Problems connecting with Serviio and Windows 8
JohninLA
Post Wed Jul 31, 2013 4:44 pm
I have been having problems with Serviio since I got a new computer with Windows 8. I have some online streaming sites that work fine, then suddenly stop. Today they aren't working again, and I've rebooted my pc, restarted Serviio, my cable modem, my router, and my media player, nothing. Serviio seems to be blocked by my system somehow, but I can't find out where. I've checked the firewall, the drive permissions, and all seems ok as far as permissions. I've shared the drive with "Everyone" giving write and edit permissions.
I'm not sure what settings need to be fixed so Serviio will work properly. Here's my log, can anyone see what the problem might be? Thanks for any help.
2013-07-31 09:13:45,452 WARN  [LibraryAdditionsCheckerThread] An error occured while scanning for item to be added, will continue
org.serviio.db.dao.PersistenceException: Cannot mark Repository with id 1 as scanned
   at org.serviio.library.dao.RepositoryDAOImpl.markRepositoryAsScanned(RepositoryDAOImpl.java:173)
   at org.serviio.library.local.service.RepositoryService.markRepositoryAsScanned(RepositoryService.java:112)
   at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.run(LibraryAdditionsCheckerThread.java:84)
Caused by: java.sql.SQLNonTransientConnectionException: Connection closed by unknown interrupt.
   at org.apache.derby.impl.jdbc.EmbedStatement.executeStatement(Unknown Source)
   at org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeStatement(Unknown Source)
   at org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeUpdate(Unknown Source)
   at org.serviio.library.dao.RepositoryDAOImpl.markRepositoryAsScanned(RepositoryDAOImpl.java:171)
   ... 2 more
Caused by: java.sql.SQLException: Connection closed by unknown interrupt.
   ... 12 more
Caused by: ERROR 08000: Connection closed by unknown interrupt.
   at org.apache.derby.iapi.util.InterruptStatus.setInterrupted(Unknown Source)
   at org.apache.derby.iapi.util.InterruptStatus.throwIf(Unknown Source)
   at org.apache.derby.impl.sql.execute.BasicNoPutResultSetImpl.checkCancellationFlag(Unknown Source)
   at org.apache.derby.impl.sql.execute.TableScanResultSet.getNextRowCore(Unknown Source)
   at org.apache.derby.impl.sql.execute.IndexRowToBaseRowResultSet.getNextRowCore(Unknown Source)
   at org.apache.derby.impl.sql.execute.ProjectRestrictResultSet.getNextRowCore(Unknown Source)
   at org.apache.derby.impl.sql.execute.NormalizeResultSet.getNextRowCore(Unknown Source)
   at org.apache.derby.impl.sql.execute.DMLWriteResultSet.getNextRowCore(Unknown Source)
   at org.apache.derby.impl.sql.execute.UpdateResultSet.collectAffectedRows(Unknown Source)
   at org.apache.derby.impl.sql.execute.UpdateResultSet.open(Unknown Source)
   at org.apache.derby.impl.sql.GenericPreparedStatement.executeStmt(Unknown Source)
   at org.apache.derby.impl.sql.GenericPreparedStatement.execute(Unknown Source)
   ... 6 more
2013-07-31 09:13:45,454 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2013-07-31 09:13:45,615 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2013-07-31 09:13:45,639 INFO  [FeedUpdaterThread] Finished looking for online resources information
2013-07-31 09:13:45,739 INFO  [PluginCompilerThread] Finished looking for plugins
2013-07-31 09:13:45,861 INFO  [DatabaseManager] Shutting down database
2013-07-31 09:13:53,686 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2013-07-31 09:13:57,984 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2013-07-31 09:13:58,059 INFO  [MediaServer] ------------------------------------------------------------------------
2013-07-31 09:13:58,059 INFO  [MediaServer] Serviio DLNA media streaming server v 1.2.1 (rev. a2aa56064460+)
2013-07-31 09:13:58,059 INFO  [MediaServer] Petr Nejedly 2009-2013
2013-07-31 09:13:58,059 INFO  [MediaServer] http://www.serviio.org
2013-07-31 09:13:58,059 INFO  [MediaServer] Java 1.7.0_05-Oracle Corporation
2013-07-31 09:13:58,059 INFO  [MediaServer] OS Windows NT (unknown) amd64 6.2
2013-07-31 09:13:58,059 INFO  [MediaServer] File encoding: windows-1252
2013-07-31 09:13:58,059 INFO  [MediaServer] Headless mode enabled: true
2013-07-31 09:13:58,059 INFO  [MediaServer] User: JOHN-PC$
2013-07-31 09:13:58,059 INFO  [MediaServer] User home dir: C:\
2013-07-31 09:13:58,059 INFO  [MediaServer] Temp dir: C:\Windows\TEMP\
2013-07-31 09:13:58,350 INFO  [WebServer] Socket buffer set to 65535 bytes
2013-07-31 09:13:58,370 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2013-07-31 09:13:58,817 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2013-07-31 09:13:58,817 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2013-07-31 09:13:58,874 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2013-07-31 09:13:58,968 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2013-07-31 09:13:58,968 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2013-07-31 09:14:06,734 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2013-07-31 09:14:06,734 DEBUG [LocalAddressResolverStrategy] Resolving host IP address automatically
