force transcoding
Hiney
Post Sat Jun 29, 2013 1:15 am
force transcoding
How do i force transcoding ?
in profiles.xml i changed
<Profile id="2" name="Samsung TV (B-series)" extendsProfileId="1">
to
<Profile id="2" name="Samsung TV (B-series)" extendsProfileId="1" alwaysEnableTranscoding="true">
but i still get
2013-06-29 10:54:50,750 DEBUG [VideoDeliveryEngine] Delivering item '4' for client 'IPAddress=/192.168.1.2, Profile=Samsung TV (B-series)'
2013-06-29 10:54:50,750 DEBUG [VideoDeliveryEngine] Delivering file 'Transformers.3.Dark.of.the.Moon.2011.DVD.mp4' in native format
some mp4's work and other don't and i really care as to why. i just want the system to work and i certainly DON'T want to go thru and re transcode all my friends files (he's about 4hrs away by car so 'popping over' to fix things doesn't really work)
here's the stats on the files, cause i know someone will ask before assisting.
suspect file
D:\done\Transformers>ffmpeg.exe -i Transformers.3.Dark.of.the.Moon.2011.DVD.mp4
configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memal
ign-hack --enable-libmp3lame --enable-librtmp --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm' --ar
ch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-ming
w32- --pkg-config=pkg-config
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Transformers.3.Dark.of.the.Moon.2011.DVD.mp4':
major_brand : isom
minor_version : 512
compatible_brands: isomiso2avc1mp41
encoder : Lavf54.29.104
Duration: 01:35:05.80, start: 0.000000, bitrate: 787 kb/s
Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 704x288 [SAR 1:1 DAR 22:9], 6
52 kb/s, 25 fps, 25 tbr, 25 tbn, 50 tbc
handler_name : VideoHandler
Stream #0:1(und): Audio: aac (mp4a / 0x6134706D), 44100 Hz, stereo, s16, 126 kb/s
handler_name : SoundHandler
working file
D:\done>ffmpeg.exe -i Transsiberian.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Transsiberian.mp4':
major_brand : isom
minor_version : 512
Duration: 01:51:08.80, start: 0.000000, bitrate: 582 kb/s
Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 664x282 [SAR 1:1 DAR 332:141]
, 448 kb/s, 25 fps, 25 tbr, 25 tbn, 50 tbc
Stream #0:1(und): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, s16, 128 kb/s
Hiney
Post Sat Jun 29, 2013 5:32 am
Re: force transcoding
a partital result
i added
<Matches container="mp4" vCodec="h264" aCodec="aac" />
to the profiles.xml under the above profile and this then transcodes the files.
AND the ffmpeg from v1.0.1 as described elsewhere.
h
Users browsing this forum: Google [Bot] and 23 guests
