Twitch.tv/Justin.tv
sjsu
Post Sun Jul 07, 2013 9:32 pm
Re: Twitch.tv/Justin.tv
cant you make this to grap from category wise, say
http://www.justin.tv/directory/entertai ... es?lang=en <--movies
so this way atleast when broadcast starts stream again, we dont need to change URL again.
k87
Post Mon Jul 08, 2013 7:34 pm
I just wanted to add that I also was having problems. I got the folders to show up on my ps3 but they said "no titles found." I tried everything and could not get it to work with version 1.21. I did what others have recommended and uninstalled 1.21 and installed 1.1. Everything is working perfectly now. I don't know why 1.21 would not work, just glad I got it up and going with version 1.1.
Tigz
Post Tue Jul 09, 2013 7:02 pm
Oddly, I decided to give that a shot, installing 1.1 serviio and it did the job for me. My stream is now working flawlessly. Not sure what the problem is with 1.21, but its bugged for some people apparently or something.
sjsu
Post Wed Jul 10, 2013 2:09 am
Tigz wrote:Oddly, I decided to give that a shot, installing 1.1 serviio and it did the job for me. My stream is now working flawlessly. Not sure what the problem is with 1.21, but its bugged for some people apparently or something.
definitely bugg on latest 1.2.1.
also this doesnt much help as channel id 's keep changing everytime broadcast restarts, so got to do category wise.
TO SERVIIO ADMIN
idk if it helps, but doing above small things will help in buying pro license even more
jules
Post Wed Jul 10, 2013 11:35 am
wow, now i have to decide whether i want to make zip any more money... ;-)
sjsu
Post Wed Jul 10, 2013 4:39 pm
jules wrote:wow, now i have to decide whether i want to make zip any more money... ;-)
well if do wat i suggested wud help avoid entering the URL everytime..sorry this is annoying
DrBomb
Post Fri Jul 12, 2013 2:48 am
Indeed, downgrading to Serviio 1.1 fixed the plugin, this is weird.
sjsu
Post Fri Jul 12, 2013 6:27 am
DrBomb wrote:Indeed, downgrading to Serviio 1.1 fixed the plugin, this is weird.
indeed it fixes it, thats another issue. I am talking about entering URL everytime broadcasts restarts as it changes channel ID
jules
Post Fri Jul 12, 2013 5:50 pm
that's odd indeed. maybe i'll find some time to investigate what's happening there in a while. for the meantime, i'll add it to the FAQ area in the first post.
pjimmy74
Post Tue Jul 23, 2013 3:32 pm
Is Twitch.tv the same as Justin.tv? I am trying to watch a channel from here http://www.justin.tv/arconai_278#/w/6214550496/171. I did everything right and the folder shows on my sony bluray player but I get the error " there's no playable file". Other streams shows up fine.
jules
Post Tue Jul 23, 2013 4:22 pm
yeah, the plugin works for both sites. the stream works fine for me. try force refreshing. the stream uses h264/aac, does your device support those? does it work in vlc?
pjimmy74
Post Tue Jul 23, 2013 5:44 pm
What's force refreshing? What would I have to do? Yes my device supports h264/aac. Just to make sure; the source type is web resource.
I got sites like xvideos and redtube working. but for the sake of everything, Justin.tv isn't working
pjimmy74
Post Tue Jul 23, 2013 6:30 pm
I just did the force refreshing. Basically downloaded a groovy and an ffmpeg.bat file from here viewtopic.php?f=20&t=6084. Now I'm able to see ilive streams( which wasn't working initially). Justin.tv still not working. I'll continue reading the forum to find out what I'm doing wrong.
jules
Post Tue Jul 23, 2013 8:18 pm
idk man. try out version 1.1 of serviio as suggested in the original post. a clean install of 1.1 with the plugin works fine, any version above 1.1 under linux.
pjimmy74
Post Thu Jul 25, 2013 1:39 am
jules wrote:idk man. try out version 1.1 of serviio as suggested in the original post. a clean install of 1.1 with the plugin works fine, any version above 1.1 under linux.
