Xbox360 help
gmann001
Post Mon Jun 24, 2013 1:05 pm
Xbox360 help
I need a little help. I have a PS3 and Xbox360. My goal is to have a video that plays on both devices WITH surround sound 5.1 and preferably able to fast forward/rewind.
I originally had my files with avi with xvid/mp3. Worked on both, but no 5.1
I tried mkv with h264/aac 5.1 and it appears to work but unable to fast forward/rewind
Read some posts that say to use mp4 container. Tried that with h264/aac 5.1 and it all works in ps3 but xbox360 can't read file.
My question is, is there a container with video and audio combo that works on both devices matching my criteria. If not, can I set it so the Ps3 (primary) will play and then the Xbox transcoded as needed to play if I decide to use that device?
If my only option is transcoding for Xbox, how do I accomplish that?
Post Mon Jun 24, 2013 1:22 pm
Re: Xbox360 help
According to this only AVI (and asf) supports 5.1 : http://blogs.msdn.com/b/xboxteam/archiv ... k-faq.aspx
You can't transcode to avi on-the-fly though, and FFmpeg doesn't have WMA Pro encoder. But you can try to do it manually and see if it plays with 5.1 DD.
gmann001
Post Sat Jul 06, 2013 1:38 pm
Re: Xbox360 help
Need a little help in getting the transcode to work properly.
Files with this work without issue on the XBOX360...
Stream #0.0(eng): Video: h264, yuv420p, 624x480 [PAR 1:1 DAR 13:10], 359 kb/s, 23.98 fps, 23.98 tbr, 2997 tbn, 47.95 tbc
Stream #0.1(eng): Audio: aac, 44100 Hz, stereo, s16, 151 kb/s
Files like this, are requiring to be transcoded in order to work...
Stream #0.0(und): Video: h264, yuv420p, 800x336, 2597 kb/s, 23.98 fps, 23.98 tbr, 24k tbn, 47.95 tbc
Stream #0.1(und): Audio: aac, 48000 Hz, 5.1, s16, 446 kb/s
So far I have this in my configuration, however its transcoding all h264/aac files
<Matches container="mp4" vCodec="h264" aCodec="aac" />
How do I adjust this "Matches" so that it only transcodes those files that are "5.1"?
thanks
Post Sat Jul 06, 2013 6:49 pm
Re: Xbox360 help
Not possible currently
gmann001
Post Sun Jul 07, 2013 3:05 pm
Re: Xbox360 help
zip wrote:Not possible currently
Ok, thanks. Is that something that can be requested for a future update? Just the ability to get even more specific in the matching.
Post Sun Jul 07, 2013 5:11 pm
Re: Xbox360 help