2013-07-31 09:14:06,734 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2013-07-31 09:14:06,735 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2013-07-31 09:14:06,736 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2013-07-31 09:14:06,737 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2013-07-31 09:14:06,737 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2013-07-31 09:14:06,738 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2013-07-31 09:14:06,739 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2013-07-31 09:14:06,739 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2013-07-31 09:14:06,740 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2013-07-31 09:14:06,740 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2013-07-31 09:14:06,741 DEBUG [DBLogDAOImpl] Checking if script 'script-1.0.sql' has been run
2013-07-31 09:14:06,742 DEBUG [DBLogDAOImpl] Checking if script 'script-1.1.sql' has been run
2013-07-31 09:14:06,742 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.sql' has been run
2013-07-31 09:14:06,743 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.1.sql' has been run
2013-07-31 09:14:06,893 DEBUG [LicenseValidator] Validating license file (352 bytes)
2013-07-31 09:14:07,290 INFO  [Device] Created UPnP Device with UUID: c5a8f887-8949-3e9f-a9ff-b88282874507, bound address: 192.168.2.2
2013-07-31 09:14:08,457 INFO  [MediaServer] ------------------------------------------------------------------------
2013-07-31 09:14:08,457 INFO  [MediaServer] License: FREE
2013-07-31 09:14:11,112 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2013-07-31 09:14:11,114 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2013-07-31 09:14:11,240 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2013-07-31 09:14:11,240 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2013-07-31 09:14:11,356 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2013-07-31 09:14:11,356 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2013-07-31 09:14:11,359 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2013-07-31 09:14:11,359 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2013-07-31 09:14:11,360 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2013-07-31 09:14:11,360 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2013-07-31 09:14:11,360 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2013-07-31 09:14:11,361 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2013-07-31 09:14:11,362 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2013-07-31 09:14:11,362 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2013-07-31 09:14:11,363 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E-series)' (id=7)
2013-07-31 09:14:11,363 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2013-07-31 09:14:11,364 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2013-07-31 09:14:11,364 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012
2013-07-31 09:14:11,367 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2013-07-31 09:14:11,367 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2012
2013-07-31 09:14:11,368 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2013-07-31 09:14:11,368 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010
2013-07-31 09:14:11,371 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2013-07-31 09:14:11,371 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010us
2013-07-31 09:14:11,371 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2013-07-31 09:14:11,371 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2011
2013-07-31 09:14:11,372 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2013-07-31 09:14:11,372 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2013-07-31 09:14:11,372 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2013-07-31 09:14:11,372 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2013-07-31 09:14:11,374 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2013-07-31 09:14:11,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2013-07-31 09:14:11,374 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2013-07-31 09:14:11,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2013-07-31 09:14:11,375 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2013-07-31 09:14:11,375 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2013-07-31 09:14:11,375 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2013-07-31 09:14:11,375 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2013-07-31 09:14:11,376 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2013-07-31 09:14:11,376 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011
2013-07-31 09:14:11,376 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2013-07-31 09:14:11,377 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2010
2013-07-31 09:14:11,377 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2013-07-31 09:14:11,377 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile plps2010