I did a clean install today of version 1.1 but still not luck with justin.tv to stream. The folders show up but still get the error "There is no playable file". I guess I'll reinstall the latest version back and stick with ilive streaming
kagashin
Post Thu Jul 25, 2013 2:54 am
so i have tried version 3 and 4, both on 1.1 and 1.2.1
this is the error i am getting
2013-07-24 21:44:43,665 DEBUG [OnlineLibraryManager] Resource http://www.twitch.tv/pheenoh not in cache yet, loading it
2013-07-24 21:44:43,665 DEBUG [WebResourceParser] Parsing web resource 'http://www.twitch.tv/pheenoh'
2013-07-24 21:44:43,665 DEBUG [WebResourceParser] Found matching url extractor (twitch.tv) for resource http://www.twitch.tv/pheenoh
2013-07-24 21:44:43,665 DEBUG [FeedItemUrlExtractor] twitch.tv: Starting parsing resource: http://www.twitch.tv/pheenoh
2013-07-24 21:44:44,147 DEBUG [FeedItemUrlExtractor] twitch.tv: Starting extraction of url for item: pheenoh-live [720p]
2013-07-24 21:44:44,152 DEBUG [FeedItemUrlExtractor] twitch.tv: Finished extraction of url: ContentURLContainer [fileType=VIDEO, contentUrl=rtmp://199.9.254.25/app playpath=jtv_q30trHcyySFj0ETS swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.raa016b9e36708548215764309d4c7648e42290fa.swf swfVfy=1 jtv=8f277682aa1d254d9b54954ea608b7395df36d39:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com\",\20\"twitchtv.com\",\20\"twitch.tv\",\20\"newjtv.com\",\20\"jtvnw.net\",\20\"wdtinc.com\",\20\"imapweather.com\",\20\"facebook.com\",\20\"starcrafting.com\"],\20\"streamName\":\20\"jtv_q30trHcyySFj0ETS\",\20\"expiration\":\201374723877,\20\"server\":\20\"video21-1.dfw01\"} live=1, expiresImmediately=true, cacheKey=pheenoh-live [720p], live=true, ]
2013-07-24 21:44:44,152 DEBUG [WebResourceParser] Added resource item 1: 'pheenoh-live [720p]' (rtmp://199.9.254.25/app playpath=jtv_q30trHcyySFj0ETS swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.raa016b9e36708548215764309d4c7648e42290fa.swf swfVfy=1 jtv=8f277682aa1d254d9b54954ea608b7395df36d39:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com\",\20\"twitchtv.com\",\20\"twitch.tv\",\20\"newjtv.com\",\20\"jtvnw.net\",\20\"wdtinc.com\",\20\"imapweather.com\",\20\"facebook.com\",\20\"starcrafting.com\"],\20\"streamName\":\20\"jtv_q30trHcyySFj0ETS\",\20\"expiration\":\201374723877,\20\"server\":\20\"video21-1.dfw01\"} live=1)
2013-07-24 21:44:44,152 DEBUG [FeedItemUrlExtractor] twitch.tv: Starting extraction of url for item: pheenoh-360p [360p]
2013-07-24 21:44:44,152 DEBUG [FeedItemUrlExtractor] twitch.tv: Finished extraction of url: ContentURLContainer [fileType=VIDEO, contentUrl=rtmp://199.9.254.24/app playpath=jtv_N7fW62tvUUbViYic swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.raa016b9e36708548215764309d4c7648e42290fa.swf swfVfy=1 jtv=5c62c997d59e4956335211c5b4ad357a7a7dc479:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com\",\20\"twitchtv.com\",\20\"twitch.tv\",\20\"newjtv.com\",\20\"jtvnw.net\",\20\"wdtinc.com\",\20\"imapweather.com\",\20\"facebook.com\",\20\"starcrafting.com\"],\20\"streamName\":\20\"jtv_N7fW62tvUUbViYic\",\20\"expiration\":\201374723877,\20\"server\":\20\"video20-1.dfw01\"} live=1, expiresImmediately=true, cacheKey=pheenoh-360p [360p], live=true, ]
