Panasonic 2013 models (ST60)
TheXman
Post Thu Aug 08, 2013 8:47 am
Re: Panasonic 2013 models (ST60)
DenyAll wrote:Thanks - I wonder if I can impose on you to test with the mime type set to "video/divx". This is what I'd prefer to leave it as (ie. same as other Pana profiles), unless we get some confirmation that it makes a difference.
So, at the moment, I have
<MediaFormatProfile mime-type="video/xvid">AVI</MediaFormatProfile>
I will change this to
..and then test again. I expect to see some difference in results.
You can also include the audio types now for the 1.3 release (they were commented out).
I don't have Serviio 1.3. Can I still uncomment this part?
<!-- Next three lines are for Serviio 1.3 and later: <Matches container="wavpack" /> <Matches container="mpc" /> <Matches container="ape" / -->
Has anyone else reported an issue with the "Enable Transcoding" part. Unchecking the box does not disable ffmpeg from doing its work even after restarting Serviio from the control panel applet.
Post Thu Aug 08, 2013 9:05 am
No you can't uncomment that part until after you instal 1.3. It's released now if you want it.
Haven't had any reports of the transcoding switch not working. I'll test it tonight, but are you sure you're pressing Save :?
TheXman
Post Thu Aug 08, 2013 9:14 am
DenyAll wrote:No you can't uncomment that part until after you instal 1.3. It's released now if you want it.
I will upgrade to 1.3 and see if the transcoding issue is sorted out for me. Other than that, I don't see anything new for me. The "transcoding to H264" is something that may not be needed for me as the TV supports this natively as far as I remember.
Post Thu Aug 08, 2013 1:40 pm
Tested the Transcoding switch (checkbox) and it works as expected for me. Not sure what is happening with yours... try 1.3.
TheXman
Post Mon Aug 12, 2013 5:46 pm
I have upgraded to 1.3
Now, I copied over the section that was created for Panasonic 2013 TV's into the fresh profile XML. It causes an exception for serviio service.
Can you send me a new profile file for 1.3 which can support Panasonic 2013?
Edit: Started from scratch and then Serviio worked. But AVI's don't work anymore.
Edit2: Had to change to
for AVI's to work. Also uncommented the audio related lines.
Post Tue Aug 13, 2013 1:02 am
Thanks. As mentioned above I have started a new topic inviting all Panasonic 2013 users to input into the new profile. See: viewtopic.php?f=13&t=12367
Previous
Return to Panasonic
