Serviio, FFmpeg problem on Freebsd 9.1
• Page 1 of 1
I am not sure if this is a bug or what. I have installed Freebsd 9.1 on my server via ports. I used the make config panel and add RTMP to the config alone with the usual others. The problem I am having is that Serviio keeps saying that FFmpeg doesn't have support for librtmp. I ran a ffmpeg rtmp link in the console and it would display the video, but Serviio claims it will not work. Has anyone seen this happen?
Re: Serviio, FFmpeg problem on Freebsd 9.1
I'm confirming this with ffmpeg 1.2.1 and serviio from ports. I have librtmp enabled in the ffmpeg build, but serviio still claims a warning that is not enabled.
/var/log/serviio$ grep ffmpeg serviio.log
2013-06-27 22:48:49,465 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path /usr/local/bin/ffmpeg1
2013-06-27 22:48:49,469 DEBUG [ProcessExecutor] Starting /usr/local/bin/ffmpeg1
/var/log/serviio$ grep WARN serviio.log
2013-06-27 22:48:49,588 WARN [FFMPEGWrapper] FFmpeg is not compiled with librtmp support, RTMP streaming will not work.
/var/log/serviio$ ffmpeg1 -version
ffmpeg version 1.2.1
built on Jun 27 2013 21:35:03 with gcc 4.2.1 (GCC) 20070831 patched [FreeBSD]
configuration: --prefix=/usr/local --mandir=/usr/local/man --incdir=/usr/local/include/ffmpeg1 --libdir=/usr/local/lib/ffmpeg1 --shlibdir=/usr/local/lib/ffmpeg1 --datadir=/usr/local/share/ffmpeg1 --build-suffix=1 --progs-suffix=1 --enable-shared --enable-gpl --enable-postproc --enable-avfilter --enable-pthreads --enable-memalign-hack --disable-libstagefright-h264 --disable-libutvideo --disable-libsoxr --cc=cc --extra-cflags='-msse -I/usr/local/include/vorbis -I/usr/local/include' --extra-ldflags='-L/usr/local/lib ' --extra-libs=-pthread --disable-debug --enable-libaacplus --disable-indev=alsa --disable-outdev=alsa --disable-libopencore-amrnb --disable-libopencore-amrwb --enable-libass --disable-libcdio --disable-libcelt --enable-libfaac --enable-libfdk-aac --disable-ffserver --enable-fontconfig --enable-libfreetype --enable-frei0r --enable-gnutls --disable-libgsm --enable-iconv --enable-libmp3lame --enable-libbluray --disable-libv4l2 --disable-libmodplug --disable-openal --enable-libopencv --disable-libopenjpeg --disable-libopus --disable-libpulse --enable-librtmp --enable-libschroedinger --disable-ffplay --disable-libspeex --enable-libtheora --disable-vaapi --enable-vdpau --enable-libvo-aacenc --disable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxvid --enable-nonfree --enable-version3
Petr
Help translate Serviio
Here is the output.
Looks like rtmp is missing here.
Anyway I did another recompile of the port, and this is the configure section:
And this is the fresh binary:
- Code:
$ ffmpeg1
ffmpeg version 1.2.1 Copyright (c) 2000-2013 the FFmpeg developers
configuration: --prefix=/usr/local --mandir=/usr/local/man --incdir=/usr/local/include/ffmpeg1 --libdir=/usr/local/lib/ffmpeg1 --shlibdir=/usr/local/lib/ffmpeg1 --datadir=/usr/local/share/ffmpeg1 --build-suffix=1 --progs-suffix=1 --enable-shared --enable-gpl --enable-postproc --enable-avfilter --enable-pthreads --enable-memalign-hack --disable-libstagefright-h264 --disable-libutvideo --disable-libsoxr --cc=cc --extra-cflags='-msse -I/usr/local/include/vorbis -I/usr/local/include' --extra-ldflags='-L/usr/local/lib ' --extra-libs=-pthread --disable-debug --enable-libaacplus --disable-indev=alsa --disable-outdev=alsa --disable-libopencore-amrnb --disable-libopencore-amrwb --enable-libass --disable-libcdio --disable-libcelt --enable-libfaac --enable-libfdk-aac --disable-ffserver --enable-fontconfig --enable-libfreetype --enable-frei0r --enable-gnutls --disable-libgsm --enable-iconv --enable-libmp3lame --enable-libbluray --disable-libv4l2 --disable-libmodplug --disable-openal --enable-libopencv --disable-libope libavutil 52. 18.100 / 52. 18.100
