Subtitles without transcoding
datroubler
Post Tue Jul 09, 2013 8:33 pm
I hope this question has not already been discussed...
I read this article:
http://www.serviio.org/index.php?option ... icle&id=33
And I guess that I have to transcode the videos to use subtitles.
I have an mkv file with forced subtitles which are not displayed on the TV. The TV itself can encode mkv files. So is it an serviio issue or a tv problem?
The TV is a Samsung UE-42F5570
Thank you for your help!
Post Tue Jul 09, 2013 11:22 pm
Re: Subtitles without transcoding
It should work for Samsungs without transcoding, make sure you have the C/D/E profile selected.
datroubler
Post Wed Jul 10, 2013 5:56 am
Yes I did. I will try it again this evening and report if I could solve the issue.
Post Wed Jul 10, 2013 8:34 am
Otherwise try with external subtitles first.
datroubler
Post Wed Jul 10, 2013 8:46 am
This mkv has no externel but i will try it with an other file if it works
Return to General discussion
