FFMPEG compile - libx264 not found
DouggieC
Post Thu Jun 20, 2013 9:10 am
Hi guys,
I'm attempting to build FFMPEG on Debian / SPARC platform, following the instructions in the wiki here: http://wiki.serviio.org/doku.php?id=build_ffmpeg_linux.
X264 compiled and installed fine, but when I then attempt to build FFMPEG with x264 included, I get the message:
ERROR: libx264 not found
If you think configure made a mistake, make sure you are using the latest
version from Git. If the latest version fails, report the problem to the
ffmpeg-user@ffmpeg.org mailing list or IRC #ffmpeg on irc.freenode.net.
Include the log file "config.log" produced by configure as this will help
solving the problem.
If I leave out --enable-libx264, the package then builds and installs correctly, but I'd like to include x264 support if possible.
Any ideas what might be going wrong?
Cheers
Doug
kiteboy
Post Thu Jun 20, 2013 5:00 pm
Re: FFMPEG compile - libx264 not found
Any solution to this - using the same guide getting the same error on ubuntu server 12.04
Post Thu Jun 20, 2013 6:51 pm
Look at this if you can find some differences: https://ffmpeg.org/trac/ffmpeg/wiki/Ubu ... ationGuide
kiteboy
Post Thu Jun 20, 2013 7:32 pm
Think ive messed this up now - gonna clean everything up before trying again
Have an .img before I started messing and will try again using that method (bit of a noob)
Post Thu Jun 20, 2013 8:22 pm
I did the 2nd June update to that guide after testing it out on Debian 7, so it should work on Ubuntu. Post back after cleaning stuff out.
kiteboy
Post Fri Jun 21, 2013 4:44 pm
Thanks - just wondering would the install differ on 32bit or 64bit?????
khurram23
Post Fri Jun 21, 2013 6:56 pm
If you compile from source, 32 or 64bit shouldn't matter. The system will take care of that while compiling.
You can also try to use the pre-compiled packages to see if they help. Link in my signature. These packages are compiled on Ubuntu for both 32bit and 64bit platform.
Dropbox - Get 500MB bonus space.
My pre-compiled FFMPEG, X264 packages for Linux/Ubuntu - Dropbox
kiteboy
Post Sat Jun 22, 2013 12:44 am
All sorted :
Missed this option
NOTE: New version of x264 contains by default support of OpenCL. If not installed or without sense (example Ubuntu 12.04LTS on VMWare) add to configure additional option –disable-opencl. Without this option ffmpeg could not be configured (ERROR: libx264 not found).
Just another noob question about following the wiki guide
Build and Install libvpx
libvpx is an emerging open video compression library which is gaining popularity for distributing high definition video content on the internet. FFmpeg supports using the libvpx library to compress video content (although Serviio does not). To acquire and build libvpx, perform the following:
When adding suppport for libvpx particulary:
Now rebuild ffmpeg by following the above steps except add
--enable-libvpx
to the long ./configure command
Do I have to make ffmpeg again or just config as in above instruction
Working fine now thanks
tguless
Post Thu Nov 14, 2013 10:05 pm
Here is a script I found on the net, and I just recently fixed it for Ubuntu 12
#!/bin/sh
# Name: ffmpeg git
# Version: 0.01a
# Description: ffmpeg git compilation with libvorbis, x264, mp3 lame support
# Script_URI: http://www.techno-blog.net
# Author: Nikos
##### Run some checks #####
# Check if user is root
if [ $(id -u) != "0" ]; then
echo "Erreur : Vous devez être root pour utiliser ce script, use sudo sh $0"
exit 1
fi
##### Set some variables and functions ######
# Directory where this script is located
BASEDIR="$(dirname $0)"
error_out() {
echo "Could not ${1}, aborting"
exit 1
wrap() {
local ErrorMsg="$1"
shift
local cmd="$1"
shift
$cmd "$@" || error_out "$ErrorMsg"
# Function to install packages
install_pkgs() {
aptitude -yq=3 install "$@"
# Function to remove packages
remove_pkgs() {
aptitude -yq=3 remove "$@"
##### The magic starts here #####
# Uninstall Packages
wrap "remove libmp3lame-dev ffmpeg" remove_pkgs libmp3lame-dev ffmpeg
# Install packages
wrap "install some dependancies" install_pkgs quilt libsdl1.2-dev libogg-dev libvorbis-dev liba52-dev libdts-dev libimlib2-dev texi2html libraw1394-dev libdc1394-22-dev libtheora-dev libgsm1-dev libxvidcore-dev libfaac-dev libfaad-dev build-essential git-core checkinstall yasm texi2html libopencore-amrnb-dev libopencore-amrwb-dev libtheora-dev libvorbis-dev libx11-dev libxfixes-dev zlib1g-dev nasm
# Retrieving x264, libvorbis, mp3lame
mkdir ffmpeg_source
cd ffmpeg_source
wrap "retrieving x264 from git sources" git clone git://git.videolan.org/x264
cd x264
wrap "set up x264 config" ./configure --enable-static --disable-opencl
wrap "compilation with 3 cores" make -j3
wrap "build install-lib-dev" make install-lib-dev
wrap "build DEB package" checkinstall --pkgname=x264 --default --pkgversion="3:$(./version.sh | awk -F'[" ]' '/POINT/{print $4"+git"$5}')" --backup=no --deldoc=yes
cd ..
mkdir -p /usr/local/share/doc/lame
wrap "download lamemp3 source" wget http://downloads.sourceforge.net/projec ... 8.4.tar.gz
tar xzvf lame-3.98.4.tar.gz
cd lame-3.98.4
wrap "set up lamemp3" ./configure --enable-nasm --disable-shared
wrap "compilation" make
wrap "build DEB package" checkinstall --pkgname=lame-ffmpeg --pkgversion="3.98.4" --backup=no --default --deldoc=yes
cd ..
wrap "retrieving libvpx from git sources" git clone http://git.chromium.org/webm/libvpx.git
cd libvpx
wrap "set up libvpx config" ./configure
wrap "build DEB package" checkinstall --pkgname=libvpx --pkgversion="$(date +%Y%m%d%H%M)-git" --backup=no --default --deldoc=yes
cd ..
wrap "retrieving ffmpeg from git sources" git clone git://git.videolan.org/ffmpeg
cd ffmpeg
wrap "set up ffmpeg config" ./configure --enable-gpl --enable-postproc --enable-swscale --enable-pthreads --enable-x11grab --enable-libdc1394 --enable-libfaac --enable-libgsm --enable-libmp3lame --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --enable-nonfree --enable-version3 --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libvpx --enable-avfilter
wrap "build DEB package" checkinstall --pkgname=ffmpeg --pkgversion="0.6.3-git" --backup=no --deldoc=yes --default
hash x264 ffmpeg ffplay ffprobe
echo "#############################"
echo "##### Mission complete! #####"
