Serviio isnt showing on tv but TV is showing on serviio
Studentmac
Post Sun Aug 04, 2013 9:04 am
Serviio isnt showing up on my Samsung D8000 smart tv, been using serviio for quite some time but today its stopped showing.
Usually restarting pc is enough to get it to connect again but its not this time.
under status on serviio i can see my tv showing in green so not sure why its not showing on tv.
removed serviio, installed newest version of serviio and it worked once, shut down pc and back on and its not showing again
went into firewall to allow serviio in case that helped and its not
Anyone have some ideas?
thanks
Post Sun Aug 04, 2013 1:15 pm
Re: Serviio isnt showing on tv but TV is showing on serviio
Hi Studentmac - are you using a mac? :?:
If so, check out viewtopic.php?f=5&t=11027#p71971.
If not, what os are you using. Has anything changed lately?
Studentmac
Post Sun Aug 04, 2013 1:45 pm
I am using wndows 7 64x
Only change is I changed the library on serviio from G drive to D, which ive changed in serviio
Post Mon Aug 05, 2013 9:17 am
I'll leave this with zip in the othertopic: viewtopic.php?f=5&t=11731
Best not to double post an issue.
