Profile for Chaneru
lillypad_33
Post Sun Jul 28, 2013 8:09 pm
Re: Profile for Chaneru
zip wrote:
chaneru wrote:Is there any way to throttle ffmpeg besides cutting down on the number of cores ?
On the transcoding tab, uncheck Best video quality.
Hey guys,
I'm using Chaneru as well, and it looks like I need version 1.3 in order to stream properly.
Is there a time frame for when this beta will be available?
I tried the profile that somebody else had posted in here, and of course it didn't work in 1.2.1
Post Sun Jul 28, 2013 10:23 pm
Hey guys,
I have been assisting Chaneru with testing, and I have the Serviio 1.3 beta. However, Mike has not yet released the version of Chaneru necessary to work with 1.3. He told me several days ago he is getting close to releasing it, but right now he's the only person that have Chaneru/Roku working with Serviio. The major issue has been with transcoding, and it sounds like he has it pretty well figured out. As far as Serviio 1.3, I think Petr is getting close, but I expect at least one more beta version to test before he goes public with it. This is all supposition on my part, as I am only one of his many beta testers.
lillypad_33
Post Sun Jul 28, 2013 11:44 pm
I have been assisting Chaneru with testing, and I have the Serviio 1.3 beta. However, Mike has not yet released the version of Chaneru necessary to work with 1.3. He told me several days ago he is getting close to releasing it, but right now he's the only person that have Chaneru/Roku working with Serviio. The major issue has been with transcoding, and it sounds like he has it pretty well figured out. As far as Serviio 1.3, I think Petr is getting close, but I expect at least one more beta version to test before he goes public with it. This is all supposition on my part, as I am only one of his many beta testers.[/quote]
Hopefully I can figure out how to become a beta tester. I've got a decent network set up here for testing.
It includes 2 diferent dlna dvd players, a roku, and a sony tv.
From the sounds of it, Chaneru 2.10 will be out shortly... I guess my best bet is to sit tight for a little bit.
Post Mon Jul 29, 2013 12:30 pm
lillypad_33 wrote:Hopefully I can figure out how to become a beta tester. I've got a decent network set up here for testing.
Just send Zip a private message asking to join the beta list, and give him some justification. Your varied network assets would be one good reason.
chaneru
Post Fri Aug 02, 2013 1:48 pm
Chaneru 2.0.10
Added support for on the fly transcoding for Serviio version 1.3 which is currently in beta testing. Here are the links to the Serviio profiles for Chaneru.
http://www.chaneru.com/UPnP/Serviio%201.2%20Profile.txt - 1.2
http://www.chaneru.com/UPnP/Serviio%201.3%20Profile.txt - 1.3 transcoding
You need to update Serviio’s profiles.xml file by placing my change just before the “</Profiles>” line at the end of the file.
You can locate the file on a Mac by right clicking the Serviio application (not Serviio-Console) and selecting “Show Package Contents”. It is contained in the folder “Contents/Resources/Java/config”. It is in “C:/Program Files/Serviio/config” on Windows.
You may have to limit the video bit rate, ex: (maxVBitrate="2000") if Roku rebuffers using your network. You could also try unchecking “Produce the best video quality” in Serviio’s options. I would also suggest running with the lowest number of cores that can keep up with the Roku’s transfers. These options, you just have to Play with to find what works for you.
You can tell if your CPU is keeping up by pausing a movie and there should be a number of minutes on the right of the progress bar. This is how much Serviio is ahead in the transcode.
These profiles are a good starting point.
If you see or find something that would be better, let me know here or email support@chaneru.com
Zip, THANKS for adding the code for HLS !
chaneru
Post Wed Aug 07, 2013 5:09 pm
Meta data returned ?
A few questions:
1. The video has an extention of MOV but Serviio is reporting MP4. "dc:title" has a type of mov.
2. "dlna:profileID" is reported as "JPEG_TN". Shouldn't this be a video type ?