2013-07-31 09:14:11,378 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2013-07-31 09:14:11,378 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2013-07-31 09:14:11,378 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2013-07-31 09:14:11,378 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2009
2013-07-31 09:14:11,379 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2013-07-31 09:14:11,379 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 22
2013-07-31 09:14:11,379 INFO  [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2013-07-31 09:14:11,379 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011a
2013-07-31 09:14:11,380 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2013-07-31 09:14:11,380 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011
2013-07-31 09:14:11,380 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2013-07-31 09:14:11,380 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2010
2013-07-31 09:14:11,381 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2013-07-31 09:14:11,381 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012us
2013-07-31 09:14:11,381 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2013-07-31 09:14:11,381 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011us
2013-07-31 09:14:11,382 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2013-07-31 09:14:11,382 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonySTR
2013-07-31 09:14:11,383 INFO  [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2013-07-31 09:14:11,383 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonyCMT
2013-07-31 09:14:11,383 INFO  [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2013-07-31 09:14:11,383 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viziotv
2013-07-31 09:14:11,384 INFO  [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2013-07-31 09:14:11,384 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile win8metro
2013-07-31 09:14:11,385 INFO  [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2013-07-31 09:14:11,442 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2013-07-31 09:14:11,442 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile flv_player
2013-07-31 09:14:11,443 INFO  [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2013-07-31 09:14:11,443 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo
2013-07-31 09:14:11,444 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo' (id=serviigo)
2013-07-31 09:14:11,444 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile wp8
2013-07-31 09:14:11,445 INFO  [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2013-07-31 09:14:11,941 INFO  [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2013-07-31 09:14:11,941 INFO  [PluginCompilerThread] Started looking for plugins
2013-07-31 09:14:11,942 DEBUG [PluginCompilerThread] Starting plugin Youtube.groovy compilation
2013-07-31 09:14:11,942 INFO  [UpdateChecker] Checking if a new version is available
2013-07-31 09:14:11,951 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2013-07-31 09:14:11,953 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2013-07-31 09:14:12,140 DEBUG [DCRawWrapper] Invoking DCRAW to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/dcraw.exe
2013-07-31 09:14:12,140 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/dcraw.exe
2013-07-31 09:14:12,288 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2013-07-31 09:14:12,288 DEBUG [AbstractTranscodingDeliveryEngine] Deleting temporary transcoded files from: C:\Windows\TEMP\Serviio
2013-07-31 09:14:13,044 INFO  [WebServer] WebServer starting on port 8895
2013-07-31 09:14:13,593 DEBUG [DiscoveryManager] UPNP device c5a8f887-8949-3e9f-a9ff-b88282874507 (192.168.2.2) is available
2013-07-31 09:14:13,593 INFO  [EventDispatcher] Starting EventDispatcher
2013-07-31 09:14:13,593 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-07-31 09:14:13,593 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-07-31 09:14:13,807 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2013-07-31 09:14:13,841 INFO  [RendererSearchSender] Searching for Renderer devices
2013-07-31 09:14:13,987 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth4 (Realtek PCIe GBE Family Controller) and address 192.168.2.2, timeout = 0
2013-07-31 09:14:13,987 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth4 (Realtek PCIe GBE Family Controller) and address 192.168.2.2, timeout = 0
2013-07-31 09:14:13,989 DEBUG [RendererSearchSender$RendererSearchWorker] Multicasting SSDP M-SEARCH using interface eth4 (Realtek PCIe GBE Family Controller) and address 192.168.2.2, timeout = 0
2013-07-31 09:14:14,599 DEBUG [RendererSearchSender$RendererSearchWorker] Sending 1 'm-search' messages
2013-07-31 09:14:14,599 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device c5a8f887-8949-3e9f-a9ff-b88282874507
2013-07-31 09:14:15,055 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.2.2:53102s
2013-07-31 09:14:15,055 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.2.3:64784/, st: urn:schemas-upnp-org:device:MediaRenderer:1
2013-07-31 09:14:15,055 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 2246d328-0090-a99d-106c-1711fc713fa6 from address /192.168.2.3:33081
