Need advices about audio out of sync
thenamelessthing
Post Mon Jul 29, 2013 3:40 am
Hi, I think I have inderstand why some of my file are out of sync. It's because of framerate who are not the right for my tv. Ex: I have two file, one with the audio out of sync problem and another who doesn't have the problem. The difference between the two file are the framerate of the video. One have 29.97 and the other have 25. I'm using a ntsc TV. Maybe if I reencode the file I can fix the problem? What do you think of my observation?
File who doesn't have the problem:
[mp3 @ 0x99982a0] Header missing
[mpeg4 @ 0x9996120] Invalid and inefficient vfw-avi packed B frames detected
Seems stream 0 codec frame rate differs from container frame rate: 30000.00 (30000/1) -> 29.97 (30000/1001)
Input #0, avi, from 'S04E06 - La poule aux oeufs d'or (1-2).avi':
encoder : VirtualDubMod 1.5.4.1 (build 2178/release)
Duration: 00:20:23.69, start: 0.000000, bitrate: 1165 kb/s
Stream #0.0: Video: mpeg4, yuv420p, 720x544 [PAR 1:1 DAR 45:34], 29.97 fps, 29.97 tbr, 29.97 tbn, 30k tbc
Stream #0.1: Audio: mp3, 44100 Hz, stereo, s16, 112 kb/s
File who have the problem:
patrick@patrick-RK574AAR-ABA-a1730n:~/.gvfs/SFTP sur 192.168.1.3 en tant que media/data/Dessins_Animes/SD/Picsou$ ffmpeg -i S01E01\ -\ N\'abandonnez\ Pas\ Le\ Navire.avi ffmpeg version 0.8.6-4:0.8.6-0ubuntu0.12.04.1, Copyright (c) 2000-2013 the Libav developers
built on Apr 2 2013 17:00:59 with gcc 4.6.3
[mp3 @ 0x8b722a0] Header missing
[mpeg4 @ 0x8b70120] Invalid and inefficient vfw-avi packed B frames detected
Seems stream 0 codec frame rate differs from container frame rate: 30000.00 (30000/1) -> 25.00 (25/1)
Input #0, avi, from 'S01E01 - N'abandonnez Pas Le Navire.avi':
Duration: 00:21:52.20, start: 0.000000, bitrate: 1119 kb/s
Stream #0.0: Video: mpeg4, yuv420p, 720x544 [PAR 1:1 DAR 45:34], 25 fps, 25 tbr, 25 tbn, 30k tbc
My Setup : BDT220 Panasonic Bluray player, TC-L55ET5 and TC-L42ET5 Panasonic TV. My home media server run Serviio 1.4.2 Pro under GNU/Linux Ubuntu 14.04 LTS server x64 and the hardware is Amd 1045t Phenom II X6, 6Gb DDR3 1333 mhz on SSD and data on soft raid 5 (3x1tb).
thenamelessthing
Post Mon Aug 05, 2013 12:53 pm
Re: Need advices about audio out of sync
I have successfully fixed my file who have the sync problem. I have reencoded the file at an different framerate. I have change the 25fps to 29.97 and everythings it's okay. BUT you can notice when you watch a little frame rate mismatch but is VERY better than an out of sync trouble!
I hope this can help other people...
Users browsing this forum: Baidu [Spider] and 13 guests
