kdl46hx853 [2012 bravia] WMV files play with sound only
radiant
Post Fri Jun 28, 2013 3:28 am
Hi since I upgraded to using serviio 1.2.1 from the sony homestream program I can't play wmv correctly.
What happens is that there is sound but no picture.
Looking at similar issues on the forum I'm guessing I need to trick the server into transcoding the wmv file?
Is this correct?
How would I do this?
Should I use the sony specific profile from homestream?
How would I do that?
Thanks!
Post Fri Jun 28, 2013 7:39 am
Re: kdl46hx853 [2012 bravia] WMV files play with sound only
Could you provide information about your WMV file ? (see signature link)
radiant
Post Fri Jun 28, 2013 11:02 am
Using Windows 7 with Serviio 1.2.1
Streaming to a kdl46hx853 using the sony 2012 profile.
Here is the output of: ffmpeg.exe -i "test.wmv"
[I renamed the copy of the file to "test.wmv"]
ffmpeg version N-54143-gb6ce50a Copyright (c) 2000-2013 the FFmpeg developers
  built on Jun 22 2013 15:27:20 with gcc 4.7.3 (GCC)
  configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av
isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab
le-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetyp
e --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --ena
ble-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-l
ibopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libsp
eex --enable-libtheora --enable-libtwolame --enable-libvo-aacenc --enable-libvo-
amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --
enable-libxvid --enable-zlib
Guessed Channel Layout for  Input Stream #0.0 : stereo
Input #0, asf, from 'test.wmv':
    title           : test
    comment         : skinny
    WM/WMADRCPeakReference: 28205
    WM/WMADRCAverageReference: 2595
    Buffer Average  : 466045
    WMFSDKVersion   : 9.00.00.3250
    WMFSDKNeeded    : 0.0.0.0000
    VBR Peak        : 5082538
    IsVBR           : 1
  Duration: 00:11:01.54, start: 0.000000, bitrate: 2990 kb/s
    Stream #0:0: Audio: wmav2 (a[1][0][0] / 0x0161), 44100 Hz, stereo, fltp, 64
kb/s
    Stream #0:1: Video: wmv2 (WMV2 / 0x32564D57), yuv420p, 720x480, 2701 kb/s, 2
3.98 tbr, 1k tbn, 1k tbc
Is this what you need?
radiant
Post Sat Jun 29, 2013 4:07 pm
anyone?
Post Sun Jun 30, 2013 8:22 am
Don't know....
Sony Bravia 2012 devices should support WMV files in native format, but there is something wried in this one.
(For example, the video track is not in first position, I don't know if device support this...)
Users browsing this forum: Baidu [Spider], Google [Bot] and 11 guests