Log of video item with Serviio Data
11:53:19.703  .  width: 1280
11:53:19.715  .  info: True
11:53:19.730  .  upnp:rating: Unknown
11:53:19.739  .  icon: tmp:/Theme/Default/video.png
11:53:19.750  .  protocol: roArray
11:53:19.761     .  .protocol count 2
11:53:19.774     .  [0] roAssociativeArray
11:53:19.786        .  mode: http-get
11:53:19.796        .  protocolInfo: http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_HD_720p_AAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000
11:53:19.807        .  pseudo: AVC_MP4_MP_HD_720p_AAC
11:53:19.819        .  url: http://192.168.1.2:8895/resource/142/MEDIA_ITEM/AVC_MP4_MP_HD_720p_AAC-0/ORIGINAL
11:53:19.831        .  mime: video/mp4
11:53:19.842     .  [1] roAssociativeArray
11:53:19.853        .  mode: http-get
11:53:19.863        .  protocolInfo: http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000
11:53:19.875        .  pseudo: JPEG_TN
11:53:19.889        .  url: http://192.168.1.2:8895/resource/142/COVER_IMAGE
11:53:19.899        .  mime: image/jpeg
11:53:19.911  .  upnp:genre: Unknown
11:53:19.922  .  dlna:profileID: JPEG_TN
11:53:19.932  .  dc:title: 2012-04-27 22.45.36.mov
11:53:19.942  .  res:resolution: 1280x720
11:53:19.954  .  path: http://192.168.1.2:8895/resource/142/MEDIA_ITEM/AVC_MP4_MP_HD_720p_AAC-0/ORIGINAL
11:53:19.965  .  height: 720
11:53:19.975  .  upnp:albumArtURI: http://192.168.1.2:8895/resource/142/COVER_IMAGE
11:53:19.986  .  dc:date: 2012-04-27
11:53:19.996  .  restricted: 1
11:53:20.007  .  seconds: 3
11:53:20.019  .  upnp:class: object.item.videoItem
11:53:20.029  .  bar: 54 Videos
11:53:20.040  .  refresh: False
11:53:20.051  .  res:duration: 0:00:03.000
11:53:20.062  .  dev_id: 3
11:53:20.072  .  upnp:icon: http://192.168.1.2:8895/resource/142/COVER_IMAGE
11:53:20.087  .  res:bitrate: 1335625
11:53:20.098  .  url: V_F^FOL_R1V_F^FOL_R1$F5/
11:53:20.108  .  title: 2012-04-27 22.45.36
11:53:20.120  .  id: V_F^FOL_R1$F5$MI142
11:53:20.130  .  type: 2
11:53:20.140  .  res:size: 5303346
11:53:20.151  .  parentID: V_F^FOL_R1$F5
11:53:20.161  .  mime: video/mp4
Post Wed Aug 07, 2013 6:19 pm
mp4 and mov are basically one and the same.
the _TN profile is only related to the thumbnail resource (the other resource being the video)
chaneru
Post Sat Aug 10, 2013 3:33 pm
DC:TITLE has the file type appended to it BUT only when the item comes from the "Folders" link.
Would it be possible to ADD the file extension to dc:title or provide another meta tag for the original type.
This really comes in handy for the user to know the original file type when transcoding a movie.
chaneru
Post Tue Aug 13, 2013 1:26 am
I have multiple MKV files in a folder. Serviio 1.3 transcoding is NOT selected for the files that are HD. When the HD files are played, I get an HTTP error 500. The ones that are not HD appear to play.
Is there something I need to do for Chaneru's profile and MKV HD files ?
Post Tue Aug 13, 2013 11:42 am
post log of when the error happens
chaneru
Post Tue Aug 13, 2013 2:09 pm
Hope this helps !
