Check if subtitels are working
nobs
Post Fri Jul 26, 2013 7:51 pm
Hello
Is there a way to check if Serviio recognize the srt file and play the subtitles?
because sometimes he plays the subtitles
and sometimes not
and i don't know why.
I think the settings I use are ok, because as mentioned before sometimes it works
(using LG Blueray /LG TV as main device)
Post Sat Jul 27, 2013 12:17 pm
Re: Check if subtitels are working
for LG it sends the file as it is, so it's up to the LG to decide if it's supported. look at the wiki, there is a tool to fix srt files, which might help you
nobs
Post Sun Jul 28, 2013 8:27 pm
Hi
thanks for the response
but SRTWiz didn't changed a thing in the srt file
(old and new are 100 % the same)
The problem is, I have no Idea if serviio is "recognizing" the file
Post Mon Jul 29, 2013 6:31 pm
if you enable detailed log and play the file, you should see if it found the subtitle file
Users browsing this forum: Google [Bot] and 43 guests
