OpenJDK7 and Serviio
DanglingPointer
Post Wed Jun 19, 2013 4:59 am
Apologies if this is a silly question, I have tried searching for the answer and it seems some people are using OpenJDK7 but also OpenJDK6 in tandem; so just so it is clear...
Is Serviio compatible with OpenJDK7? Or do I need to remove it and replace it with 6 to avoid issues.
I will be downloading Serviio tonight and would like to satisfy the prerequisites.
Thanks in advance.
Post Wed Jun 19, 2013 8:59 am
Re: OpenJDK7 and Serviio
Yes, it will work with either.
DanglingPointer
Post Wed Jun 19, 2013 10:20 am
Awesome!
Uninstalling Mediatomb and installing Serviio now...
Users browsing this forum: Baidu [Spider] and 61 guests