2013-08-13 08:40:42,673 DEBUG [ServiioHttpService] Incoming request from /192.168.1.12:37284: GET /resource/596/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.1, headers = [Accept: video/x-matroska,Connection: close,Host: 192.168.1.2:8895,User-Agent: Roku/DVP-3.1 (013.01E01182A)]]
2013-08-13 08:40:42,674 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.12
2013-08-13 08:40:42,675 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.12
2013-08-13 08:40:42,675 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.12, Profile=Chaneru'
2013-08-13 08:40:42,676 DEBUG [ResourceDeliveryProcessor] Request for resource 596 and type 'MEDIA_ITEM' received
2013-08-13 08:40:42,676 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 596 (local)
2013-08-13 08:40:42,676 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 596)
2013-08-13 08:40:42,683 DEBUG [VideoDAOImpl] Reading a Video (id = 596)
2013-08-13 08:40:42,683 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 596, format MATROSKA and profile Chaneru
2013-08-13 08:40:42,683 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Birds_1080.mkv
2013-08-13 08:40:42,684 WARN  [VideoDeliveryEngine] Cannot get media info for transcoded file Birds_1080.mkv: AppleHttp video file Birds_1080.mkv does not match any supported DLNA profile
2013-08-13 08:40:42,684 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: null
   at org.serviio.delivery.resource.AbstractDeliveryEngine.findMediaInfoForFileProfile(AbstractDeliveryEngine.java:285)
   at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedMediaInfoForVersion(AbstractTranscodingDeliveryEngine.java:156)
I removed and reloaded my files to get the database rebuilt
2013-08-13 08:59:21,558 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/jim/Movies/A MKV
2013-08-13 08:59:21,558 DEBUG [LibraryAdditionsCheckerThread] Found file 'Birds_1080.mkv', checking if it's already in the Library
2013-08-13 08:59:21,558 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item /Users/jim/Movies/A MKV/Birds_1080.mkv
2013-08-13 08:59:21,558 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /Users/jim/Movies/A MKV/Birds_1080.mkv, ignore case: false
2013-08-13 08:59:21,558 DEBUG [MediaItemDAOImpl] Media item /Users/jim/Movies/A MKV/Birds_1080.mkv doesn't exist in DB yet
2013-08-13 08:59:21,558 DEBUG [LibraryAdditionsCheckerThread] File not in Library, will add it
2013-08-13 08:59:21,558 DEBUG [VideoExtractionStrategy] Extracting metadata of video file: /Users/jim/Movies/A MKV/Birds_1080.mkv
2013-08-13 08:59:21,558 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: /Users/jim/Movies/A MKV/Birds_1080.mkv
2013-08-13 08:59:21,558 DEBUG [ProcessExecutor] Starting /Users/jim/Serviio/Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg -i /Users/jim/Movies/A MKV/Birds_1080.mkv
2013-08-13 08:59:21,933 DEBUG [FFmpegMetadataRetriever] Retrieving H264 profile/level for file '/Users/jim/Movies/A MKV/Birds_1080.mkv'
2013-08-13 08:59:21,933 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve H264 header for file: /Users/jim/Movies/A MKV/Birds_1080.mkv
2013-08-13 08:59:21,933 DEBUG [ProcessExecutor] Starting /Users/jim/Serviio/Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg -i /Users/jim/Movies/A MKV/Birds_1080.mkv -frames:v 1 -c:v copy -f h264 -bsf:v h264_mp4toannexb -an pipe:
2013-08-13 08:59:22,180 DEBUG [FFmpegMetadataRetriever] File '/Users/jim/Movies/A MKV/Birds_1080.mkv' has H264 profile HIGH, levels [{H=4.1, RF=4}] and 4 ref frames
