Suddenly have 2 major problems with my Serviio..
Cubix
Post Fri Jun 14, 2013 12:03 am
Hello..
Couldnt find any post about this so either i am blind or there is none... Anyywayyy....
Been using Serviio for some time now and i have never had any problems until 1 week ago...
I mainly use serviio to stream from my PC to my Samsung smart tv.. and starting 1 week ago the folder browsing is really laggy.. (Sorry in advance if this explanation is messy and hard to understand but i will do my best.)
When everything was working fine i could browse the folders with ease.. but now when i move the selection box onto a folder the tv(?) or serviio server(?) takes some time to load the info about it and creates what feels like a lagg.. so instead of just browsing arround i need to wait after each selection for it to cach up... Hope you understand what i mean otherwise i guess i will add some pictures or something :P
The other problem that accured at the same time is that if i start to watch f.ex a movie and then need to pause in the middle i could just start it again later on and it would remember where i was.. It doesnt anymore so now it starts from the top everytime and i need to fast forward...
Really hope you know what i should do in order to fix this...
Also feel free to ask for any further info if needed since i know i am not providing much in this thread.
Thx in advance /C
Post Fri Jun 14, 2013 9:27 am
Re: Suddenly have 2 major problems with my Serviio..
Make sure you're still using the Samsung profile (for the resume functionality), but I think it only works for certain file types too.
Cubix
Post Fri Jun 14, 2013 11:20 pm
Changed profile and now it remembers where i was so thx for that.. :)
Still have the problem with the laggy menues tho.. :/
Cubix
Post Tue Jun 18, 2013 11:47 pm
Bump..
And if it helps.. When pressing source on the remote i used to see the serviio logo in the list now it's just a screen with a ? in it...
Post Wed Jun 19, 2013 3:48 am
Post a detailed log for a period when you are browsing your menu items.
Cubix
Post Sat Jun 22, 2013 12:10 am
Not sure what i did really but it's working now .. o_O
Thx anyway :D
Users browsing this forum: No registered users and 56 guests
