Console will not open
BigC_13
Post Mon Jun 24, 2013 4:46 pm
I've just installed Serviio on recommendations from a friend. However whenever I try and open Serviio console nothing happens, watching the processes the console will start and then close immediately. Tried everything I could think of, re-installing, disabling my anti-virus, running as an administrator and compatibility mode and nothing seems to work. I'm running Windows 7 Ultimate 64 bit.
Any suggestions on what might be causing this?
Post Mon Jun 24, 2013 11:27 pm
Re: Console will not open
Check the log to see if there is an error when you start the console.
BigC_13
Post Tue Jun 25, 2013 5:46 am
zip wrote:Check the log to see if there is an error when you start the console.
This is all I get after trying to open it twice it disappears from processes after about 5 seconds:
2013-06-24 22:43:25,723 INFO [ServiioConsole] Starting Serviio Console
2013-06-24 22:43:26,810 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2013-06-24 22:45:06,680 INFO [ServiioConsole] Starting Serviio Console
2013-06-24 22:45:06,788 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
Post Tue Jun 25, 2013 9:40 am
Try to uninstall and reinstall your Java
Users browsing this forum: Google [Bot] and 47 guests
