Sony KDL-50R550A 2013
wazntme
Post Sat Jun 29, 2013 4:10 am
I just purchased a Sony KDL-50R550A and it won't access Serviio. It see's it on my network . Serviio gives it a generic dlna profile. But that's where it ends. "The server is not accessible". ?
wazntme
Post Wed Jul 03, 2013 3:31 am
Re: Sony KDL-50R550A 2013
Any suggestions about this , am I missing something .
Post Wed Jul 03, 2013 4:23 am
Did you try creating a new Sony 2013 profile, see viewtopic.php?f=11&t=11147#p72112, or assigning one of the existing Sony Bravia 2012 profiles?
NX3
Post Wed Jul 03, 2013 4:42 pm
For now manually set the Sony 2012 profile and just confirm its all working ok ?
Post Wed Jul 03, 2013 8:33 pm
This is an other 2013 model (probably same than W6, W8, W9 series).
Could you provide formats supported by your device (see my signature link) ?
What is your country, UK, US ?
wazntme
Post Thu Jul 04, 2013 9:11 am
I apologize my file sharing was off in the firewall , I'm using the 2012 US profile for the moment.
Post Thu Jul 04, 2013 10:17 am
wazntme wrote:I apologize my file sharing was off in the firewall , I'm using the 2012 US profile for the moment.
OK,
With 2012 profile, that should work, but all your mkv will be transcoded where you could deliver them in native format.
There is a 2013 profile under contruction here, mkv will be delivered in native format.
Btw, that could be fine if you can confirm formats supported by your device (see my signature link) ?
marsvinie
Post Sun Sep 08, 2013 2:17 pm
Has anyone used a profile that works with this model.
This is the Getprofile of the tv.
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_T,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_ISO,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_T,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_ISO,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_JP_T,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_KO_ISO,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_T,
http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM,
http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM,
http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM,
http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM,
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3,
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM_ICO,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG_ICO,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_BASE,
http-get:*:video/mpeg:*,
http-get:*:video/vnd.dlna.mpeg-tts:*,
http-get:*:video/avi:*,
http-get:*:video/x-ms-asf:*,
http-get:*:video/x-ms-wmv:*,
http-get:*:video/mp4:*,
http-get:*:image/jpeg:*,
http-get:*:audio/L16:*,
http-get:*:audio/mpeg:*,
http-get:*:audio/x-ms-wma:*
Both Serviio come up in the tv. But Serviio gets to 98% and stalls. I have 2 other sony tvs and serviio still works great on it.
I did add the 2013 profile that i found here viewtopic.php?f=11&t=11147#p72112 but still same result.
Hope someone can help. I'm surprised there are not more users with this model.
Post Sun Sep 08, 2013 4:39 pm
marsvinie wrote:Has anyone used a profile that works with this model.
Do you try with the 2012 profile (you can select it on serviio console) ?
EDIT: could you confirm, it is an US model ? it seems that DLNA supported format are same than 2012 models : http://www.docs.sony.com/release/KDL-R520A_R550A.pdf
Files from a network device need to be in the following formats:
– Still images: JPEG
– Music: MP3, linear PCM, WMA
– Video: AVCHD, MPEG2, MPEG1, MP4 (AVC), MP4 (MPEG4), WMV
wazntme
Post Sat Oct 19, 2013 8:05 am
this KDL series seem to be an issue , anyone have a working profile for this , what seems to be so different from the other models Sony has put out. (last SONY I Buy).
wazntme
Post Tue Nov 19, 2013 11:35 am
KDL-R550A profile ? 2013
I was wondering if there is a working profile for this tv or in the works? I tried the beta with bad results. I use a 2012 profile and all my thumbnails are blank which makes it hard to pick a movie. Anyone have better results ,please let me know .. Thanks...
Post Tue Nov 19, 2013 7:31 pm
Re: KDL-R550A profile ? 2013
wazntme wrote:I use a 2012 profile and all my thumbnails are blank which makes it hard to pick a movie. Anyone have better results ,please let me know .. Thanks...
Thumbnails blank is strange, this is the same behaviour than Sony BDP players.
Could you try to select "BDP 2012 profile" on serviio console?
Then, with Intel UPnP tools (Device Spy), could you provide the Device XML (rigth click on device) ?
