ILIVE - A Video Livestreams Server Collection
Post Thu Jun 27, 2013 2:55 pm
Re: ILIVE - A Video Livestreams Server Collection
You delete a plugin from the same place that you add a plugin.
siriusblack
Post Thu Jun 27, 2013 3:29 pm
Thanks really appreciate jhb50
Will try it when get home from work
Beta Tester
jshg46
Post Thu Jun 27, 2013 5:13 pm
It seems dead for me as well. It acts like it is scanning but the logs tell me error occurred "might not play"
Post Thu Jun 27, 2013 5:37 pm
Site has changed as posted 5 back.
guitman
Post Tue Jul 09, 2013 10:50 pm
Everyone still dead in the water with this one too? Mine was working great until just last week, now no feeds show up. Going to the website through a browser works fine.
npuser
Post Sat Jul 13, 2013 2:10 pm
I am not sure if it's a coincident or what but all ilive streams came right up after I recompile ffmpeg to v2.
Npuser
Post Sat Jul 13, 2013 4:07 pm
Possibly you used the KSV modified librtmp rather than the git version which is used in the windows ffmpeg. If so it supports redirect which I live now reguires.
Xmantium
Post Sun Jul 14, 2013 11:59 am
On my Linux NAS, ive compliled the latest ffmpeg v2.0 with librtmp from git, i got nearly all the streams
Wondering if the KSV patch will show me more streams - theres a easy guide to update it here - http://wiki.xbmc.org/index.php?title=HO ... te_librtmp
Is there a particular stream that uses the the KSV patch?
IndividualLover
Post Sun Jul 14, 2013 1:44 pm
Xmantium wrote:On my Linux NAS, ive compliled the latest ffmpeg v2.0 with librtmp from git, i got nearly all the streams
@Xmantium, can we compile for WD Live? As you know powerpc builds using on this device.
Post Sun Jul 14, 2013 2:12 pm
jhb50 wrote:Possibly you used the KSV modified librtmp rather than the git version which is used in the windows ffmpeg. If so it supports redirect which I live now reguires.
It looks like they changed the link again so redirect is not required now.
guitman
Post Mon Jul 15, 2013 5:40 pm
Is there a recommendation to get it back to working on my OSX box? I have not modified anything outside of the default Serviio install. Do I need to do something with ffmpeg to get iLive to work again?
guitman
Post Mon Jul 15, 2013 10:08 pm
Go figure, its back. Cool.
jshg46
Post Thu Sep 12, 2013 3:58 pm
Anyone seeing any problems out of this plugin today? I cant get videos to play from the site and sometimes it wont search the site for updated content.
Post Thu Sep 12, 2013 5:28 pm
They have locked them up.
jshg46
Post Thu Sep 12, 2013 6:46 pm
Thanks for the reply. I figured it had to be something since my cbs plugins are still working.
pjimmy74
Post Sun Oct 20, 2013 11:46 pm
Is anyone having issues streaming from ilive.to? Mine stopped working and I can't figure what the problem is. Channels are still streaming online on my pc so the problem is not that they're offline. Ilive folders show up on my DLNA device but there are no channels.
pjimmy74
Post Tue Oct 22, 2013 8:39 pm
jhb50 wrote:http://forum.serviio.org/viewtopic.php?f=20&t=6086&view=unread&sid=604052930d33252d597991cdcc54acc8#p78311
I did all that. It was working fine until about 3 weeks ago.
AlVal
Post Sat Oct 26, 2013 3:20 pm
2013-10-26 15:54:14,140 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://ny.iguide.to/edge playpath=2byvy55uocgnct8 swfurl=http://player.ilive.to/secure_player_ilive_z.swf pageurl=http://www.ilive.to live=1. It might not play.
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:320)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:237)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:116)
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateMandatoryMetadata(FFmpegMetadataRetriever.java:454)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:97)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:135)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:297)
... 2 more
MAX_IQ
Post Sat Oct 26, 2013 4:23 pm
to play ilive.to channels you need a token, so the right stream should look like that
" rtmp://ny.iguide.to/edge playpath=2byvy55uocgnct8 swfurl=http://player.ilive.to/secure_player_ilive_z.swf pageurl=http://www.ilive.to token=******** live=1
Ilive.to changes the token periodically, it would be great if we can change it manually in the plugin
Return to Available plugins
Users browsing this forum: Google [Bot] and 34 guests
