Tune In radio
unmatched
Post Wed Jul 31, 2013 7:47 am
Re: Tune In radio
Ich have 2 Questions:
1: I cant add single stations like this: http://tunein.com/radio/Masters-of-Hard ... o-s111956/ please help
2: Is it possible to add my favourites from Tune in to Serviio?
Maca
Post Sat Aug 03, 2013 1:47 pm
Re: Tune In radio
zip, I have been using this plugin quite a lot on my Sony Bravia (2011) and it seems a bit hit and miss whether the stream will start, often I have to return and press play again until it starts.
Grabbed the log output...
2013-08-03 14:36:19,879 WARN [OutputBytesReader] Error reading bytes stream from external process: Stream closed
2013-08-03 14:36:19,895 WARN [PipedOutputBytesReader] Error reading bytes stream from external process: Stream closed
This was using 1.3 beta 3 and the recent RC1
Works ok, but would be great if it worked first go.
dualc
Post Sun Sep 15, 2013 8:37 am
Re: Tune In radio
Hi..
Can get it to work in 1.3.1 server, added..
http://tunein.com/radio/Trance-g403/
http://tunein.com/radio/Sweden-r101300/
http://tunein.com/radio/stations/Sveriges-Radio-a33815/
I got this warning in log..
WARN [FeedUpdaterThread] An error occured while parsing the online resource http://tunein.com/radio/stations/Sveriges-Radio-a33815/, will try again soon: Unexpected error while invoking plugin (Tune In): index is out of range 0..-1 (index = 0)
As webresource, and i cant see any list in either XBMC or on my BD-C5500 bluray player.
Any ideas.?
BlurayPlayer: Samsung BD-C5500
TV: Samsung LE40B535
Post Sun Sep 15, 2013 7:45 pm
Re: Tune In radio
Updated the plugin to follow new tunein changes
dualc
Post Mon Sep 16, 2013 5:01 am
Re: Tune In radio
Thx for the update Petr, .. works like charm now. :)
/M
flexi
Post Tue Oct 01, 2013 4:48 pm
Re: Tune In radio
Where do I find the updated plugin?
A.P.P for Serviio 1.3.1 (27/09/2013) includes tunein.groovy version 3 by 31/03/2013.
I'm getting "Unexpected error while invoking plugin (Tune In): index is out of range 0..-1 (index = 0)" every time.
Post Wed Oct 02, 2013 9:00 pm
Re: Tune In radio
top of this topic
flexi
Post Fri Oct 04, 2013 12:54 am
Re: Tune In radio
Oh, you can simply replace files here? Stupid me.
Well, version 4 looks way better. Thank you.
n3mmr
Post Mon Oct 28, 2013 8:24 am
Re: Tune In radio
how the h--l do you know that you're actually providing mp3 streams so that they actually get presented??
n3mmr
Post Mon Oct 28, 2013 5:01 pm
Re: Tune In radio
I set up the URL http://tunein.com/radio/stations/Sveriges-Radio-a33815/ which works.
But only the first 7 entries, i e the first page; There are several pages. Their URLs are the same, but... ?
How's one supposed to make this plugin show the rest of the stations available?
jk50
Post Tue Oct 29, 2013 12:57 am
Re: Tune In radio
n3mmr wrote:I set up the URL http://tunein.com/radio/stations/Sveriges-Radio-a33815/ which works.
Try this
first page:
http://tunein.com/radio/search/?query=Sveriges
second page:
http://tunein.com/radio/search/?query=Sveriges&offset=7
third page:
http://tunein.com/radio/search/?query=S ... &offset=14
just change "&offset=X" untill you get what you want.
dualc
Post Sat Dec 21, 2013 8:53 am
Re: Tune In radio
Hi.
This plugin does not give me any playlist's anymore, .. needin'g an uppgrade maybee?
/M
TIG
Post Fri Jan 10, 2014 2:01 pm
Re: Tune In radio
Not workin' anymore...
