samsung ue40c6000
massimo
Post Tue Jan 18, 2011 3:03 am
samsung ue40c6000
Hi everybody,
My experience with samsung s share manager was a comlete disaster. After a lot of searching i finally came to the conclusion that serviio definitely is the best server ap on the web.
But there is still room for improvement for i have a couple of issues:
- when i run the console under rederer profile samsung c series/player then there are some HD mkv files where the sound is missing
- then i tried to run the console under profile samsung a and b series and the the same file HAD sound but functionalities as fastforward and rewind dissapeared
also under a and b series the transcoding works fine, but under c series nothing happens.
Can this be fixed?
Post Tue Jan 18, 2011 9:55 am
Re: samsung ue40c6000
massimo wrote:also under a and b series the transcoding works fine, but under c series nothing happens.
That's because the C series TV can play almost everything natively.
massimo
Post Tue Jan 18, 2011 12:14 pm
yes indeed,
but my question is about the fact that some files will play under profile a-series or b-series with sound (where transcoding will activate because of the file format not beeing supported by dlna standards). That's why i find this software awesome.
And when i choose the profile suited for my TV set c series/player the transcoding doesn't kick in when it's needed. If I play the file through USB there's no problem at all as you say the TV set can play it natively. But whenever i try to play it through dlna there's no sound.
I understand that it is an issue of file format and that dlna is very picky, But serviio having transcoding would ease a lot of RE-encoding of video files in my case.
Thanks for your support
massimo
Post Tue Jan 18, 2011 12:22 pm
Also I would like to add that samsung ue40c6000 can read almost every fileformat but through dlna it is not the case.
Return to User experiences