2013-08-13 08:59:22,180 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve thumbnail for file: /Users/jim/Movies/A MKV/Birds_1080.mkv
2013-08-13 08:59:22,180 DEBUG [ProcessExecutor] Starting /Users/jim/Serviio/Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg -threads 2 -ss 11 -i /Users/jim/Movies/A MKV/Birds_1080.mkv -an -frames:v 1 -f image2 pipe:
2013-08-13 08:59:22,908 DEBUG [AbstractCDSLibraryIndexingListener] Library updated, notifying CDS
2013-08-13 08:59:22,909 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-08-13 08:59:22,909 DEBUG [LocalContentCacheDecorator] Cleared cache (local_default)
2013-08-13 08:59:35,284 DEBUG [LibraryManager] Metadata found via extractor EMBEDDED: VideoMetadata [title=Birds_1080, filePath=/Users/jim/Movies/A MKV/Birds_1080.mkv, fileSize=114918832, audioBitrate=null, audioCodec=null, audioStreamIndex=null, bitrate=39859, channels=null, container=MATROSKA, contentType=UNKNOWN, duration=23, episodeNumber=null, fps=23.976, frequency=null, h264Levels={H=4.1, RF=4}, h264Profile=HIGH, ftyp=null, height=1072, seasonNumber=null, seriesName=null, timestampType=null, videoBitrate=null, videoCodec=H264, videoFourCC=null, videoStreamIndex=0, width=1920, embeddedSubtitles=[]]
2013-08-13 08:59:35,301 DEBUG [TheMovieDBSourceAdaptor] Searching for movie 'birds'  (language: en)
2013-08-13 08:59:35,564 DEBUG [TheMovieDBSourceAdaptor] Found 68 matches
2013-08-13 08:59:35,564 DEBUG [TheMovieDBSourceAdaptor] Searching for movie 'a mkv'  (language: en)
2013-08-13 08:59:35,703 DEBUG [TheMovieDBSourceAdaptor] Found 0 matches
2013-08-13 08:59:35,703 DEBUG [TheMovieDBSourceAdaptor] Found a suitable movie match, id = 125601
2013-08-13 08:59:35,703 DEBUG [TheMovieDBSourceAdaptor] Retrieving details of movie (movieId = 125601, language = en)
2013-08-13 08:59:35,947 DEBUG [LibraryManager] Metadata found via extractor ONLINE_VIDEO_SOURCES: VideoMetadata [title=Birds, filePath=null, fileSize=0, audioBitrate=null, audioCodec=null, audioStreamIndex=null, bitrate=null, channels=null, container=null, contentType=MOVIE, duration=null, episodeNumber=null, fps=null, frequency=null, h264Levels={}, h264Profile=null, ftyp=null, height=null, seasonNumber=null, seriesName=null, timestampType=null, videoBitrate=null, videoCodec=null, videoFourCC=null, videoStreamIndex=null, width=null, embeddedSubtitles=[]]
2013-08-13 08:59:35,947 DEBUG [VideoService] Adding video into database: Birds
2013-08-13 08:59:35,947 DEBUG [FolderDAOImpl] Looking for folder hierarchy A MKV
2013-08-13 08:59:35,954 DEBUG [GenreDAOImpl] Reading a Genre (name = Unknown)
2013-08-13 08:59:35,955 DEBUG [GenreService] Genre Unknown found
2013-08-13 08:59:35,955 DEBUG [CoverImageService] Resizing and storing cover art image for max resolution of 320x320
2013-08-13 08:59:35,955 DEBUG [ImageUtils] Starting image resize, size = 247029 bytes
2013-08-13 08:59:36,016 DEBUG [ImageUtils] Returning resized image, size = 27461 bytes
2013-08-13 08:59:36,016 DEBUG [CoverImageService] Image successfully resized
2013-08-13 08:59:36,016 DEBUG [CoverImageService] Resizing and storing cover art image for max resolution of 160x160
2013-08-13 08:59:36,016 DEBUG [ImageUtils] Starting image resize, size = 27461 bytes
2013-08-13 08:59:36,021 DEBUG [ImageUtils] Returning resized image, size = 6371 bytes
2013-08-13 08:59:36,021 DEBUG [CoverImageService] Image successfully resized
2013-08-13 08:59:36,021 DEBUG [CoverImageDAOImpl] Creating a new ImageCover (length = 6371)
2013-08-13 08:59:36,024 DEBUG [VideoDAOImpl] Creating a new Video (title = Birds)
2013-08-13 08:59:36,025 DEBUG [PersonDAOImpl] Adding a Person Frans Zwartjes to media item 756 as DIRECTOR
