BDP S790 - Can't play DTS HD?
BloomBloom
Post Sat Jun 29, 2013 12:02 pm
I keep having problems playing DTS HD via serviio, it crashes after a few minutes.
Below is an example of such a file. BD discs with DTS HD work fine.
What do you think?
Thanks!
Unique ID : 249690090257141517555531898527377493992 (0xBBD88FE9FFDB1681A1E20EE010CF8FE8)
Complete name : T:\Incoming\Escape From Planet Earth 2013 BluRay 1080p DTS-HD x264-LEGi0N\Escape From Planet Earth 2013 BluRay 1080p DTS-HD x264-LEGi0N.mkv
Format : Matroska
File size : 8.78 GiB
Duration : 1h 29mn
Overall bit rate : 14.1 Mbps
Encoded date : UTC 2013-05-17 12:57:26
Writing application : mkvmerge v6.2.0 ('Promised Land') built on Apr 28 2013 12:22:01
Writing library : libebml v1.3.0 + libmatroska v1.4.0
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 29mn
Nominal bit rate : 10 000 Kbps
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.272
Writing library : x264 core 132 r2310 76a5c3a
Encoding settings : cabac=1 / ref=5 / deblock=1:1:1 / analyse=0x3:0x113 / me=umh / subme=10 / psy=0 / mixed_ref=0 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=1 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=7 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=80 / rc=2pass / mbtree=1 / bitrate=10000 / ratetol=1.0 / qcomp=0.60 / qpmin=5 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=62500 / vbv_bufsize=78125 / nal_hrd=none / ip_ratio=1.40 / aq=1:0.60
Language : English
Default : Yes
Forced : No
Matrix coefficients : BT.709
Format : DTS
Format profile : MA / Core
Mode : 16
Codec ID : A_DTS
Duration : 1h 29mn
Bit rate mode : Variable
Bit rate : Unknown / 1 509 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossless / Lossy
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : en:00:00:00.000
00:05:00.550 : en:00:05:00.550
00:09:23.271 : en:00:09:23.271
00:14:12.602 : en:00:14:12.602
00:21:21.447 : en:00:21:21.447
00:28:13.859 : en:00:28:13.859
00:32:03.672 : en:00:32:03.672
00:36:05.413 : en:00:36:05.413
00:42:05.606 : en:00:42:05.606
00:46:22.989 : en:00:46:22.989
00:51:34.675 : en:00:51:34.675
00:58:33.510 : en:00:58:33.510
01:03:24.259 : en:01:03:24.259
01:08:47.915 : en:01:08:47.915
01:17:29.728 : en:01:17:29.728
01:21:45.484 : en:01:21:45.484
Post Sun Jun 30, 2013 6:51 am
Re: BDP S790 - Can't play DTS HD?
Which Renderer profile are you using?
BloomBloom
Post Tue Jul 02, 2013 9:55 pm
DenyAll wrote:Which Renderer profile are you using?
BDP- Sx90 (2012)
I presume it creates a higher quality image than if I ran servio directly on my Sony TV KDL-46HX853
Thanks!
BloomBloom
Post Mon Jul 08, 2013 3:22 pm
BDP- Sx90 (2012)
Thanks!
Bump...
akajester
Post Mon Jul 08, 2013 8:00 pm
Serviio uses ffmpeg binaries to transcode. I thought I read that ffmpeg doesn't support DTS-HD yet.
What you can do, is find the command to transcode the file from command prompt, using the serviio included ffmpeg binary and see what error it spits out. That error may tell you that it doesn't support that audio format, or maybe it's something else.
You can download a newer version of the ffmpeg binaries than the ones included with serviio and put them in place for serviio to use and see if the error goes away. I've had that resolve issues in the past, just not with DTS-HD.
I've avoided this by remuxing my bluray mkv's using the DD or DTS track, but ignoring the DTS-HD track. I probably wouldn't notice the loss of audio quality on my setup anyways. :)
Post Tue Jul 09, 2013 2:22 am
At the moment these video's should be passed through without invoking ffmpeg, according to the profile at least. You can check this by seeing if ffmpeg is running in your task list when streaming this file (ensure you check "Show processes from all users").
In any case let's try it - temporarily switch from the Sony BDP-Sx90 (2012) to the Sony BDP-Sx70/SMP-N100 (2010) profile (and press Save :) ) This profile will transcode the DTS audio to AC3 and re-wrap into a mpeg2 container. Video quality is not affected. Give it a try and let us know - this may then help point to the solution.
akajester
Post Tue Jul 09, 2013 3:48 am
I bet sony doesn't allow the DLNA to decode DTS-HD or DTS-MA. Wouldn't that work around HDCP? I bet the firmware is the culprit.
Users browsing this forum: Baidu [Spider] and 15 guests
