ue40c6000
massimo
Post Tue Jan 18, 2011 3:10 pm
ue40c6000
i 'm having trouble to view only some mkv files through serviio. sound is missing. tv set however is capable of reading natively through usb without problems.
here s what ffmpeg gives: (is it possible to make serviio transcode for samsung tv c series? because it doesn't but needs to)
F:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "E:\MEDIA PLAYER\FILMS VF HD\GL
ADIATOR 1080.mkv"
FFmpeg version SVN-r23012, Copyright (c) 2000-2010 the FFmpeg developers
built on May 3 2010 19:05:24 with gcc 3.4.5 (mingw-vista special r3)
erver --enable-memalign-hack --enable-libmp3lame --enable-w32threads --extra-ldf
lags=-L/static/lib --extra-cflags=-I/static/include
libavutil 50.15. 0 / 50.15. 0
libavcodec 52.66. 0 / 52.66. 0
libavformat 52.62. 0 / 52.62. 0
libavdevice 52. 2. 0 / 52. 2. 0
libswscale 0.10. 0 / 0.10. 0
[matroska @ 012fbb70]MAX_READ_SIZE:5000000 reached
[matroska @ 012fbb70]Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (48000/
1001) -> 23.98 (48000/2002)
Input #0, matroska, from 'E:\MEDIA PLAYER\FILMS VF HD\GLADIATOR 1080.mkv':
Duration: 02:50:56.91, start: 0.000000, bitrate: N/A
Stream #0.0(fre): Video: h264, yuv420p, 1920x816, PAR 1:1 DAR 40:17, 23.98 t
br, 1k tbn, 47.95 tbc
Stream #0.1(fre): Audio: dca, 48000 Hz, 6 channels, s16
Stream #0.2(eng): Audio: dca, 48000 Hz, 6 channels, s16
Stream #0.3(fre): Subtitle: 0x0000
title : Forced
Stream #0.4(fre): Subtitle: 0x0000
Stream #0.5(eng): Subtitle: 0x0000
Post Tue Jan 18, 2011 6:14 pm
Re: ue40c6000
it's a DTS audio, which the C series TVs should be able to decode. Can someone confirm whether they can play DTS audio on the C series Sammy?
Post Tue Jan 18, 2011 6:54 pm
Re: ue40c6000
i cant play any MKv file at all atm with RC1
Users browsing this forum: Google [Bot] and 7 guests
