AVI files playing choppy
jdavistdi
Post Mon Jun 17, 2013 12:30 am
I've noticed that AVI format files are particularly choppy regardless of their file size. Did not notice any errors in the logs. I've tried connecting the blu-ray player to an ethernet line and wireless with the same results. I have the new Sony BDP-S5100 model.
Any ideas?
NX3
Post Mon Jun 17, 2013 6:43 pm
Re: AVI files playing choppy
Post the mediainfo for one of the files...
jdavistdi
Post Tue Jun 18, 2013 12:44 am
NX3 wrote:Post the mediainfo for one of the files...
Sorry, I'm kind of a newbie, so I'm not exactly sure what you mean by mediafile, but here's the info from the details tab (under video):
Frame width: 720
Height: 480
Data rate: 28771kbps
Total bitrate: 29795
Frame rate: 29 frames/second
Audio:
Bit rate: 1024kbps
Channels: 2 (stereo)
Audio sample rate: 32 khz
Post Tue Jun 18, 2013 7:34 am
jdavistdi
Post Thu Jun 20, 2013 3:15 am
Illico wrote:Please : viewtopic.php?f=5&t=4510
Thanks for the tip. Finally figured it out:
Complete name : G:\My Videos\2004 Halloween - Clip 058.avi
Format : AVI
Commercial name : DVCPRO
File size : 93.5 MiB
Duration : 26s 226ms
Overall bit rate mode : Constant
Overall bit rate : 29.9 Mbps
Recorded date : 2004-10-29 09:26:41.000
TAPE : 2005-misc
TCOD : 12415069333
Format : DV
Codec ID : dvsd
Codec ID/Hint : Sony
Bit rate mode : Constant
Bit rate : 24.4 Mbps
Encoded bit rate : 28.8 Mbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:1:1
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Bottom Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 2.357
Time code of first frame : 00:20:41;14
Time code source : Subcode time code
Stream size : 90.0 MiB (96%)
Encoding settings : ae mode=full automatic / wb mode=automatic / white balance= / fcm=manual focus
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : 1
Bit rate : 1 024 Kbps
Channel(s) : 2 channels
Sampling rate : 32.0 KHz
Bit depth : 16 bits
Stream size : 3.20 MiB (3%)
Alignment : Aligned on interleaves
Interleave, duration : 265 ms (7.94 video frames)
Interleave, preload duration : 266 ms
Post Thu Jun 20, 2013 6:14 am
jdavistdi wrote:Video
Format : DV
Format : PCM
This i a very high video bitrate, not sure if this format is delivered in native format or transcoded (could you confirm, with detailed log), but you should have a good network settings for this video to be played flawlessly.
jdavistdi
Post Thu Jun 20, 2013 2:38 pm
Format : DV
Format : PCM
Sounds like the high bitrate over the wireless network might be one problem. I'll try to get the detailed log for the rest. Do you have any suggestions on good video conversion software?
Post Thu Jun 20, 2013 6:37 pm
What is the profile selected on console ?
Post Thu Jun 20, 2013 6:41 pm
if its Sony BDP 2012 profile,
You can try to add a custom profile for your DV video, by adding the following lines just before the last </Profiles> element in ../serviio/config/profiles.xml:
   <Profile id="custom" name="Sony BDP custom" extendsProfileId="bdp2012">
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="384" >
            <Matches container="avi" vCodec="dvvideo" profile="lpcm" />
jdavistdi
Post Thu Jun 20, 2013 9:17 pm
Illico wrote:if its Sony BDP 2012 profile,
Yes, I have the Sony BDP 2012 profile. I'll add the line you suggested and try again. Thanks!
