Samsung HT/E3550 "file not supported"
weiyentan
Post Sun Jul 07, 2013 12:39 pm
Hi there,
Just at my parents house setting up Serviio.
It is a Samsung Blueray player HT-3550.
It is able to see the server and list the video but when I click on the video it says file not supported.
I have attached the serviio log to this post.
TIA for any help that you can provide :D
log.zip
(56.74 KiB) Downloaded 390 times
Post Sun Jul 07, 2013 6:32 pm
Re: Samsung HT/E3550 "file not supported"
Log looks ok. Try the latest FFmpeg.
weiyentan
Post Mon Jul 08, 2013 12:28 am
Thanks Zip for the insight. I downloaded the new ffmpeg like you said and replaced it on tthe server. It is 21MB instead of 11MB. Still no dice.
I tried my ipad 3 using air player and it works fine (even on generic mode, which leads me to believe that it is something to do with the profile?
I have forced transcoding when necessary...but not sure where to look after that....
weiyentan
Post Mon Jul 08, 2013 12:30 am
i tried Java 1.7 (but no go) and reverted back../.
weiyentan
Post Mon Jul 08, 2013 12:37 am
i am using the Samsung TV /player (C/D/E) profile settings)
jshaw0304
Post Wed Jul 10, 2013 8:35 am
http://www.samsung.com/us/support/faq/FAQ00047282/51099
The website isn't that current, but relatively accurate for the issue at hand.
If you convert it to a different format I would be willing to bet it would play.
