Movie names not showing full title
jwajer
Post Fri Jul 12, 2013 10:41 am
I tested Serviio and found I liked most of what I saw. The problem that prevents me from using it is the fact that the title of my movies show up wrong. Most other programs I tested used the file name for ex. "X-Men United" or "X-Men - First Class". But Serviio shows up 5 titles of "X-Men" so I cannot tell which movie is which. I have several movies that are a series based and they all appear that way. The feature I like is the listing by picking the letter say "A" and seeing all the movies starting with A but the title problem makes that useless for me. Is there a setting to fix this? If not can you add an option to use the movie file titles. FYI...All the movies are MP4.
Post Fri Jul 12, 2013 1:00 pm
Re: Movie names not showing full title
they were probably not matched probably on themoviedb.org. What are the file names?
jwajer
Post Fri Jul 19, 2013 12:31 pm
All the X-Men movies, All the Tales from the crypt, All the Star Trek Movies, All the Alien movies, Basically all the ones I have that have more than one. Is there any way to use the file names or the tags in the movie files for the list? if not might be a good option to consider.
Post Mon Jul 22, 2013 11:46 am
This should help you name the files so they are recognized: http://wiki.serviio.org/doku.php?id=filebot
Users browsing this forum: Baidu [Spider] and 72 guests
