Samsung UE46ES7000 can't play TRUEHD audio
sparrow
Post Fri Jul 26, 2013 6:49 pm
Hi all
I've got an .mkv movie with TRUEHD audio. Unfortunately when I try to play it, I get a TRUEHD audio cannot be played error.
I'm running Serviio Pro 1.2.1, and the TV is a Samsung UE46ES7000.
I've found a couple of hits from a few years ago, but they all seem to suggest that Serviio supports this now, so I'm not sure why I'm seeing this.
Any help appreciated.
Post Mon Jul 29, 2013 10:26 pm
Re: Samsung UE46ES7000 can't play TRUEHD audio
post detailed log of playing the file
sparrow
Post Thu Aug 01, 2013 7:15 pm
Apologies for the delay. Log file is 35M.
I've stripped most of it out to upload, let me know if you need any more.
(107.91 KiB) Downloaded 622 times
Post Thu Aug 01, 2013 8:27 pm
I assume it was The Dark Knight? The log is cut before you actually played the file.
sparrow
Post Thu Aug 01, 2013 9:29 pm
No, The Matrix.
I forgot to bounce the service, so I've now got a 500MB file. I'll trash it and try again.
sparrow
Post Thu Aug 01, 2013 9:42 pm
Too big to upload here, uploaded to box.
https://app.box.com/s/lkbf1qbwmm1enrb40w07
Post Fri Aug 02, 2013 4:04 pm
Ok, it's not transcoded. Can you post ffmpeg -i of the file?
sparrow
Post Fri Aug 02, 2013 5:48 pm
C:\Program Files\Serviio\lib>ffmpeg -i "F:\Movies\The Matrix Trilogy\The Matrix(1999).mkv"
ffmpeg version 1.1.1 Copyright (c) 2000-2013 the FFmpeg developers built on Feb 5 2013 21:59:54 with gcc 4.7.2 (GCC)
p --enable-fontconfig --enable-libfreetype --enable-zlib --extra-libs='-lrtmp -l
polarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-
runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-
mingw32- --pkg-config=pkg-config
libavutil 52. 13.100 / 52. 13.100
libavcodec 54. 86.100 / 54. 86.100
libavformat 54. 59.106 / 54. 59.106
libavdevice 54. 3.102 / 54. 3.102
libavfilter 3. 32.100 / 3. 32.100
libswscale 2. 1.103 / 2. 1.103
Input #0, matroska,webm, from 'F:\Movies\The Matrix Trilogy\The Matrix (1999).mkv':
creation_time : 2010-12-08 10:58:56
Duration: 02:16:17.96, start: 0.000000, bitrate: 18749 kb/s
Chapter #0.0: start 0.000000, end 205.789000
title : Trinity in a Jam
Chapter #0.1: start 205.789000, end 395.645000
title : Impossible Pursuit
Chapter #0.2: start 395.645000, end 582.665000
title : Follow Instructions
Chapter #0.3: start 582.665000, end 718.301000
title : The Question
Chapter #0.4: start 718.301000, end 1007.423000
title : "They're Coming for You"
Chapter #0.5: start 1007.423000, end 1293.542000
title : Unable to Speak
Chapter #0.6: start 1293.542000, end 1508.590000
title : Getting the Bug Out
Chapter #0.7: start 1508.590000, end 1731.146000
title : Morpheus' Proposal
Chapter #0.8: start 1731.146000, end 1945.193000
title : Down the Rabbit Hole
Chapter #0.9: start 1945.193000, end 2121.870000
title : Slimy Rebirth
Chapter #0.10: start 2121.870000, end 2320.902000
title : Nebuchadnezzar's Crew
Chapter #0.11: start 2320.902000, end 2662.577000
title : The Real World
Chapter #0.12: start 2662.577000, end 2793.541000
title : The Search Is Over
Chapter #0.13: start 2793.541000, end 2937.852000
title : Training Begins
Chapter #0.14: start 2937.852000, end 3211.291000
title : Morpheus/Neo Matchup
Chapter #0.15: start 3211.291000, end 3392.139000
