[SOLVED] 2104 DLNA error on PS3 only
GiNB
Post Thu Jul 11, 2013 4:55 am
Hi
Been using Serviio with my Toshiba TV using the Toshiba REGZA profile for about a year now all working fine.
Last weekend my son bought a slim PS3 and Serviio was recognised straightaway and the PS3 profile applied automatically. All worked
perfectly for 3 days.
Last night, seemingly out of nowhere, it took ages to find the Serviio server and when it did it came up with the 2104 DLNA error.
I tried re-booting the Serviio machine but still came up with the same error. When I tried downstairs on the Toshiba has no problems.
Setup is as follows:
Box running Ubuntu 12.04
Latest update of Serviio - and not much else
Wired network (CAT5)
Netgear router - DHCP addressing
Any suggestions would be much appreciated
V.frustrated
Post Thu Jul 11, 2013 8:11 am
Re: 2104 DLNA error on PS3 only
No, never had it (also have a slim), but lots on the web. Seems to be multiple solutions proffered:
  • Change from wireless to cable, or visa versa!
  • Turn off any firewalls and antivirus
  • disable and re-enable the media services in the Network Settings on your PS3
Try the third one first as its easiest. Also check out the PS3 community http://community.us.playstation.com/t5/ ... p/27588555.
GiNB
Post Thu Jul 11, 2013 10:33 pm
Thanks for the response - will post results when I get a chance
GiNB
Post Sat Jul 13, 2013 7:09 am
Suggestion 3 worked..... Cheers DenyAll
