No cover art on samsung ue46f6200
krayzee
Post Sun Jun 23, 2013 2:21 pm
Hi
i dont seem to be able to get any cover art on my media when using serviio.
I have attached a debug log.
any help you can provide woule be great thanks
serviio.txt
debug log
(96.2 KiB) Downloaded 573 times
Post Sun Jun 30, 2013 2:24 pm
Re: No cover art on samsung ue46f6200
Do you see cover art when using Mediabrowser?
If not, make sure you:
  • checked the "Retrieve descriptive metadata" option against the share (Library tab, Shared Folders);
  • Checked the options under the Metadata tab (select "Online metadata sources" and ensure first three checkboxes are ticked)
  • Checked your file names are in accordance with http://www.serviio.org/component/conten ... RhZGF0YSJd
aacosta
Post Mon Jul 01, 2013 10:15 pm
It seems that the display of thumbnails is currently broken for the F Series TVs, see viewtopic.php?f=10&t=10460