2013-08-13 08:59:36,025 DEBUG [PersonDAOImpl] Reading a Person (name = Frans Zwartjes)
2013-08-13 08:59:36,026 DEBUG [PersonDAOImpl] Creating a new Person (name = Frans Zwartjes)
2013-08-13 08:59:36,026 DEBUG [PersonDAOImpl] Checking if person 2386 has a role DIRECTOR for media item 756
2013-08-13 08:59:36,027 DEBUG [PersonDAOImpl] Adding a Person Unknown to media item 756 as PRODUCER
2013-08-13 08:59:36,027 DEBUG [PersonDAOImpl] Reading a Person (name = Unknown)
2013-08-13 08:59:36,028 DEBUG [PersonDAOImpl] Checking if person 2122 has a role PRODUCER for media item 756
2013-08-13 08:59:36,028 DEBUG [PersonDAOImpl] Adding a Person Unknown to media item 756 as ACTOR
2013-08-13 08:59:36,028 DEBUG [PersonDAOImpl] Reading a Person (name = Unknown)
2013-08-13 08:59:36,029 DEBUG [PersonDAOImpl] Checking if person 2122 has a role ACTOR for media item 756
2013-08-13 08:59:36,029 DEBUG [MetadataDescriptorDAOImpl] Creating a new MetadataDescriptor (type = ONLINE_VIDEO_SOURCES, mediaItemId = 756)
2013-08-13 08:59:36,030 DEBUG [MetadataDescriptorDAOImpl] Creating a new MetadataDescriptor (type = EMBEDDED, mediaItemId = 756)
2013-08-13 08:59:36,031 DEBUG [CoverImageDAOImpl] Reading a CoverImage for folder (id = 40)
2013-08-13 08:59:36,032 DEBUG [SearchIndexer] Adding term 'Birds' to search index
2013-08-13 08:59:36,055 DEBUG [SearchIndexer] Adding term 'Birds_1080.mkv' to search index
2013-08-13 08:59:36,063 DEBUG [SearchIndexer] Adding term 'A MKV' to search index
2013-08-13 08:59:36,215 INFO  [LibraryAdditionsCheckerThread] Added file 'Birds_1080.mkv' (title: Birds) to Library
Post Tue Aug 13, 2013 2:42 pm
It looks like transcoding is on in Serviio, but the renderer is asking for non-trancoded MATROSKA file?
Are you using the above posted profile? (1.3 + transcoding)
chaneru
Post Tue Aug 13, 2013 3:27 pm
Yes, Chaneru profile for 1.3 with transcoding.
Failed Video Soap data
<?xml version="1.0" encoding="utf-8" ?><SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><SOAP-ENV:Body><u:BrowseResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><Result>&lt;?xml version="1.0" encoding="UTF-8" standalone="no"?&gt;&lt;DIDL-Lite xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/"&gt;&lt;item id="V_F^FOL_R1$F33$MI596" parentID="V_F^FOL_R1$F33" restricted="1"&gt;&lt;dc:title&gt;Birds_1080.mkv&lt;/dc:title&gt;&lt;upnp:class&gt;object.item.videoItem&lt;/upnp:class&gt;&lt;upnp:albumArtURI dlna:profileID="JPEG_TN"&gt;http://192.168.1.2:8895/resource/1268/COVER_IMAGE&lt;/upnp:albumArtURI&gt;&lt;upnp:icon&gt;http://192.168.1.2:8895/resource/1268/COVER_IMAGE&lt;/upnp:icon&gt;&lt;dc:date&gt;2011-04-28&lt;/dc:date&gt;&lt;upnp:genre&gt;Unknown&lt;/upnp:genre&gt;&lt;dc:description&gt;A woman plays with a bird as the camera's gaze is drawn to her legs.&lt;/dc:description&gt;&lt;upnp:rating&gt;Unknown&lt;/upnp:rating&gt;&lt;res bitrate="4982375" duration="0:00:23.000" protocolInfo="http-get:*:video/x-matroska:DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000" resolution="1920x1072" size="114918832"&gt;http://192.168.1.2:8895/resource/596/MEDIA_ITEM/MATROSKA-0/ORIGINAL&lt;/res&gt;&lt;res protocolInfo="http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000" resolution="160x89"&gt;http://192.168.1.2:8895/resource/1268/COVER_IMAGE&lt;/res&gt;&lt;/item&gt;&lt;/DIDL-Lite&gt;</Result><NumberReturned>1</NumberReturned><TotalMatches>1</TotalMatches><UpdateID>2</UpdateID></u:BrowseResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
My Decode
