DLNA response values
Zek
Post Wed Jan 19, 2011 4:29 pm
Zip,
I was examining the responses of Serviio using Intel's tools. Could you please tell me what the following fields are in this response string?
video/mpeg:DLNA.ORG_PN=AVC_TS_HD_50_AC3_ISO;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000
DLNA.ORG_PN = pretty obvious, the type of container?
DLNA.ORG_OP = ? What does 1 mean in this case? What are other values or enums?
DLNA.ORG_CI = ? same as above
DLNA.ORG_FLAGS = ? What are the various flags?
Cheers!
Zek
Sony Bravia KDL-55NX810 | Serviio 0.5 (rev. 975aa458693c) | Synology DS-1010+
Post Wed Jan 19, 2011 4:34 pm
Re: DLNA response values
Media file format profile, usually combination of container/video codec/audio codec/sometimes region
first bit means Time based seek supported, second byte range seek supported (not sure about the order now), so 01 = only byte seek, 10 = time based, 11 = both, 00 = none
0 = native, 1 = transcoded
There are additional flags (bits) that describe functionality and supported operations of the file/server. More in the DLNA spec (which I don't think I can copy here ;-) )
Zek
Post Wed Jan 19, 2011 8:23 pm
Thanks Zip! I dug a little deeper and found some source code that explained the flags:
http://libdlna.sourcearchive.com/docume ... ource.html
http://folks.o-hand.com/ross/gupnp-docs ... lInfo.html
Return to General discussion
Users browsing this forum: Baidu [Spider] and 2 guests
