PS3 twitch resalution
l337g0g0
Post Fri Jun 21, 2013 12:32 pm
when i stream twitch to my ps3 or my Sony TV one or two inch's are off the side of the screen.
The ps3 you tube app does this also.
Can i add a border during trans-coding to fix this and have it shrinks so it fits to screen properly?
Or can i use another format that will fit by default?
Ty for you time...
boct1584
Post Fri Jun 21, 2013 2:13 pm
Re: PS3 twitch resalution
I was having that trouble too; it turned out to be a problem with how the TV was framing the image. On my TV (a Samsung), I set the picture size to "Just Scan" and that fixed it.
l337g0g0
Post Fri Jun 21, 2013 8:09 pm
I have a Sony 46 ex750, there is no option for just scan I'm pretty sure.
Also when i put the image in normal the image goes square and the edges are still cut off.
I'm wondering if i even find a scan option if the image is being cut off and still won't show.
Anyone else have any other ways of fixing this PLZ TY...
l337g0g0
Post Sat Jun 22, 2013 9:18 pm
BUMB.
Anyone?
l337g0g0
Post Wed Jun 26, 2013 9:27 am
bump one more time...
Post Wed Jun 26, 2013 9:56 am
Could you provide information about the stream format ?
With Sony Bravia device, when video is transcoded to mpeg2video, there is an option used in the profile "DAR=16:9" to "fit" image to the screen resolution.
But we know that in some cases, there are some pixels lost on border side, read the complete topic about this here : viewtopic.php?f=11&t=2956
l337g0g0
Post Sat Jun 29, 2013 12:31 pm
The stream format is 720P from Twitch.
Thanks for that link.
So i lose an inch off top bottom and left and right.
What's an easy fix so that any thing i stream to the PS3 will format properly. (I'm using Seviio 1.1 so the twitch add-on will work)
I see those yellow lines on the page you linked and don't know where to add them. i am a complete newb now with this kind of stuff.
Ty so much for your help...
Users browsing this forum: Baidu [Spider] and 5 guests
