support serie F (2013)
Post Mon Jun 17, 2013 9:19 am
Re: support serie F (2013)
No... but we could build a new profile there if you find that (for example) we don't have to transcode certain files any more. Also if it all works, I'll be able to rename the profile to C/D/E/F ;-)
Brammers
Post Tue Jun 18, 2013 12:55 am
I've only got MP4 and MKV files to test with, but both of those work.
I'm happy to try out anything you point me towards though.
J
Six
Post Fri Jun 21, 2013 5:39 am
Hi!
I have sound problems with Samsung C/D/E profile on my F8000 TV.
Everything was OK on ES8000, but on new tv, sound chopping or jamming time to time (I can't explain better:). Not all time.
And both - DTS or AC3 sound in MKV container.
It means something is different between E-serie and F-serie Samsung TV.
If I choose Generic profile or something else (I tried Philips etc), sound is OK, but then I can't use external subtitles. Only internal I can choose.
Is there profile I can try which recognizes external subtitles like Samsung profile?
P.S. And mini-pictures are gone after last firmware update (FW 1103) :(
Post Fri Jun 21, 2013 12:34 pm
Six wrote:If I choose Generic profile or something else (I tried Philips etc), sound is OK, but then I can't use external subtitles.
Can you post ffmpeg -i for the file?
What if you disable transcoding and still use the Samsung profile?
Six
Post Sat Jun 22, 2013 3:00 am
Transcoding is disabled already.
(On my Synology NAS DS213+):
ffmpeg -i JOE SATRIANI - Satchurated - [2012].mkv
ffmpeg version UNKNOWN, Copyright (c) 2000-2011 the FFmpeg developers
built on Feb 25 2013 23:22:09 with gcc 4.3.2
configuration: --arch=powerpc --target-os=linux --cross-prefix=/usr/local/powerpc-none-linux-gnuspe/bin/powerpc-none-linux-gnuspe- --enable-cross-compile --enable-optimizations --disable-yasm --disable-altivec --enable-pic --enable-shared --disable-static --disable-swscale-alpha --disable-ffserver --disable-ffplay --enable-libmp3lame --enable-libfaac --enable-nonfree --enable-version3 --enable-libopencore-amrnb --enable-libopencore-amrwb --disable-decoder=amrnb --cc=/usr/local/powerpc-none-linux-gnuspe/bin/powerpc-none-linux-gnuspe-ccache-gcc
libavutil 50. 40. 1 / 50. 40. 1
libavcodec 52.120. 0 / 52.120. 0
libavformat 52.108. 0 / 52.108. 0
libavdevice 52. 4. 0 / 52. 4. 0
libavfilter 1. 77. 0 / 1. 77. 0
libswscale 0. 14. 0 / 0. 14. 0
[matroska,webm @ 0x10031fc0] Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (5000000/104271) -> 23.98 (24000/1001)
Input #0, matroska,webm, from 'JOE SATRIANI - Satchurated - [2012].mkv':
title : =WIDDER=
Duration: 02:19:43.93, start: 0.000000, bitrate: 12906 kb/s
Chapter #0.0: start 0.000000, end 299.590000
title : 01 Ice 9
Chapter #0.1: start 299.590000, end 595.261000
title : 02 Hordes of Locusts
title : 21 Big Bad Moon
Chapter #0.21: start 7820.270000, end 8230.430000
title : 22 Crowd Chant
Chapter #0.22: start 8230.430000, end 8230.430000
title : 23 Summer Song
Stream #0.0(eng): Video: h264 (High), yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
title : Joe Satriani 2012
Stream #0.1(eng): Audio: dca (DTS), 48000 Hz, 5.1, s16, 1536 kb/s (default)
title : DTS
Stream #0.2(eng): Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
title : AC3
One more:
Input #0, matroska,webm, from 'Vuonna 85 - [2013].mkv':
Duration: 01:39:52.92, start: 0.000000, bitrate: 12534 kb/s
Stream #0.0(eng): Video: h264 (High), yuv420p, 1920x816, PAR 1:1 DAR 40:17, 24 fps, 24 tbr, 1k tbn, 48 tbc
Stream #0.1(fin): Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s (default)
Stream #0.2(eng): Subtitle: [0][0][0][0] / 0x0000 (default)
Post Mon Jun 24, 2013 1:04 pm
IN that case there is no difference between Samsung and Generic - the files are served natively.