2013-07-24 21:44:44,154 DEBUG [WebResourceParser] Added resource item 2: 'pheenoh-360p [360p]' (rtmp://199.9.254.24/app playpath=jtv_N7fW62tvUUbViYic swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.raa016b9e36708548215764309d4c7648e42290fa.swf swfVfy=1 jtv=5c62c997d59e4956335211c5b4ad357a7a7dc479:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com\",\20\"twitchtv.com\",\20\"twitch.tv\",\20\"newjtv.com\",\20\"jtvnw.net\",\20\"wdtinc.com\",\20\"imapweather.com\",\20\"facebook.com\",\20\"starcrafting.com\"],\20\"streamName\":\20\"jtv_N7fW62tvUUbViYic\",\20\"expiration\":\201374723877,\20\"server\":\20\"video20-1.dfw01\"} live=1)
2013-07-24 21:44:44,154 DEBUG [OnlineContentCacheDecorator] Stored online content 'http://www.twitch.tv/pheenoh' in the cache (online_feeds), returning it
2013-07-24 21:44:44,154 DEBUG [OnlineLibraryManager] Resource http://www.twitch.tv/pheenoh will expire in the cache on Thu Jul 25 21:44:44 CDT 2013
2013-07-24 21:44:44,154 DEBUG [FeedUpdaterThread] Retrieving information about the video stream 'pheenoh-live [720p]'
2013-07-24 21:44:44,154 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: rtmp://199.9.254.25/app playpath=jtv_q30trHcyySFj0ETS swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.raa016b9e36708548215764309d4c7648e42290fa.swf swfVfy=1 jtv=8f277682aa1d254d9b54954ea608b7395df36d39:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com\",\20\"twitchtv.com\",\20\"twitch.tv\",\20\"newjtv.com\",\20\"jtvnw.net\",\20\"wdtinc.com\",\20\"imapweather.com\",\20\"facebook.com\",\20\"starcrafting.com\"],\20\"streamName\":\20\"jtv_q30trHcyySFj0ETS\",\20\"expiration\":\201374723877,\20\"server\":\20\"video21-1.dfw01\"} live=1
2013-07-24 21:44:44,181 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\lib/ffmpeg.exe -analyzeduration 10000000 -i rtmp://199.9.254.25/app playpath=jtv_q30trHcyySFj0ETS swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.raa016b9e36708548215764309d4c7648e42290fa.swf swfVfy=1 jtv=8f277682aa1d254d9b54954ea608b7395df36d39:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com\",\20\"twitchtv.com\",\20\"twitch.tv\",\20\"newjtv.com\",\20\"jtvnw.net\",\20\"wdtinc.com\",\20\"imapweather.com\",\20\"facebook.com\",\20\"starcrafting.com\"],\20\"streamName\":\20\"jtv_q30trHcyySFj0ETS\",\20\"expiration\":\201374723877,\20\"server\":\20\"video21-1.dfw01\"} live=1
2013-07-24 21:44:44,740 DEBUG [FeedUpdaterThread] Cannot get information about the URL, it might have expired already. Trying again.
2013-07-24 21:44:44,741 DEBUG [FeedItemUrlExtractor] twitch.tv: Starting extraction of url for item: pheenoh-live [720p]
2013-07-24 21:44:44,741 DEBUG [FeedItemUrlExtractor] twitch.tv: Finished extraction of url: ContentURLContainer [fileType=VIDEO, contentUrl=rtmp://199.9.254.25/app playpath=jtv_q30trHcyySFj0ETS swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.raa016b9e36708548215764309d4c7648e42290fa.swf swfVfy=1 jtv=8f277682aa1d254d9b54954ea608b7395df36d39:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com\",\20\"twitchtv.com\",\20\"twitch.tv\",\20\"newjtv.com\",\20\"jtvnw.net\",\20\"wdtinc.com\",\20\"imapweather.com\",\20\"facebook.com\",\20\"starcrafting.com\"],\20\"streamName\":\20\"jtv_q30trHcyySFj0ETS\",\20\"expiration\":\201374723877,\20\"server\":\20\"video21-1.dfw01\"} live=1, expiresImmediately=true, cacheKey=pheenoh-live [720p], live=true, ]
2013-07-24 21:44:44,741 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: rtmp://199.9.254.25/app playpath=jtv_q30trHcyySFj0ETS swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.raa016b9e36708548215764309d4c7648e42290fa.swf swfVfy=1 jtv=8f277682aa1d254d9b54954ea608b7395df36d39:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com\",\20\"twitchtv.com\",\20\"twitch.tv\",\20\"newjtv.com\",\20\"jtvnw.net\",\20\"wdtinc.com\",\20\"imapweather.com\",\20\"facebook.com\",\20\"starcrafting.com\"],\20\"streamName\":\20\"jtv_q30trHcyySFj0ETS\",\20\"expiration\":\201374723877,\20\"server\":\20\"video21-1.dfw01\"} live=1