08:40:52.034 * ---------------- Video Item ---------------- roAssociativeArray
08:40:52.045  .  width: 1920
08:40:52.056  .  info: True
08:40:52.066  .  upnp:rating: Unknown
08:40:52.078  .  icon: tmp:/Theme/Default/video.png
08:40:52.088  .  protocol: roArray
08:40:52.101     .  .protocol count 2
08:40:52.113     .  [0] roAssociativeArray
08:40:52.125        .  mode: http-get
08:40:52.134        .  protocolInfo: http-get:*:video/x-matroska:DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000
08:40:52.145        .  pseudo: MATROSKA
08:40:52.156        .  url: http://192.168.1.2:8895/resource/596/MEDIA_ITEM/MATROSKA-0/ORIGINAL
08:40:52.167        .  mime: video/x-matroska
08:40:52.184     .  [1] roAssociativeArray
08:40:52.198        .  mode: http-get
08:40:52.209        .  protocolInfo: http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000
08:40:52.219        .  pseudo: JPEG_TN
08:40:52.229        .  url: http://192.168.1.2:8895/resource/1268/COVER_IMAGE
08:40:52.238        .  mime: image/jpeg
08:40:52.249  .  upnp:genre: Unknown
08:40:52.261  .  dlna:profileID: JPEG_TN
08:40:52.270  .  dc:title: Birds_1080.mkv
08:40:52.281  .  res:resolution: 1920x1072
08:40:52.290  .  path: http://192.168.1.2:8895/resource/596/MEDIA_ITEM/MATROSKA-0/ORIGINAL
08:40:52.301  .  height: 1072
08:40:52.312  .  upnp:albumArtURI: http://192.168.1.2:8895/resource/1268/COVER_IMAGE
08:40:52.321  .  dc:date: 2011-04-28
08:40:52.330  .  restricted: 1
08:40:52.341  .  seconds: 23
08:40:52.351  .  dc:description: A woman plays with a bird as the camera's gaze is drawn to her legs.
08:40:52.362  .  upnp:class: object.item.videoItem
08:40:52.373  .  bar: 5 Videos
08:40:52.383  .  refresh: False
08:40:52.396  .  res:duration: 0:00:23.000
08:40:52.407  .  dev_id: 2
08:40:52.416  .  upnp:icon: http://192.168.1.2:8895/resource/1268/COVER_IMAGE
08:40:52.426  .  res:bitrate: 4982375
08:40:52.435  .  url: V_F^FOL_R1V_F^FOL_R1$F33/
08:40:52.448  .  title: Birds_1080
08:40:52.458  .  id: V_F^FOL_R1$F33$MI596
08:40:52.470  .  type: 2
08:40:52.480  .  res:size: 114918832
08:40:52.489  .  parentID: V_F^FOL_R1$F33
08:40:52.500  .  mime: video/x-matroska
Good Video Soap data
<?xml version="1.0" encoding="utf-8" ?><SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><SOAP-ENV:Body><u:BrowseResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><Result>&lt;?xml version="1.0" encoding="UTF-8" standalone="no"?&gt;&lt;DIDL-Lite xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/"&gt;&lt;item id="V_F^FOL_R1$F33$MI548" parentID="V_F^FOL_R1$F33" restricted="1"&gt;&lt;dc:title&gt;MKV-Bicentennial_Man.mkv&lt;/dc:title&gt;&lt;upnp:class&gt;object.item.videoItem&lt;/upnp:class&gt;&lt;upnp:albumArtURI dlna:profileID="JPEG_TN"&gt;http://192.168.1.2:8895/resource/647/COVER_IMAGE&lt;/upnp:albumArtURI&gt;&lt;upnp:icon&gt;http://192.168.1.2:8895/resource/647/COVER_IMAGE&lt;/upnp:icon&gt;&lt;dc:date&gt;2011-02-02&lt;/dc:date&gt;&lt;upnp:genre&gt;Unknown&lt;/upnp:genre&gt;&lt;upnp:rating&gt;Unknown&lt;/upnp:rating&gt;&lt;res bitrate="59500" duration="0:01:05.000" protocolInfo="http-get:*:application/vnd.apple.mpegurl:DLNA.ORG_PN=HLS;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000" resolution="624x320"&gt;http://192.168.1.2:8895/resource/548/MANIFEST/HLS-0/ORIGINAL.m3u8&lt;/res&gt;&lt;res protocolInfo="http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000" resolution="160x82"&gt;http://192.168.1.2:8895/resource/647/COVER_IMAGE&lt;/res&gt;&lt;/item&gt;&lt;/DIDL-Lite&gt;</Result><NumberReturned>1</NumberReturned><TotalMatches>1</TotalMatches><UpdateID>2</UpdateID></u:BrowseResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
