Why is this file transcoded ?
NX3
Post Tue Jul 30, 2013 5:42 pm
Sony 2011 profile, this gets transcoded to mpeg2 but it appears at face value the same as all other HD videos that don't get fully transcoded.
Format settings, ReFrames                : 5 frames
Duration                                 : 2h 41mn
Nominal bit rate                         : 10.4 Mbps
Height                                   : 1 080 pixels
Bits/(Pixel*Frame)                       : 0.209
Writing library                          : x264 core 135 r2345
Encoding settings                        : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=230 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=10398 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=24000 / vbv_bufsize=24000 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
Language                                 : Spanish
Post Wed Jul 31, 2013 1:13 am
Re: Why is this file transcoded ?
It's because the h264 profile level is High@L5 despite what the header of the file states - see http://wiki.serviio.org/doku.php?id=get_h264_level
This is then transcoded in accordance with the first rule in the Sony 2012 profile (which the 2011 profile inherits).
NX3
Post Wed Jul 31, 2013 6:55 pm
How can you tell its level 5.1 ? It claims 4.1 which is why I was surprised to be transcoding...
Post Wed Jul 31, 2013 7:28 pm
NX3 wrote:How can you tell its level 5.1 ? It claims 4.1 which is why I was surprised to be transcoding...
Do you read the wiki ? http://wiki.serviio.org/doku.php?id=get_h264_level
1920x1080x5/256=40500 ==> Level > 4.2 this is not a 4.1 level
if there were 4 refframe, it should be a 4.1 level...
NX3
Post Wed Jul 31, 2013 7:38 pm
I have to admit I didn't full appreciate how the lv worked and was calculated. I do now so thank you.....
Post Wed Jul 31, 2013 11:33 pm
Illico wrote:1920x1080x5/256=40500 ==> Level > 4.2 this is not a 4.1 level
Being pedantic but I also want to to double check my understanding (I make this a level 5.0) :
1920x1080x5/256=40500 ==> Level > 5.0 as the 40500 exceeds the Level 4.2 MaxDpbMbs of 34,816 (but is less than the level 5.0 MaxDpbMbs of 110,400)
Post Thu Aug 01, 2013 10:24 am
Oups,
Yes Maxbdp for 4.2 is 34816, so 40500 exceeds the level then, you are right level should be 5.0...
