HAHASPORT - A DYNAMIC SPORTS STREAMS WEB RESOURCE
Ohvee
Post Wed May 22, 2013 2:31 am
Re: HAHASPORT - A DYNAMIC SPORTS STREAMS WEB RESOURCE
Hmm, did they change something with the site? I can see it fine in a browser, but it isn't working with serviio (I'm only trying to the hockey page).
The log mentions something about an index out of range error.
Rufus McDufus
Post Sat May 25, 2013 9:43 am
Ohvee wrote:Hmm, did they change something with the site? I can see it fine in a browser, but it isn't working with serviio (I'm only trying to the hockey page).
Not working at all for me either. I'm getting lots of these:
2013-05-25 07:19:44,383 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Unexpected error while invoking plugin (HaHaSport): index is out of range 0..-1 (index = 0)
        at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:58)
        at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:171)
Caused by: java.lang.IndexOutOfBoundsException: index is out of range 0..-1 (index = 0)
        at org.codehaus.groovy.runtime.DefaultGroovyMethods.getAt(DefaultGroovyMethods.java:6202)
        at org.codehaus.groovy.runtime.dgm$310.invoke(Unknown Source)
        at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite$PojoMetaMethodSiteNoUnwrapNoCoerce.invoke(PojoMetaMethodSite.java:271)
        at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite.call(PojoMetaMethodSite.java:53)
        at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116)
        at HaHaSport.extractItems(HaHaSport.groovy:261)
        at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:32)
        at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:29)
        at org.serviio.library.online.PluginExecutionProcessor$1.call(PluginExecutionProcessor.java:50)
        at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
        at java.util.concurrent.FutureTask.run(Unknown Source)
        at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
        at java.lang.Thread.run(Unknown Source)
Lincsguy
Post Sat May 25, 2013 1:52 pm
@Rufus, I get the same
Post Thu May 30, 2013 10:07 pm
Version 31 posted, with many changes and improved execution.
Ohvee
Post Fri May 31, 2013 7:43 pm
Thanks!
_SDK_
Post Sat Jun 01, 2013 3:09 am
Thanks for all the work.
Greetings From Jamaica.
danprice86
Post Sat Jul 13, 2013 4:59 pm
Hi all.
I cannot get a list of 'live now events', I only get a next event thumbnail.
I have tried refreshing, I have tried folders for all sports, only football, and only football with 9estreams.
Any pointers out there?
Thanks!
Post Sat Jul 13, 2013 5:19 pm
They have changed their source streams and the plugin needs an update. I will hopefully release that with Serviio 1.3
danprice86
Post Sat Jul 13, 2013 5:52 pm
Ah, I see... Thanks my man.
nico4gr
Post Mon Aug 12, 2013 5:31 pm
Any news about this plugin now that 1.3 has been released?
Post Tue Aug 13, 2013 3:18 pm
Unfortunately they have implemented various techniques to obsure their streams which I cannot counter, so I will not be able to release an update. Use it for whatever streams continue to work.
xXsamXx1991
Post Mon Nov 04, 2013 1:52 pm
Is it possible to update the plugin if serviio 1.4 will be released or is it impossible to use hahasport with the implemented techniques?
xXsamXx1991
Player: Samsung UE46C5700 | Server: Ubuntu 14.04 LTS
Player: Samsung UE40F5370
Player: Toshiba REGZA 37UL863
Intel UPnP tools | HOWTO: Turn on detailed logging | HowTo: Provide supported formats of a device | HowTo: Provide details of a video file that doesn't play | HowTo: Remove header compression
Previous
Return to Available plugins