2013-07-24 21:44:44,741 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\lib/ffmpeg.exe -analyzeduration 10000000 -i rtmp://199.9.254.25/app playpath=jtv_q30trHcyySFj0ETS swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.raa016b9e36708548215764309d4c7648e42290fa.swf swfVfy=1 jtv=8f277682aa1d254d9b54954ea608b7395df36d39:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com\",\20\"twitchtv.com\",\20\"twitch.tv\",\20\"newjtv.com\",\20\"jtvnw.net\",\20\"wdtinc.com\",\20\"imapweather.com\",\20\"facebook.com\",\20\"starcrafting.com\"],\20\"streamName\":\20\"jtv_q30trHcyySFj0ETS\",\20\"expiration\":\201374723877,\20\"server\":\20\"video21-1.dfw01\"} live=1
2013-07-24 21:44:45,079 WARN  [FeedUpdaterThread] Failed to retrieve online item information for rtmp://199.9.254.25/app playpath=jtv_q30trHcyySFj0ETS swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.raa016b9e36708548215764309d4c7648e42290fa.swf swfVfy=1 jtv=8f277682aa1d254d9b54954ea608b7395df36d39:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com\",\20\"twitchtv.com\",\20\"twitch.tv\",\20\"newjtv.com\",\20\"jtvnw.net\",\20\"wdtinc.com\",\20\"imapweather.com\",\20\"facebook.com\",\20\"starcrafting.com\"],\20\"streamName\":\20\"jtv_q30trHcyySFj0ETS\",\20\"expiration\":\201374723877,\20\"server\":\20\"video21-1.dfw01\"} live=1. It might not play.
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:292)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:209)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:102)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.validateMandatoryMetadata(FFmpegMetadataRetriever.java:453)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:94)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:132)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:269)
   ... 2 more
2013-07-24 21:44:45,079 DEBUG [FeedUpdaterThread] Retrieving information about the video stream 'pheenoh-360p [360p]'
2013-07-24 21:44:45,079 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: rtmp://199.9.254.24/app playpath=jtv_N7fW62tvUUbViYic swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.raa016b9e36708548215764309d4c7648e42290fa.swf swfVfy=1 jtv=5c62c997d59e4956335211c5b4ad357a7a7dc479:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com\",\20\"twitchtv.com\",\20\"twitch.tv\",\20\"newjtv.com\",\20\"jtvnw.net\",\20\"wdtinc.com\",\20\"imapweather.com\",\20\"facebook.com\",\20\"starcrafting.com\"],\20\"streamName\":\20\"jtv_N7fW62tvUUbViYic\",\20\"expiration\":\201374723877,\20\"server\":\20\"video20-1.dfw01\"} live=1
2013-07-24 21:44:45,079 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\lib/ffmpeg.exe -analyzeduration 10000000 -i rtmp://199.9.254.24/app playpath=jtv_N7fW62tvUUbViYic swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.raa016b9e36708548215764309d4c7648e42290fa.swf swfVfy=1 jtv=5c62c997d59e4956335211c5b4ad357a7a7dc479:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com\",\20\"twitchtv.com\",\20\"twitch.tv\",\20\"newjtv.com\",\20\"jtvnw.net\",\20\"wdtinc.com\",\20\"imapweather.com\",\20\"facebook.com\",\20\"starcrafting.com\"],\20\"streamName\":\20\"jtv_N7fW62tvUUbViYic\",\20\"expiration\":\201374723877,\20\"server\":\20\"video20-1.dfw01\"} live=1
2013-07-24 21:44:45,456 DEBUG [FeedUpdaterThread] Cannot get information about the URL, it might have expired already. Trying again.
