Maximum number of files
Darats
Post Sun Jan 16, 2011 5:06 pm
I got a Samasung HT-C5550, and everything works fine with Serviio but one thing:
I can't have more than 1000 files displayed on my HomeCinema. I have around 3000 files in the cathegory "Electronic" for example, if I choose this cathegory it only displays the first 1000 files.
It is quite a problem if I want to play randomly all the files of a cathegory.
I've also found on a log file : maxObj=1000, so is it a Sarviio limitation, and if yes could it be changed ? Or is it a limitation from my Home cinema device ?
Anothr question: I've already asked some questions on the forum about how to play randomly the entire library of audio fles. Someone told me that it will be implemented on the futur 0.5 version, but how will it work ? I mean, will I have the same problem of being limited to 1000 files ?
Post Sun Jan 16, 2011 5:24 pm
Re: Maximum number of files
It's the device limitation.
The random category in 0.5 I think gives back 100, but I haven't tested it myself properly and it might just work with 'unlimited' results - maybe depends on the device.
Darats
Post Sun Jan 16, 2011 5:38 pm
Ok, and do you think there is a way to find another method to randomly play an entire library even if there is this 1000 songs limit ?
Post Sun Jan 16, 2011 6:16 pm
Not sure, give 0.5 a go when it's out and then we'll see.
Just out of curiosity, listening to 1000 songs would take you like 4000 minutes ... you don't sleep? :-)
Darats
Post Mon Jan 17, 2011 10:06 am
lol, of course I sleep...
I just would like to be able to use "random play" on my entire library, not only on the first 1000 songs.
Post Mon Jan 17, 2011 10:27 am
It'll get random 100 from your entire library every time you select the category.
Darats
Post Mon Jan 17, 2011 6:38 pm
Ok, so I think that will solve my problem. Nice job, can't wait the release !
tombert
Post Thu Jan 20, 2011 6:46 pm
I dont want to offend zip ... but for Audio you might want to look at other DLNA streamers which have better support for large libraries ... (mine costs ~30$)
... but: for Video serviio ist the best :!:
Darats
Post Mon Jan 24, 2011 7:45 pm
If it is possible, could send me a private message with the name of this other DLNA server ? Or post it here if Zip is OK.
By the way I tried the new "Random" feature of Serviio, and actually it just choose the first 100 songs of my library (the one with titles beginning with (.[ or numbers). So did I do something wrong ? Even with a forced refresh of the library it doesn't change.
Post Mon Jan 24, 2011 9:20 pm
Darats wrote:By the way I tried the new "Random" feature of Serviio, and actually it just choose the first 100 songs of my library
You're right, it's a bug.
Darats
Post Mon Jan 24, 2011 9:33 pm
All right, so I will wait for the 0.5.1 ^^
tombert
Post Tue Jan 25, 2011 7:48 am
send a PM
denony
Post Fri Mar 23, 2012 7:13 pm
Petr wrote:You're right, it's a bug.
Hello Petr,
I've just tried Seviio 0.6.2 (Windows) with my UPnP Network Audio Player (Marantz NA7004), and the "Random" playlist is limited to 100 songs. Is there a way to increase this limit ?
Thank you,
Regards,
Laurent
Post Sat Mar 24, 2012 7:01 pm
not at the moment
Users browsing this forum: No registered users and 58 guests
