Embedded subtitle support in MP4 files
Sam___D
Post Wed Jul 17, 2013 1:06 pm
Hi
I'm using Serviio on Windows Server 2008 R2 to stream files to a Philips TV, a PlayStation 3 and a bunch of Android devices with BubbleUPNP and MX Player.
All my video files are .mp4 files with a H264 video stream (720p or 1080p), an AAC audio stream and embedded subtitles. The files are encoded with the latest stable version of Handbrake and they work fine if I play them directly with VLC for Windows or MX Player for Android. There is always a button to enable subtitles if they aren't enabled (depends on the language) automatically.
But when I use Serviio I never see subtitles. Not on my Philips TV, neither on my PS3 and neither on my Android devices. All these devices have buttons to enable subtitles but they're always greyed out. What should I change in Serviio's settings to enable subtitles? The subtitles are in English or in Dutch ("Nederlands").
Post Wed Jul 17, 2013 6:21 pm
Re: Embedded subtitle support in MP4 files
Depends on the renderer. None of these probably support embedded subtitles.
Enable embedded subtitles in the console. It will then serve the subtitles as external source. The MX player might support that. the other two will need you to enable Burned-in subtitles, which will cause all your file to be transcoded.
Sam___D
Post Tue Jul 23, 2013 3:04 pm
Okay, so I included a screenshot of my current settings in this post. Now they work on Android (with BubbleUPNP and MX Player). My PlayStation 3 still doesn't give me the option to enable them.
I couldn't test with my Philips TV due to another problem. I bought a WD My Net N900 router and added it to my network as an access point. Now my Philips TV can only see the N900's built-in media server and not Serviio.
Post Tue Jul 23, 2013 10:52 pm
You need to enable the third option (burned in subtitles) for the PS3 and philips devices to see any subs.
Sam___D
Post Wed Jul 24, 2013 3:23 pm
I still don't see subtitles on my PS3 with these settings.
I've tested this with a video file with a size of 2,35 GB and a duration of 02:16:17.
The server has 4 GB RAM, Intel Core 2 Quad Q9300 and Windows Server 2008 R2.
Post Sat Jul 27, 2013 12:06 pm
post ffmpeg -i for the file
Sam___D
Post Sat Jul 27, 2013 1:23 pm
C:\Program Files\Serviio\lib>ffmpeg.exe -i "I:\media\films\Amazing Spiderman (20
12)\The.amazing.spiderman.2012.1080p.brrip.x264.yify_c_1.mp4"
ffmpeg version 1.1.1 Copyright (c) 2000-2013 the FFmpeg developers
  built on Feb  5 2013 21:59:54 with gcc 4.7.2 (GCC)
p --enable-fontconfig --enable-libfreetype --enable-zlib --extra-libs='-lrtmp -l
polarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-
runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-
mingw32- --pkg-config=pkg-config
  libavutil      52. 13.100 / 52. 13.100
  libavcodec     54. 86.100 / 54. 86.100
  libavformat    54. 59.106 / 54. 59.106
  libavdevice    54.  3.102 / 54.  3.102
  libavfilter     3. 32.100 /  3. 32.100
  libswscale      2.  1.103 /  2.  1.103
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'I:\media\films\Amazing Spiderman (2012)
\The.amazing.spiderman.2012.1080p.brrip.x264.yify_c_1.mp4':
    major_brand     : mp42
    minor_version   : 0
    creation_time   : 2013-05-26 13:32:45
    encoder         : HandBrake 0.9.8 2012071700
  Duration: 02:16:17.42, start: 0.000000, bitrate: 2472 kb/s
    Stream #0:0(und): Video: h264 (Main) (avc1 / 0x31637661), yuv420p, 1916x802
[SAR 1:1 DAR 958:401], 2307 kb/s, 23.98 fps, 23.98 tbr, 90k tbn, 180k tbc
    Stream #0:1(eng): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 15
9 kb/s
    Stream #0:2(eng): Subtitle: mov_text (tx3g / 0x67337874)
Post Sun Jul 28, 2013 10:53 am
mov_text subtitles are not supported. I will have a look at how difficult it'd be to ad them.
Sam___D
Post Sun Jul 28, 2013 12:14 pm
It seems to be the default setting in Handbrake. Do you happen to know how to change that in Handbrake to a supported format?
Post Mon Jul 29, 2013 12:10 pm
No, it'd be something like srt.
I've implemented mov_text for 1.3 yesterday though, so you should get it in a couple of weeks
Sam___D
Post Mon Jul 29, 2013 1:09 pm
Thanks, when it works on all my devices I'll buy the pro version ;)
Users browsing this forum: Baidu [Spider] and 12 guests