Post Thu Jan 23, 2014 11:08 pm
Re: Tune In radio
Give me some URLs that don't work anymore.
sammo420
Post Sat Feb 08, 2014 4:23 am
Re: Tune In radio
According to an above post this at one point worked
but I tried it and it didn't work for me. I've also tried getting
http://tunein.com/radio/The-Bone-1077-s35231/#
in a couple of different variations to work with no luck which is why I tried the above to make sure it wasn't something I was doing wrong. Enter as "web resource" and click "audio" and nothing. They can't all be mp3.
Great app by the way, thatnks for allowing me to kick to competition to the curb. You guys in the forums with the plugins and transcoding support really make this app a lot better as well.
Post Mon Feb 10, 2014 8:50 pm
Re: Tune In radio
sammo420 wrote:According to an above post this at one point worked
This one gives me 6 streams on the Bravia.
david3
Post Sat Feb 15, 2014 1:23 am
Re: Tune In radio
Hello Petr (zip)
I change your plugin Tune In, in VALID_FEED_URL. This line (15) I change to:
final VALID_FEED_URL = '^(?:https?://)?(?:www\\.)?tunein\\.com/(radio/|search/\\?query=).+'
This change permit to add Urls from Search Query. For Example if you Search in Tune in "Sky.fm New Age" the Url is:
http://tunein.com/search/?query=sky.fm%20new%20age
This code works correctly and shows radio stations...
But in unknown circunstances it doesnt work. For Example with query "Kiss FM 955"
http://tunein.com/search/?query=kiss%20fm%20955
This case shows a empty folder, but in Tune In results shows 1 result. I think it happens by an html TAG but i cant found.
Can you help me? thanks!!
I attach the file if anybody want to add search results as Stations
TuneIn.groovy
(5.4 KiB) Downloaded 3842 times
Post Sat Feb 15, 2014 8:10 pm
Re: Tune In radio
I've updated the plugin - it should now pick that (flash based) station
shomizu9
Post Wed Apr 02, 2014 5:54 pm
Re: Tune In radio
Thanks so much for this plugin (and Serviio itself!).
I've figured out how to use it after reading over everything here - but also noticed some people asking about things I would also love to see after learning how to use the plugin and how TuneIn search queries work in general.
Some people above mentioned the 7 station result limit - this is of course how TuneIn search results are returned when you do a search on their website; if there are more than 7 results it shows some buttons for showing a new page with further results. I monkeyed around with URLs trying to see if there was a way to get TuneIn to return all results on one page (which would let someone add such a URL to Serviio), but of course any operators are not listed anywhere I could find. The offset one simply allows you to basically repeat the behavior the buttons on the results page provides.
Given the TuneIn plugin parses the returned results page to build its list of stations available in Serviio, what about having the plugin look for and use the "Showing 1-7 of 30" type info on the returned page to do a loop or something to basically forward the results (like a person would if they clicked the > arrow button on the TuneIn results page to forward their results list), adding stations from each returned page until the end? It would be a sort of hack to get around the 7 station results per page limit and allow Serviio users to build full station lists off search queries. This in turn means having to add fewer web resource URLs to Serviio to get all results.
Why would anyone want to add a full search query as a web resource? Well, an example is a collection of stations that belong to one site - SomaFM. If I search for "somafm" it returns all the stations they produce, and we could simply add one url as a web resource to get all 30 results into Serviio:
http://tunein.com/search/?query=somafm (returns 1-7 only)
instead of 5 URLs:
(1-7) http://tunein.com/search/?query=somafm
(8-14) http://tunein.com/search/page/?query=so ... e&offset=7
(15-21) http://tunein.com/search/page/?query=so ... &offset=14
(22-28) http://tunein.com/search/page/?query=so ... &offset=21
(29-30) http://tunein.com/search/page/?query=so ... &offset=28
Of course, the Serviio user would really want to be sure that their search query URL they add as a web resource actually returned only what they wanted.....
Just a thought/idea! Thanks again
Gumby
Post Sun May 11, 2014 12:35 pm
Re: Tune In radio
Is it just me...or did the Tunein plugin stop working over this weekend? I know there was a new release of the TuneIn web site...anyone else having issues?
Return to Available plugins