2013-07-24 21:44:45,456 DEBUG [FeedItemUrlExtractor] twitch.tv: Starting extraction of url for item: pheenoh-360p [360p]
2013-07-24 21:44:45,457 DEBUG [FeedItemUrlExtractor] twitch.tv: Finished extraction of url: ContentURLContainer [fileType=VIDEO, contentUrl=rtmp://199.9.254.24/app playpath=jtv_N7fW62tvUUbViYic swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.raa016b9e36708548215764309d4c7648e42290fa.swf swfVfy=1 jtv=5c62c997d59e4956335211c5b4ad357a7a7dc479:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com\",\20\"twitchtv.com\",\20\"twitch.tv\",\20\"newjtv.com\",\20\"jtvnw.net\",\20\"wdtinc.com\",\20\"imapweather.com\",\20\"facebook.com\",\20\"starcrafting.com\"],\20\"streamName\":\20\"jtv_N7fW62tvUUbViYic\",\20\"expiration\":\201374723877,\20\"server\":\20\"video20-1.dfw01\"} live=1, expiresImmediately=true, cacheKey=pheenoh-360p [360p], live=true, ]
2013-07-24 21:44:45,457 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: rtmp://199.9.254.24/app playpath=jtv_N7fW62tvUUbViYic swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.raa016b9e36708548215764309d4c7648e42290fa.swf swfVfy=1 jtv=5c62c997d59e4956335211c5b4ad357a7a7dc479:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com\",\20\"twitchtv.com\",\20\"twitch.tv\",\20\"newjtv.com\",\20\"jtvnw.net\",\20\"wdtinc.com\",\20\"imapweather.com\",\20\"facebook.com\",\20\"starcrafting.com\"],\20\"streamName\":\20\"jtv_N7fW62tvUUbViYic\",\20\"expiration\":\201374723877,\20\"server\":\20\"video20-1.dfw01\"} live=1
2013-07-24 21:44:45,458 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\lib/ffmpeg.exe -analyzeduration 10000000 -i rtmp://199.9.254.24/app playpath=jtv_N7fW62tvUUbViYic swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.raa016b9e36708548215764309d4c7648e42290fa.swf swfVfy=1 jtv=5c62c997d59e4956335211c5b4ad357a7a7dc479:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com\",\20\"twitchtv.com\",\20\"twitch.tv\",\20\"newjtv.com\",\20\"jtvnw.net\",\20\"wdtinc.com\",\20\"imapweather.com\",\20\"facebook.com\",\20\"starcrafting.com\"],\20\"streamName\":\20\"jtv_N7fW62tvUUbViYic\",\20\"expiration\":\201374723877,\20\"server\":\20\"video20-1.dfw01\"} live=1
2013-07-24 21:44:45,789 WARN  [FeedUpdaterThread] Failed to retrieve online item information for rtmp://199.9.254.24/app playpath=jtv_N7fW62tvUUbViYic swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.raa016b9e36708548215764309d4c7648e42290fa.swf swfVfy=1 jtv=5c62c997d59e4956335211c5b4ad357a7a7dc479:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com\",\20\"twitchtv.com\",\20\"twitch.tv\",\20\"newjtv.com\",\20\"jtvnw.net\",\20\"wdtinc.com\",\20\"imapweather.com\",\20\"facebook.com\",\20\"starcrafting.com\"],\20\"streamName\":\20\"jtv_N7fW62tvUUbViYic\",\20\"expiration\":\201374723877,\20\"server\":\20\"video20-1.dfw01\"} live=1. It might not play.
   ... 2 more
jules
Post Thu Jul 25, 2013 10:33 am
the urls that the plugin extracts look fine. can you run this in a command line and give me a version number and build date:
"C:\Program Files\Serviio\lib/ffmpeg.exe" -version
or maybe just substitute the ffmpeg.exe file in the lib folder for one from the first post and try again?
