Transcode from 25fps to 23.976
caustic386
Post Sun Jun 23, 2013 4:21 am
Is it possible to use Serviio to transcode files from 25fps to 23.976fps? My Oppo BDP-103 doesn't care much for 25fps; skips every second.
Post Sun Jun 23, 2013 9:04 am
Re: Transcode from 25fps to 23.976
No.
But you can use ffmpeg with "-r" option to transcode your file and force output frame rate.
caustic386
Post Mon Jun 24, 2013 12:07 am
Admittedly, I'm way out of my depth here, but isn't ffmpeg the tool Serviio uses to transcode?
Post Mon Jun 24, 2013 6:53 am
Right, but serviio does not use all ffmpeg options (features), and user could not customized ffmpeg command line.
But you can use ffmpeg out of serviio, to transcode your file with custom option. And I pointed you the "-r" option.
caustic386
Post Mon Jun 24, 2013 11:34 am
Understood - thanks for your suggestion!
