Re: LG 47" MP4/1080 Files Stutter ?
pasta1234 wrote:I figured id try and load the Beta Version 1.3 which made no difference.
If i try and comment the code you suggested below serviio service fails to start for some reason.
With the attached profiles file i have attached the LOG file, perhaps that might shed some flashlight . With trasncoding enabled the file appears as a video real and is unplayable, see pic.
Are there others who have their LG TVs successfully transcoding ?
Pete
Yes dude.. I think there are must some man who have their LG TVs successfully transcoding.
