IPTV Streaming
vertraut
Post Sun Jun 16, 2013 5:51 pm
IPTV Streaming
Hi, thank you for Serviio, its very comfortable and better than Samsung soft)
I would like to make ipvt streaming from PC to Samsung SmartTV.
On PC I use vlc player -> Local network -> Network Streams (SAP) to see IPTV from my internet provider.
Can Serviio be usefull for me in this case?
Post Sun Jun 16, 2013 6:41 pm
Re: IPTV Streaming
What is the protocol used by VLC / IPTV provider ?
vertraut
Post Mon Jun 17, 2013 8:26 am
Re: IPTV Streaming
mpeg 4
Post Mon Jun 17, 2013 9:48 am
Re: IPTV Streaming
not codec, I mean http, rtsp, etc .....
What is the url used with VLC?
vertraut
Post Mon Jun 17, 2013 8:24 pm
Re: IPTV Streaming
I didn't give VLC any URL. It loads video stream from SAP (local network me and my FTTx provider http://www.idc.md).
If I use IPTV player, I use URL http://iptv4.idc.md/files/m3u.php, if you can't open it, I do it myself:
#EXTM3U
#EXTINF:0,IDC Детский
udp://@224.33.7.1:1234
#EXTINF:0,IDC Кино 1
udp://@224.33.7.2:1234
#EXTINF:0,IDC Кино 2
udp://@224.33.7.3:1234
#EXTINF:0,IDC Кино 3
udp://@224.33.7.4:1234
#EXTINF:0,IDC Наше кино 1
udp://@224.33.7.5:1234
#EXTINF:0,IDC Наше кино 2
udp://@224.33.7.6:1234
#EXTINF:0,ТСВ
udp://@224.33.120.1:1234
#EXTINF:0,Первый
udp://@224.33.220.2:1234
#EXTINF:0,Discovery
udp://@224.33.120.20:1234
#EXTINF:0,Animal Planet
udp://@224.33.120.21:1234
#EXTINF:0,Кино плюс
udp://@224.33.120.22:1234
#EXTINF:0,Феникс-Кино
udp://@224.33.120.23:1234
#EXTINF:0,Здоровое ТВ
udp://@224.33.120.24:1234
#EXTINF:0,Россия 24
udp://@224.41.120.1:1234
#EXTINF:0,EuroNews
udp://@224.41.120.2:1234
#EXTINF:0,BBC World
udp://@224.41.120.3:1234
#EXTINF:0,CNN International
udp://@224.41.120.4:1234
#EXTINF:0,Bloomberg
udp://@224.41.120.5:1234
#EXTINF:0,Russia Today
udp://@224.41.120.6:1234
sergdm
Post Tue Oct 22, 2013 11:38 am
Re: IPTV Streaming
Can I get a stream on TV from link like this - udp://@224.33.7.1:1234 ? It is item from playlist IPTV of our provider.
I've made "video stream" and wrote this link, I see this item in Serviio menu on TV, but my Philips TV not show.
maza11
Post Sat Aug 20, 2016 9:14 pm
Re: IPTV Streaming
Please help, I use Serviio v 1.6.1
We are satisfied, but we need to IPTV
because cable and terrestrial TV no
I have a playlist
http://iptv.servzp.pp.ua/list/triolan.m3u
content therein is
I tried to simply copy the url and add online sources. it does not work, the TV does not see it
It can have the plug-ins needed
YouTube and how to look at it, too, at the same time I would like to know already
It stands on win7
Прошу помощи, пользуюсь Serviio v 1.6.1
все устраивает, но нужно IPTV
т.к. кабельного и эфирного телевидения нету
есть плейлист
в нем такое содержимое
пробовал просто копировать этот url и добавлять в online источники. ничего не получается, тв не видит это
может какие то плагины нужны
и как ютуб смотреть на нем тоже заодно хотелось бы узнать уже
стоит на win7
Post Sun Aug 21, 2016 11:23 am
Re: IPTV Streaming
maza11
Post Sun Aug 21, 2016 9:19 pm
Re: IPTV Streaming
TV does not see this channel
I did start and stop services
Image Image Image
Post Mon Aug 22, 2016 7:56 am
Re: IPTV Streaming
Hmm. when I do
ffmpeg -i "http://109.86.131.67:8888/udp/238.0.0.9:1234"
I get an unknown error. So either the site is not accessible to me from here or FFmpeg can't deal with the stream / whatever lives there.
maza11
Post Mon Aug 22, 2016 6:10 pm
Re: IPTV Streaming
I do not understand
Steam working 100%
But TV did not see
#EXTINF:0, K1
http://176.67.1.208:10/udp/239.255.250.61:1234
p.s. 'ffmpeg -i
Provided URL is not valid 'ffmpeg -i "http://176.67.1.208:10/udp/239.255.250.61:1234"'
Post Mon Aug 22, 2016 6:23 pm
Re: IPTV Streaming
The URL works for me now, for whatever reason.
Add it as a live stream / Video.
Re: IPTV Streaming
maza11
Post Tue Aug 23, 2016 5:46 am
Re: IPTV Streaming
After you add a TV channel did not see them, added plugin for playlists, from 100 channels to 11 channels to see the playlist. Several hours passed, and the channels appeared in the playlist and the one that I added.
Delay so much work.
The channels are working, but often goes to the buffering
Internet 50 Mbit / s Router TL-WR841ND is stable on your computer
После добавления канала телевизор их не видел, добавил плагин для плейлистов, из 100 каналов в плейлисте увидел 11 каналов. Прошло несколько часов и каналы появились и в плейлисте и тот один что я добавлял.
Задержка такая большая получается.
Каналы работают, но часто идет до буферизация
интернет 50 мбит/с, роутер TL-WR841ND на компьютере работает стабильно
maza11
Post Tue Aug 23, 2016 2:54 pm
Re: IPTV Streaming
How to quickly update information Serviio, vip08 and k1 I added yesterday, yesterday vechrom see both now only vip08.
30 minutes ago XXX added, and it is not present in the list
Image Image
Post Tue Aug 23, 2016 5:27 pm
Re: IPTV Streaming
It probably keeps failing retrieving the stream information, ie the error with ffmpeg. Nothing Serviio can do, either the stream is not consistent or ffmpeg doesn't play nice with it.
maza11
Post Tue Aug 23, 2016 5:36 pm
Re: IPTV Streaming
now
There is some delay
maza11
Post Tue Aug 23, 2016 5:40 pm
Re: IPTV Streaming
and how to add content ?
example
http://xxxxxxx.org:8000/movie/rita/rita/694.mkv
and
http://xxxxxxx.online:2500/live/mana/mana/2059.ts
Post Wed Aug 24, 2016 8:42 am
Re: IPTV Streaming
You could try to add them to a playlist and use this plugin: viewtopic.php?f=20&t=6022
maza11
Post Thu Aug 25, 2016 2:34 pm
Re: IPTV Streaming
must use the UDP-to-HTTP proxy program ?
TV connection via LAN ethernet
Return to General discussion