2013-07-31 09:14:15,056 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.2.2:53102s
2013-07-31 09:14:15,221 DEBUG [ServiioHttpService] Incoming request from /192.168.2.2:53462: GET /deviceDescription/c5a8f887-8949-3e9f-a9ff-b88282874507 HTTP/1.1, headers = [Host: 192.168.2.2:8895,Connection: Close]]
2013-07-31 09:14:15,221 DEBUG [ServiioHttpService] Incoming request from /192.168.2.10:3783: SUBSCRIBE /serviceEventing/ContentDirectory HTTP/1.1, headers = [Host: 192.168.2.2:8895,TIMEOUT: Second-300,SID: uuid:590b37ae-c471-4c1e-a30f-f01a01e1178f,CONNECTION: close]]
2013-07-31 09:14:15,221 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.2
2013-07-31 09:14:15,222 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.10
2013-07-31 09:14:15,228 DEBUG [ServiioHttpService] Incoming request from /192.168.2.3:63822: GET /deviceDescription/c5a8f887-8949-3e9f-a9ff-b88282874507 HTTP/1.1, headers = [Host: 192.168.2.2:8895,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 Intel MicroStack/1.0.1423]]
2013-07-31 09:14:15,228 DEBUG [RendererManager] Adding renderer Renderer [uuid=2246d328-0090-a99d-106c-1711fc713fa6, ipAddress=192.168.2.3, name=WD TV Live Plus, profileId=14, manuallyAdded=false, forcedProfile=true, enabled=true, accessGroupId=1] to list of active renderers
2013-07-31 09:14:15,228 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.3
2013-07-31 09:14:15,269 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent renewal request received for service ContentDirectory and subscription uuid:590b37ae-c471-4c1e-a30f-f01a01e1178f
2013-07-31 09:14:15,269 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device c5a8f887-8949-3e9f-a9ff-b88282874507 from 192.168.2.2 (headers = [Host: 192.168.2.2:8895,Connection: Close])
2013-07-31 09:14:15,269 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device c5a8f887-8949-3e9f-a9ff-b88282874507 from 192.168.2.3 (headers = [Host: 192.168.2.2:8895,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 Intel MicroStack/1.0.1423])
2013-07-31 09:14:15,270 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.2
2013-07-31 09:14:15,270 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.2.2:8895,Connection: Close]
2013-07-31 09:14:15,272 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.2
2013-07-31 09:14:15,272 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.3
2013-07-31 09:14:15,273 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.2.2:8895,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 Intel MicroStack/1.0.1423]
2013-07-31 09:14:15,274 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.3
2013-07-31 09:14:15,702 DEBUG [ServiioHttpService] Incoming request from /192.168.2.10:3806: SUBSCRIBE /serviceEventing/X_MS_MediaReceiverRegistrar HTTP/1.1, headers = [Host: 192.168.2.2:8895,TIMEOUT: Second-300,SID: uuid:bb0a0423-c352-4cd0-bc16-62959d9bbd61,CONNECTION: close]]
2013-07-31 09:14:15,702 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.10
2013-07-31 09:14:15,703 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent renewal request received for service X_MS_MediaReceiverRegistrar and subscription uuid:bb0a0423-c352-4cd0-bc16-62959d9bbd61
2013-07-31 09:14:16,425 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:07 (advertisement duration is 1800 sec.)
2013-07-31 09:14:16,445 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.2.10:8080/description.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2013-07-31 09:14:16,445 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 5f9ec1b3-ff59-19bb-8530-0005cd223ace from address /192.168.2.10:3911
2013-07-31 09:14:16,446 DEBUG [RendererManager] Adding renderer Renderer [uuid=5f9ec1b3-ff59-19bb-8530-0005cd223ace, ipAddress=192.168.2.10, name=AVR-2112, profileId=22, manuallyAdded=false, forcedProfile=true, enabled=true, accessGroupId=1] to list of active renderers
2013-07-31 09:14:16,717 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Windows 8/RT'
2013-07-31 09:14:16,718 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'WDTV Live'
2013-07-31 09:14:16,720 DEBUG [ServiioHttpService] Incoming request from /192.168.2.2:53464: GET /icon/smallPNG HTTP/1.1, headers = [Host: 192.168.2.2:8895,Connection: Close]]
2013-07-31 09:14:16,720 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.2
2013-07-31 09:14:16,720 DEBUG [ServiioHttpService] Incoming request from /192.168.2.2:53468: GET /serviceDescription/X_MS_MediaReceiverRegistrar HTTP/1.1, headers = [Host: 192.168.2.2:8895,Connection: Close]]
2013-07-31 09:14:16,721 DEBUG [ServiioHttpService] Incoming request from /192.168.2.2:53467: GET /icon/largeJPG HTTP/1.1, headers = [Host: 192.168.2.2:8895,Connection: Close]]
2013-07-31 09:14:16,721 DEBUG [ServiioHttpService] Incoming request from /192.168.2.2:53466: GET /icon/smallJPG HTTP/1.1, headers = [Host: 192.168.2.2:8895,Connection: Close]]
2013-07-31 09:14:16,721 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.2
2013-07-31 09:14:16,721 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2013-07-31 09:14:16,722 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon largeJPG