title : First Jump
Chapter #0.16: start 3392.139000, end 3541.288000
title : The Gatekeepers
Chapter #0.17: start 3541.288000, end 3668.582000
title : Running Silent and Deep
Chapter #0.18: start 3668.582000, end 3916.496000
title : Dealing for Bliss
Chapter #0.19: start 3916.496000, end 4066.813000
title : Off to See the Oracle
Chapter #0.20: start 4066.813000, end 4353.432000
title : There Is No Spoon
Chapter #0.21: start 4353.432000, end 4669.582000
title : Choices...and a Cookie
Chapter #0.22: start 4669.582000, end 4863.108000
title : Glitch in the Matrix
Chapter #0.23: start 4863.108000, end 5105.350000
title : One Left Behind
Chapter #0.24: start 5105.350000, end 5385.130000
title : Heroes Unplugged
Chapter #0.25: start 5385.130000, end 5487.565000
title : Cypher's Burnout
Chapter #0.26: start 5487.565000, end 5845.256000
title : Matters of Belief
Chapter #0.27: start 5845.256000, end 6064.976000
title : Virus to Be Cured
Chapter #0.28: start 6064.976000, end 6260.337000
title : Lobby Shooting Spree
Chapter #0.29: start 6260.337000, end 6420.497000
title : Dodge This
Chapter #0.30: start 6420.497000, end 6618.529000
title : Gotcha
Chapter #0.31: start 6618.529000, end 6776.687000
title : Rooftop Rescue
Chapter #0.32: start 6776.687000, end 6996.907000
title : Subway Showdown
Chapter #0.33: start 6996.907000, end 7129.372000
title : "My Name Is Neo"
Chapter #0.34: start 7129.372000, end 7347.423000
title : Sentinels Attack
Chapter #0.35: start 7347.423000, end 7541.784000
title : "He Is the One"
Chapter #0.36: start 7541.784000, end 7726.802000
title : Final Connections
Chapter #0.37: start 7726.802000, end 8177.962000
title : End Credits ("Wake Up Rock Is Dead")
Stream #0:0(eng): Video: vc1 (Advanced) (WVC1 / 0x31435657), yuv420p, 1920x1
080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
title : The Matrix (1999) - 1080p @ 16439 kbps
Stream #0:1(eng): Audio: truehd, 48000 Hz, 5.1(side), s32 (default)
title : TrueHD / 1646 kbps / 48 KHz / 16-Bit / 5.1
Stream #0:2(eng): Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s
title : AC3 / 192 kbps / 48 KHz / 16-Bit / 2.0
Stream #0:3(eng): Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s
Stream #0:4(eng): Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s
Stream #0:5(eng): Subtitle: dvd_subtitle
Stream #0:6(pol): Subtitle: dvd_subtitle
Stream #0:7(tha): Subtitle: dvd_subtitle
Stream #0:8(eng): Subtitle: dvd_subtitle
title : Commentary Subtitles
Post Fri Aug 02, 2013 10:04 pm
ah ok. It's a VC1 video, which there is no transcoding rule for. Currently FFmpeg cannot remux VC1 to MPEGTS, so you'll have to transcode the video as well as audio. It will need a good CPU to do this real time.
Add this
<Matches container="matroska" vCodec="vc1" aCodec="truehd" />
to the C/D/E profile under
and restart the PC / Serviio service.
sparrow
Post Fri Aug 02, 2013 10:33 pm
That works, thanks. Not that I understand any of it!
CPU seems to be coping, but I may stay away from TRUE HD until I upgrade. i3 3220 seems to be running at about 40% with nothing else running, standard cooling may not be up to the task.
Thanks for the help, and this software is well worth the price.
Users browsing this forum: No registered users and 49 guests