kagashin
Post Thu Jul 25, 2013 11:30 am
c:\Program Files\Serviio\lib>ffmpeg.exe -version
ffmpeg version N-54921-g436616f
built on Jul 24 2013 18:01:37 with gcc 4.7.3 (GCC)
configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avis
ynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable
-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetype
--enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enabl
e-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-lib
opus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspee
x --enable-libtheora --enable-libtwolame --enable-libvo-aacenc --enable-libvo-am
rwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --en
able-libxvid --enable-zlib
libavutil      52. 40.100 / 52. 40.100
libavcodec     55. 19.100 / 55. 19.100
libavformat    55. 12.102 / 55. 12.102
libavdevice    55.  3.100 / 55.  3.100
libavfilter     3. 81.103 /  3. 81.103
libswscale      2.  4.100 /  2.  4.100
libswresample   0. 17.103 /  0. 17.103
jules
Post Thu Jul 25, 2013 12:02 pm
okay, try this: do a force refresh on the channel, go to the log to see the error messages, then copy out the URL like in the following example and run this command line:
ffmpeg -i "rtmp://199.9.254.25/app playpath=jtv_q30trHcyySFj0ETS swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.raa016b9e36708548215764309d4c7648e42290fa.swf swfVfy=1 jtv=8f277682aa1d254d9b54954ea608b7395df36d39:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com\",\20\"twitchtv.com\",\20\"twitch.tv\",\20\"newjtv.com\",\20\"jtvnw.net\",\20\"wdtinc.com\",\20\"imapweather.com\",\20\"facebook.com\",\20\"starcrafting.com\"],\20\"streamName\":\20\"jtv_q30trHcyySFj0ETS\",\20\"expiration\":\201374723877,\20\"server\":\20\"video21-1.dfw01\"} live=1"
see that the "url" starts with "rtmp://" and ends with "live=1". the spaces in between are fine. also confirm that all of the quotation marks(") in between the outermost ones are escaped (have a backspace in front of them).
if it shows you >= a dozen of lines about codec information, ffmpeg is fine. if not, ffmpeg isn't fine.
kagashin
Post Thu Jul 25, 2013 4:13 pm
so i did that and got
c:\Program Files\Serviio\lib>ffmpeg.exe -i "rtmp://199.9.254.12/app playpath=jtv
_ip5CB4UOOorVZJR5 swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.raa0
16b9e36708548215764309d4c7648e42290fa.swf swfVfy=1 jtv=7a3a216fdfd9aaa7c30e634be
44a3a42bd18be1e:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com
,\20\"streamName\":\20\"jtv_ip5CB4UOOorVZJR5\",\20\"expiration\":\201374772049,\
20\"geo_ip\":\20\"67.11.182.115\",\20\"server\":\20\"video8-1.dfw01\"} live=1"
ffmpeg version N-54921-g436616f Copyright (c) 2000-2013 the FFmpeg developers
isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab
le-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetyp
e --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --ena
ble-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-l
ibopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libsp
eex --enable-libtheora --enable-libtwolame --enable-libvo-aacenc --enable-libvo-
amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --
enable-libxvid --enable-zlib
  duration              0.00
  fileSize              0.00
  width                 640.00
  height                360.00
  videocodecid          avc1
  videodatarate         2000.00
  framerate             25.00
  audiocodecid          mp4a
  audiodatarate         128.00
  audiosamplerate       44100.00
  audiosamplesize       16.00
  audiochannels         2.00
  stereo                TRUE
  encoder               Open Broadcaster Software v0.542b
Input #0, flv, from 'rtmp://199.9.254.12/app playpath=jtv_ip5CB4UOOorVZJR5 swfUr
4c7648e42290fa.swf swfVfy=1 jtv=7a3a216fdfd9aaa7c30e634be44a3a42bd18be1e:{"swfDo
mains":\20["justin.tv",\20"jtvx.com",\20"xarth.com",\20"twitchtv.com",\20"twitch
.tv",\20"newjtv.com",\20"jtvnw.net",\20"wdtinc.com",\20"imapweather.com",\20"fac
ebook.com",\20"starcrafting.com"],\20"streamName":\20"jtv_ip5CB4UOOorVZJR5",\20"
expiration":\201374772049,\20"geo_ip":\20"67.11.182.115",\20"server":\20"video8-
1.dfw01"} live=1':
    fileSize        : 0
    audiochannels   : 2
    encoder         : Open Broadcaster Software v0.542b
  Duration: 00:00:00.00, start: 0.000000, bitrate: N/A
    Stream #0:0: Video: h264 (High), yuv420p, 640x360, 2048 kb/s, 1k tbr, 1k tbn
, 2k tbc
    Stream #0:1: Audio: aac, 44100 Hz, stereo, fltp, 131 kb/s
i did have to add the wrapping "s to the outside of it
Return to Available plugins
Users browsing this forum: Baidu [Spider] and 12 guests
