Been "Twatted" by the "Dratted" Java 7 update!
hexeta
Post Tue Jun 25, 2013 9:58 am
After updating to current Java on my PC, I find it impossible to re-start Serviio.
I have attempted:-
E:/Serviio>Bin>ServiioServices.exe
...Brief flash of command prompt window.
I then try:-
E:/Serviio>Bin>ServiioConsole.exe
After a while, a sneaky window with no taskbar presence can be found lurking behind other windows declaring that Serviio doesn't appear to be working, so it's going home!.....and taking it's ball! :cry:
How on earth do I coax Serviio into life after Java updates? :lol:
hexeta
Post Tue Jun 25, 2013 10:16 am
Re: Been "Twatted" by the "Dratted" Java 7 update!
OK, OK, If at first you don't succeed....read the B... FAQ's! 8-)
Got it now, won't forget that in a hurry! :oops:
Still don't like that sneaky window though! ;)