My Decode
10:21:49.810 * ---------------- Video Item ---------------- roAssociativeArray
10:21:49.820  .  width: 624
10:21:49.830  .  info: True
10:21:49.842  .  upnp:rating: Unknown
10:21:49.856  .  icon: tmp:/Theme/Default/video.png
10:21:49.866  .  protocol: roArray
10:21:49.881     .  .protocol count 2
10:21:49.895     .  [0] roAssociativeArray
10:21:49.906        .  mode: http-get
10:21:49.917        .  protocolInfo: http-get:*:application/vnd.apple.mpegurl:DLNA.ORG_PN=HLS;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000
10:21:49.928        .  pseudo: HLS
10:21:49.939        .  url: http://192.168.1.2:8895/resource/757/MANIFEST/HLS-0/ORIGINAL.m3u8
10:21:49.950        .  mime: application/vnd.apple.mpegurl
10:21:49.961     .  [1] roAssociativeArray
10:21:49.972        .  mode: http-get
10:21:49.983        .  protocolInfo: http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000
10:21:49.994        .  pseudo: JPEG_TN
10:21:50.005        .  url: http://192.168.1.2:8895/resource/1803/COVER_IMAGE
10:21:50.015        .  mime: image/jpeg
10:21:50.026  .  upnp:genre: Unknown
10:21:50.038  .  dlna:profileID: JPEG_TN
10:21:50.048  .  dc:title: MKV-Bicentennial_Man.mkv
10:21:50.058  .  res:resolution: 624x320
10:21:50.069  .  path: http://192.168.1.2:8895/resource/757/MANIFEST/HLS-0/ORIGINAL.m3u8
10:21:50.085  .  height: 320
10:21:50.095  .  upnp:albumArtURI: http://192.168.1.2:8895/resource/1803/COVER_IMAGE
10:21:50.105  .  dc:date: 2011-02-02
10:21:50.116  .  restricted: 1
10:21:50.127  .  seconds: 65
10:21:50.138  .  upnp:class: object.item.videoItem
10:21:50.149  .  refresh: False
10:21:50.159  .  res:duration: 0:01:05.000
10:21:50.170  .  dev_id: 1
10:21:50.181  .  upnp:icon: http://192.168.1.2:8895/resource/1803/COVER_IMAGE
10:21:50.192  .  res:bitrate: 59500
10:21:50.202  .  title: MKV-Bicentennial_Man
10:21:50.213  .  id: V_F^FOL_R2$F40$MI757
10:21:50.224  .  type: 2
10:21:50.235  .  parentID: V_F^FOL_R2$F40
10:21:50.246  .  mime: application/vnd.apple.mpegurl
Post Tue Aug 13, 2013 3:29 pm
how come the first is not transcoded to HLS?
chaneru
Post Tue Aug 13, 2013 3:42 pm
That is my question. It looks like when ffmpeg got the information, Serviio decided not to transcode it. ( profile ? )
Post Tue Aug 13, 2013 4:31 pm
post ffmpeg -i for the file
chaneru
Post Tue Aug 13, 2013 5:15 pm
Input #0, matroska,webm, from 'Birds_1080.mkv':
  Duration: 00:00:23.06, start: 0.000000, bitrate: 39859 kb/s
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x1072 [SAR 1:1 DAR 120:67
], 23.98 fps, 23.98 tbr, 20k tbn, 47.95 tbc (default)
Post Tue Aug 13, 2013 7:28 pm
That looks fine.
In the Browse response you should not get MATROSKA resources, but HLS. Are you sure the browse response is rendered using the right profile? (check serviio log).
chaneru
Post Tue Aug 13, 2013 7:42 pm
In my previous post with code tagged as "Failed Video Soap data" and "Good Video Soap data" is the browse responses in the same session. I'm not changing profiles.
I have 5 MKV files in the same folder and the two that are flagged as HD, show as MKV, where the others are HLS ????
Post Tue Aug 13, 2013 8:00 pm
I tried the profile with my files and all are HLS.
Can you try to browse to the folder in Intel's AV Media Controller? Don't forget to give the PC the Roku profile.
Example here: viewtopic.php?f=5&t=12275&p=75845&hilit=avmc#p75845
Look at the properties of the resources, are they all HLS or some MATROSKA?
Users browsing this forum: Majestic-12 [Bot] and 10 guests
