[CDS API] XmlHttpRequest from a not allowed IP
kissskoool
Post Tue Aug 06, 2013 2:54 pm
After my two first posts, i still have some questions, but i'm sure it will be useful for others too ;)
I'm trying to make a JS XmlHttpRequest like this :
function cds_info(token, object_id){
   var xhr = new XMLHttpRequest();
   xhr.open("GET", "http://my_server_ip:23424/cds/browse/flv_player/"+object_id+"/BrowseMetadata/all/0/1?authToken="+token);
   xhr.setRequestHeader("Accept", "application/xml | application/json");
   xhr.onreadystatechange = function () {
     if (this.readyState == 4) {
      alert('Object_id: '+object_id+'\nStatus: '+this.status+'\nHeaders: '+JSON.stringify(this.getAllResponseHeaders())+'\nBody: '+this.responseText);
   xhr.send(null);
And i get this error message :
Origin http://my_server_ip is not allowed by Access-Control-Allow-Origin
How can i allow this request ?
Many thanks for your help !
Post Tue Aug 06, 2013 5:32 pm
Re: [CDS API] XmlHttpRequest from a not allowed IP
The accept-type is either application/xml or application/json. The API shows that in not so clean way, sorry about that.
It'll define if you get back XML or JSON, the choice is yours.
kissskoool
Post Tue Aug 06, 2013 6:04 pm
Thanks for your answer.
It was not exactly what i asked but it doesn't matter i found a solution for the Access-Control-Allow-Origin problem due to cross domain ajax limits.
i just did a reverse proxy to redirect http://my_server:23424/cds/... to http://my_server/cds/... so i remain on the same domain.
ailete
Post Sun Aug 11, 2013 2:21 pm
Hi kissskoool !
I encountered the same issue, but I did'nt manage to resolve it yet.
You say you found a solution by setting a reverse proxy... Can you explain how you did it please ? It would be really helpful for me.
Thanks a lot :D
kissskoool
Post Mon Aug 12, 2013 12:25 pm
Access-Control-Allow-Origin problems is due to a cross ajax request from a domain to another one.
The origin url and the destination url must have the same domain and port.
So http://my_server:23424/cds/ and http://my_server/cds/ are considered two different domains.
My solution is to redirect on my server http://my_server:23424/cds/ to http://my_server/cds/
To do that you have to activate mods proxy and proxy_http
then in your site apache virtualhost you'll have to add those lines :
<Location /cds>
        ProxyPass http://127.0.0.1:23424/cds
        ProxyPassReverse http://127.0.0.1:23424/cds
    </Location>