libavcodec 54. 92.100 / 54. 92.100
libavformat 54. 63.104 / 54. 63.104
libavdevice 54. 3.103 / 54. 3.103
libavfilter 3. 42.103 / 3. 42.103
libswscale 2. 2.100 / 2. 2.100
libpostproc 52. 2.100 / 52. 2.100
Use -h to get full help or, even better, run 'man ffmpeg'
- Code:
$ ffmpeg1 -protocols
built on Jul 14 2013 17:47:46 with gcc 4.2.1 (GCC) 20070831 patched [FreeBSD]
Supported file protocols:
Input:
applehttp
bluray
cache
concat
crypto
data
file
gopher
hls
http
httpproxy
https
mmsh
mmst
pipe
rtp
sctp
srtp
tcp
tls
udp
rtmp
rtmpe
rtmps
rtmpt
rtmpte
Output:
file
gopher
http
httpproxy
https
md5
pipe
rtp
sctp
srtp
tcp
tls
udp
rtmp
rtmpe
rtmps
rtmpt
rtmpte
still not there, right? the rtmp formats from your output might be the built-in rtmp protocols
Petr
Hi
Any updates on this..
I have just upgraded to 1.3.1 and all is OK EXCEPT the FFMPEG issue as described below..I have a FFMPEG 1.2.2 from the latest port and protocols shows RTMP... but no --enable-librtmp
jail# ffmpeg1 -protocols
ffmpeg version 1.2.2 Copyright (c) 2000-2013 the FFmpeg developers
built on Aug 26 2013 21:49:22 with gcc 4.2.2 (GCC) 20070831 prerelease [FreeBSD]
configuration: --enable-x11grab --prefix=/usr/local --mandir=/usr/local/man --incdir=/usr/local/include/ffmpeg1 --libdir=/usr/local/lib/ffmpeg1 --shlibdir=/usr/local/lib/ffmpeg1 --datadir=/usr/local/share/ffmpeg1 --build-suffix=1 --progs-suffix=1 --enable-shared --enable-gpl --enable-postproc --enable-avfilter --enable-avresample --enable-pthreads --enable-memalign-hack --disable-libstagefright-h264 --disable-libutvideo --disable-libsoxr --cc=cc --extra-cflags='-msse -I/usr/local/include' --extra-ldflags='-L/usr/local/lib ' --extra-libs=-pthread --disable-debug --disable-libaacplus --disable-indev=alsa --disable-outdev=alsa --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libass --disable-libcdio --disable-libcelt --enable-libfaac --disable-libfdk-aac --enable-fontconfig --enable-libfreetype --enable-frei0r --enable-gnutls --disable-libgsm --enable-iconv --enable-libmp3lame --disable-libbluray --disable-libv4l2 --disable-libmodplug --disable-openal --enable-libopencv --disable-libopenjpeg --d libavutil 52. 18.100 / 52. 18.100
Input:
applehttp
cache
concat
crypto
data
file
gopher
hls
http
httpproxy
https
mmsh
mmst
pipe
rtp
sctp
srtp
tcp
tls
udp
rtmp
rtmpe
rtmps
rtmpt
rtmpte
Output:
file
gopher
http
httpproxy
https
md5
pipe
rtp
sctp
srtp
tcp
tls
udp
rtmp
rtmpe
rtmps
rtmpt
rtmpte
jail#
Yet I get 2013-08-26 21:56:36,516 WARN [FFMPEGWrapper] FFmpeg is not compiled with librtmp support, RTMP streaming will not work.
Has anyone got any further.
Input:
applehttp
cache
concat
crypto
data
file
gopher
hls
http
httpproxy
https
mmsh
mmst
pipe
rtp
sctp
srtp
tcp
tls
udp
rtmp
rtmpe
rtmps
rtmpt
rtmpte
Output:
file
gopher
http
httpproxy
https
md5
pipe
rtp
sctp
srtp
tcp
tls
udp
rtmp
rtmpe
rtmps
rtmpt
rtmpte
jail#
• Page 1 of 1
Users browsing this forum: Baidu [Spider] and 13 guests
