread] Starting plugin XVIDEOS.groovy compilation
2013-06-13 14:20:50,015 INFO [PluginCompilerThread] Added Web Resouce plugin XVIDEOS (XVIDEOS.groovy), version: 1
2013-06-13 14:20:50,015 DEBUG [PluginCompilerThread] Starting plugin YahooMovies.groovy compilation
2013-06-13 14:20:50,062 INFO [PluginCompilerThread] Added Feed plugin Yahoo Movies (YahooMovies.groovy), version: 1
2013-06-13 14:20:50,062 DEBUG [PluginCompilerThread] Starting plugin Youtube.groovy compilation
2013-06-13 14:20:50,117 INFO [PluginCompilerThread] Added Feed plugin YouTube (Youtube.groovy), version: 1
2013-06-13 14:20:50,117 DEBUG [PluginCompilerThread] Starting plugin ZengaTV.groovy compilation
2013-06-13 14:20:50,173 INFO [PluginCompilerThread] Added Web Resouce plugin zengatv.com (ZengaTV.groovy), version: 1
2013-06-13 14:20:50,173 DEBUG [PluginCompilerThread] Starting plugin ZonyTV.groovy compilation
2013-06-13 14:20:50,224 INFO [PluginCompilerThread] Added Web Resouce plugin zonytvcom.info (ZonyTV.groovy), version: 1
2013-06-13 14:20:53,893 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net7 (Intel(R) Centrino(R) Advanced-N 6235) and address 192.168.0.9, timeout = 0
2013-06-13 14:20:53,893 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 8eda6066-4ca3-3622-adc9-b1740bc8c845
2013-06-13 14:20:55,862 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:25 (advertisement duration is 1800 sec.)
2013-06-13 14:21:00,253 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.0.9:60380s
2013-06-13 14:21:02,257 INFO [FeedUpdaterThread] Started looking for information about online resources
2013-06-13 14:21:02,257 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-06-13 14:21:02,259 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-06-13 14:21:02,261 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-06-13 14:21:02,264 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-06-13 14:21:02,269 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2013-06-13 14:21:02,269 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-06-13 14:21:02,270 INFO [PlaylistMaintainerThread] Started looking playlist changes
2013-06-13 14:21:02,295 DEBUG [PlaylistDAOImpl] Reading all Playlists
2013-06-13 14:21:02,415 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2013-06-13 14:21:02,416 DEBUG [LibraryUpdatesCheckerThread] Looking for removed playlist files in repository: C:\Users\mark\Downloads
2013-06-13 14:21:02,416 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: C:\Users\mark\Downloads
2013-06-13 14:21:02,416 DEBUG [PlaylistDAOImpl] Reading Playlists for Repository (id = 1)
2013-06-13 14:21:02,417 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: C:\Users\mark\Downloads\Acestream Recordings
Beta Tester
Post Thu Jun 13, 2013 3:40 pm
Re: mkv wont play
line 1629 on your profiles.xml remove "</Profile>" element ( too much ), save.
Restart serviio service or reboot PC.
PS : What is the purpose of this custom profile?
siriusblack
Post Thu Jun 13, 2013 3:54 pm
Re: mkv wont play
I use the sb profile cause my online stuff didn't work
On the both profiles gen / sams c/d/e
So If I get this working I don't have to keep changing profiles
Thanks again
Will do that when I get home 2nite
Thanks Really appreciate all your help
Beta Tester
