No video , audio on mkv file on sony
atghate
Post Sun Jul 14, 2013 3:38 am
I am new to serviio/ media sharing.
I have sony KDL40EX523.
I am using 2011US profile for this.
I have file that I am trying to play in mkv format, i can hear the sound alright but picture is blank.
Details of file are as below:
ffmpeg version 1.1.1 Copyright (c) 2000-2013 the FFmpeg developers
built on Feb 5 2013 21:59:54 with gcc 4.7.2 (GCC)
p --enable-fontconfig --enable-libfreetype --enable-zlib --extra-libs='-lrtmp -l
polarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-
runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-
mingw32- --pkg-config=pkg-config
libavutil 52. 13.100 / 52. 13.100
libavcodec 54. 86.100 / 54. 86.100
libavformat 54. 59.106 / 54. 59.106
libavdevice 54. 3.102 / 54. 3.102
libavfilter 3. 32.100 / 3. 32.100
libswscale 2. 1.103 / 2. 1.103
Input #0, matroska,webm, from 'C:\Users\atghate\Videos\Sample\sample.mkv':
creation_time : 2013-07-07 02:40:03
Duration: 00:00:51.51, start: 0.000000, bitrate: 533 kb/s
Chapter #0.0: start 0.000000, end 46.630000
title : Chapter 1
Chapter #0.1: start 46.630000, end 51.510000
title : Chapter 2
Stream #0:0(eng): Video: h264 (Main), yuv420p, 570x252 [SAR 84:95 DAR 2:1],
23.98 fps, 23.98 tbr, 1k tbn, 180k tbc (default)
Stream #0:1(eng): Audio: mp3, 48000 Hz, stereo, s16p, 80 kb/s (default)
NX3
Post Sun Jul 14, 2013 12:48 pm
Re: No video , audio on mkv file on sony
I'd guess its because its WebM video but I thought serviio coped with that. Have you got transcoding enabled ? Your on the latest version of serviio ?
atghate
Post Sun Jul 14, 2013 1:29 pm
NX3 wrote:I'd guess its because its WebM video but I thought serviio coped with that. Have you got transcoding enabled ? Your on the latest version of serviio ?
Thank you for response.
Yes , transcoding is enabled.
Avi videos were playing ok on tv ok those do not play without trans-coding.
I think my Title is misleading. audio is ok. video is not on ok for mkv file.
NX3
Post Sun Jul 14, 2013 1:47 pm
Just out of interest try a sony 2010 profile so it gets transcoded to mpeg2 and see if you get video ?
NX3
Post Mon Jul 29, 2013 7:19 am
I've got the same problem now on this file below. I'm updates ffmpeg to latest build etc... no different. I'm currently re-encoding it.
Format profile                           : Main@L4.0
Format settings, CABAC                   : No
Format settings, ReFrames                : 2 frames
Muxing mode                              : Header stripping
Duration                                 : 2h 45mn
Bit rate                                 : 10 000 Kbps
Height                                   : 800 pixels
Display aspect ratio                     : 2.40:1
Bits/(Pixel*Frame)                       : 0.272
Stream size                              : 11.2 GiB (85%)
Writing library                          : x264 core 112
Encoding settings                        : cabac=0 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=umh / subme=5 / psy=1 / psy_rd=0.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=0 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=0 / open_gop=0 / weightp=0 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=10000 / ratetol=1.0 / qcomp=0.60 / qpmin=3 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
FFMPEG -i
ffmpeg version git-2013-07-28-1ecf380 Copyright (c) 2000-2013 the FFmpeg developers
  built on Jul 28 2013 12:56:41 with gcc 4.6 (Ubuntu/Linaro 4.6.3-1ubuntu5)
  configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-librtmp --enable-libxvid --enable-libass --enable-libvpx