2013-07-31 09:14:16,723 DEBUG [ServiioHttpService] Incoming request from /192.168.2.2:53469: GET /serviceDescription/ConnectionManager HTTP/1.1, headers = [Host: 192.168.2.2:8895,Connection: Close]]
2013-07-31 09:14:16,723 DEBUG [ServiioHttpService] Incoming request from /192.168.2.2:53470: GET /serviceDescription/ContentDirectory HTTP/1.1, headers = [Host: 192.168.2.2:8895,Connection: Close]]
2013-07-31 09:14:16,723 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service X_MS_MediaReceiverRegistrar
2013-07-31 09:14:16,724 DEBUG [ServiioHttpService] Incoming request from /192.168.2.2:53465: GET /icon/largePNG HTTP/1.1, headers = [Host: 192.168.2.2:8895,Connection: Close]]
2013-07-31 09:14:16,724 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.2
2013-07-31 09:14:16,725 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2013-07-31 09:14:16,728 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.2.3:64784/, st: urn:schemas-upnp-org:device:MediaRenderer:1
2013-07-31 09:14:16,728 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 2246d328-0090-a99d-106c-1711fc713fa6 from address /192.168.2.3:33082
2013-07-31 09:14:16,728 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon largePNG
2013-07-31 09:14:16,729 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.2.3:64784/, st: urn:schemas-upnp-org:device:MediaRenderer:1
2013-07-31 09:14:16,729 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 2246d328-0090-a99d-106c-1711fc713fa6 from address /192.168.2.3:33083
2013-07-31 09:14:16,729 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2013-07-31 09:14:16,729 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallJPG
2013-07-31 09:14:16,730 DEBUG [ServiioHttpService] Incoming request from /192.168.2.3:63822: GET /serviceDescription/X_MS_MediaReceiverRegistrar HTTP/1.1, headers = [Host: 192.168.2.2:8895,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 Intel MicroStack/1.0.1423]]
2013-07-31 09:14:16,730 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.3
2013-07-31 09:14:16,736 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service X_MS_MediaReceiverRegistrar
2013-07-31 09:14:16,738 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2013-07-31 09:14:16,743 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2013-07-31 09:14:16,746 DEBUG [ServiioHttpService] Incoming request from /192.168.2.3:63822: GET /serviceDescription/ContentDirectory HTTP/1.1, headers = [Host: 192.168.2.2:8895,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 Intel MicroStack/1.0.1423]]
2013-07-31 09:14:16,746 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.3
2013-07-31 09:14:16,747 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2013-07-31 09:14:16,747 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2013-07-31 09:14:16,758 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2013-07-31 09:14:16,762 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2013-07-31 09:14:16,775 DEBUG [ServiioHttpService] Incoming request from /192.168.2.3:63822: GET /serviceDescription/ConnectionManager HTTP/1.1, headers = [Host: 192.168.2.2:8895,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 Intel MicroStack/1.0.1423]]
2013-07-31 09:14:16,775 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.3
2013-07-31 09:14:16,776 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2013-07-31 09:14:16,776 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2013-07-31 09:14:17,265 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.2.10:8080/description.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2013-07-31 09:14:17,265 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 5f9ec1b3-ff59-19bb-8530-0005cd223ace from address /192.168.2.10:3911
2013-07-31 09:14:18,085 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.2.3:55211s
2013-07-31 09:14:18,086 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.2.3:55211s
2013-07-31 09:14:18,086 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.2.3:55211
2013-07-31 09:14:18,586 INFO  [PluginCompilerThread] Added Feed plugin YouTube (Youtube.groovy), version: 1
2013-07-31 09:14:20,601 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2013-07-31 09:14:23,687 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth4 (Realtek PCIe GBE Family Controller) and address 192.168.2.2, timeout = 0
2013-07-31 09:14:23,687 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device c5a8f887-8949-3e9f-a9ff-b88282874507
2013-07-31 09:14:25,490 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:08 (advertisement duration is 1800 sec.)
JohninLA
Post Wed Jul 31, 2013 6:33 pm
Re: Problems connecting with Serviio and Windows 8
One other thing I notice is that in Windows Explorer, under Network media devices, Serviio will show in a list of my media players and other media servers, like PlayOn and Windows Media Player. After a short time, Serviio just disappears, even though it still shows in the taskbar as running. Not sure if this is all related, but Serviio just doesn't act as stable on my system as other servers. Thanks.
Users browsing this forum: No registered users and 49 guests
