Sony BDP-S590, some files cannot play
In Serviio, I'm using the Sx90 2012 profile and for 90% of my files it plays perfectly without transcoding. All my files are straight bluray remuxes, so most are very high bitrate. I'd like to keep it this way as transcoding is very cpu intensive and unnecessary for most files and I have a home theater that utilizes these files as well. I want the highest quality possible.
Here's an example of two files that won't play. In the log, both files are mentioned as being passed in native format. Any idea what's wrong with these files?
2013-07-29 21:58:41,704 DEBUG [VideoDeliveryEngine] Delivering file 'Prometheus.mkv' in native format
2013-07-29 22:00:14,355 DEBUG [VideoDeliveryEngine] Delivering file 'Serenity.mkv' in native format
Complete name : E:\Movies\Prometheus\Prometheus.mkv
Format : Matroska
File size : 25.8 GiB
Duration : 2h 3mn
Overall bit rate : 29.9 Mbps
Movie name : Prometheus
Encoded date : UTC 2013-07-24 22:55:16
Writing application : mkvmerge v6.3.0 ('You can't stop me!') built on Jun 28 2013 20:09:41
Writing library : libebml v1.3.0 + libmatroska v1.4.0
Attachment : Yes
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 3mn
Bit rate mode : Variable
Bit rate : 27.8 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.558
Stream size : 24.0 GiB (93%)
Language : English
Default : No
Forced : No
Format : DTS
Mode : 16
Codec ID : A_DTS
Duration : 2h 3mn
Bit rate mode : Constant
Bit rate : 1 509 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1.30 GiB (5%)
Title : 3/2+1
Language : English
Default : Yes
Forced : No
Text
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : The same subtitle format used on BDs/HD-DVDs
Language : English
Default : Yes
Forced : No
and...
Complete name : E:\Movies\Serenity\Serenity.mkv
Format : Matroska
Format version : Version 2
File size : 18.4 GiB
Duration : 1h 59mn
Overall bit rate : 22.1 Mbps
Encoded date : UTC 2012-03-06 22:05:59
Writing application : mkvmerge v5.3.0 ('I could have danced') built on Feb 9 2012 10:38:07
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Format : VC-1
Format profile : Advanced@L3
Codec ID : V_MS/VFW/FOURCC / WVC1
Codec ID/Hint : Microsoft
Duration : 1h 59mn
Bit rate : 20.1 Mbps
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.405
Stream size : 16.7 GiB (91%)
Language : English
Default : Yes
Forced : No
Format : DTS
Mode : 16
Codec ID : A_DTS
Duration : 1h 59mn
Bit depth : 24 bits
Delay relative to video : 10ms
Stream size : 1.25 GiB (7%)
Title : 3/2+1
Language : English
Default : Yes
Forced : No
Text
Format : PGS
Language : English
Default : Yes
Forced : No
Thanks!