  libavutil      52. 40.100 / 52. 40.100
  libavcodec     55. 19.100 / 55. 19.100
  libavformat    55. 12.102 / 55. 12.102
  libavdevice    55.  3.100 / 55.  3.100
  libavfilter     3. 81.103 /  3. 81.103
  libswscale      2.  4.100 /  2.  4.100
  libswresample   0. 17.103 /  0. 17.103
Input #0, matroska,webm, from 'file.mkv':
    creation_time   : 2013-03-27 18:14:58
  Duration: 02:45:22.87, start: 0.000000, bitrate: 11390 kb/s
    Chapter #0.0: start 0.000000, end 216.466000
      title           : Chapter 1
    Chapter #0.1: start 216.466000, end 767.976000
      title           : Chapter 2
    Chapter #0.2: start 767.976000, end 1129.462000
      title           : Chapter 3
    Chapter #0.3: start 1129.462000, end 1608.315000
      title           : Chapter 4
    Chapter #0.4: start 1608.315000, end 1904.528000
      title           : Chapter 5
    Chapter #0.5: start 1904.528000, end 2427.175000
      title           : Chapter 6
    Chapter #0.6: start 2427.175000, end 2765.513000
      title           : Chapter 7
    Chapter #0.7: start 2765.513000, end 3156.904000
      title           : Chapter 8
    Chapter #0.8: start 3156.904000, end 3492.864000
      title           : Chapter 9
    Chapter #0.9: start 3492.864000, end 3740.362000
      title           : Chapter 10
    Chapter #0.10: start 3740.362000, end 4333.538000
      title           : Chapter 11
    Chapter #0.11: start 4333.538000, end 4715.836000
      title           : Chapter 12
    Chapter #0.12: start 4715.836000, end 5168.080000
      title           : Chapter 13
    Chapter #0.13: start 5168.080000, end 5689.642000
      title           : Chapter 14
    Chapter #0.14: start 5689.642000, end 6052.380000
      title           : Chapter 15
    Chapter #0.15: start 6052.380000, end 6334.036000
      title           : Chapter 16
    Chapter #0.16: start 6334.036000, end 6601.136000
      title           : Chapter 17
    Chapter #0.17: start 6601.136000, end 6904.022000
      title           : Chapter 18
    Chapter #0.18: start 6904.022000, end 7434.969000
      title           : Chapter 19
    Chapter #0.19: start 7434.969000, end 7694.103000
      title           : Chapter 20
    Chapter #0.20: start 7694.103000, end 8054.421000
      title           : Chapter 21
    Chapter #0.21: start 8054.421000, end 8248.991000
      title           : Chapter 22
    Chapter #0.22: start 8248.991000, end 8552.544000
      title           : Chapter 23
    Chapter #0.23: start 8552.544000, end 8788.530000
      title           : Chapter 24
    Chapter #0.24: start 8788.530000, end 9180.463000
      title           : Chapter 25
    Chapter #0.25: start 9180.463000, end 9341.999000
      title           : Chapter 26
    Chapter #0.26: start 9341.999000, end 9690.931000
      title           : Chapter 27
    Chapter #0.27: start 9690.931000, end 9922.872000
      title           : Chapter 28
    Stream #0:0(eng): Video: h264 (Main), yuv420p, 1920x800, SAR 1:1 DAR 12:5, 23.98 fps, 23.98 tbr, 1k tbn, 180k tbc (default)
    Stream #0:1(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), fltp, 1536 kb/s (default)
Post Mon Jul 29, 2013 8:05 am
NX3 wrote:Format/Info : Advanced Video Codec
"Header stripping" not supported, should be detected by serviio and remuxed. Check detailed log file and extract the ffmpeg command line used ?
NX3
Post Mon Jul 29, 2013 5:41 pm
Cheers Illico, line below.
Starting ffmpeg -fflags +genpts -threads 4 -i file.mkv -y -c:v copy -bsf:v h264_mp4toannexb -c:a ac3 -b:a 384k -ac 6 -map 0:0 -map 0:1 -sn -f mpegts /tmp/Serviio/transcoding-temp-72377-sony2011-ORIGINAL.stf