aacosta
Post Mon Jul 01, 2013 9:46 am
I recently purchased an F6675 (previously I had a C series which worked perfectly with Serviio) running the lastest available firmware, to which I stream with Serviio on OSX with the C-D-E series profile. Playing and seeking seems to work nicely, however I have noticed certain problems:
* I cannot see any thumbnails for my movies.
* .srt subtitles and mkv-embedded subtitles seem to conflict. Mkv-embedded subtitles work (yay! they didn't on the C-series) but if an .mkv has embedded subtitles and also an accompanying .srt file, the .srt seems to be ignored (the only available subtitles during playback are the mkv-embedded ones).
* Resume video playback does not work (it's not available).
Zip, since I am aware you don't have access to an F-series TV, is there a way in which I can help you debug these problems with my own?
beta
Post Mon Jul 01, 2013 2:55 pm
On my D-Series everything works fine.
Did'nt work on my new F5370:
Photos:
- Get only an Error while selecting any Photo-Folder
Videos:
- No Thumbs
- No Resume
- Forwarding only with Control-Cross on IR (no real FF, RW), Testet with MKV and TS Files
- No Time Search/Seek
Six
Post Tue Jul 02, 2013 2:32 pm
Samsung have changed something in all new F-serie firmwares.
Today I updated my bluray player BD-F7500 and small pictures are gone.
Same story on the TV - after latest firmware update, small pics are gone.
Post Wed Jul 03, 2013 8:07 pm
Can you try with the Samsung AllShare server? Does that have all the original features?
Six
Post Thu Jul 04, 2013 6:46 am
Samsung have new Samsung Link.
No AllShare anymore...
dokie80
Post Thu Jul 04, 2013 6:48 am
shpak_evgen wrote:i have F-series TV, and i can see the folders only, but can't see (browse) any content of that folders. for example my another TV is E-series TV, and there is no problems at all.
...Hope you can (and wish) fix it.
Hi there. I have F-series, and serviio working just fine with serviio for windows and serviio on NAS (WD Live). I had this exact problem also when I setup both on windows and NAS. Actually you can view the files/videos if you browse "All Content" category (or other category I think), but doesnt show up when you browse Folder category.
-- For Windows --
The problem occurs for me because I share network folders with mapped drive (i.e. Z:/ for //hostname/Public). So, for the TV to be able to see files on folder view, you should choose "add path" in library, not "add local". use "//hostname/folder" path. This solution works for me for Serviio for Windows.
-- For Serviio on NAS --
I'm not sure what caused the problem, but I did reinstall serviio and install serviowebui v1.4beta (was using 1.2a when I had the problem), and re-add library via webUI.
Now both serviio server working without problem.
edit: and make sure you choose "Samsung C/D/E Series" profile if you have problems with sub (srt files). For me, the sub doesnt show up with Generic DLNA profile.
Hope this help.
Regards,
Six
Post Thu Jul 04, 2013 7:04 am
dokie80, do you have the latest firmware on your F-serie TV?
dokie80
Post Thu Jul 04, 2013 8:21 am
Six wrote:dokie80, do you have the latest firmware on your F-serie TV?
yes, I did online update.
ps. please note, I m providing solution for shpak_evgen, to show folder content. I do have several problem like browsing on TV seems slower than twonky or serviio for windows. posted a thread here: http://forum.serviio.org/viewtopic.php?f=14&t=2961&p=72627#p72627
Misanthrop
Post Mon Jul 29, 2013 9:24 am
first i have to say serviio is a great tool and makes life much easier. samsung allshare was way too bad. never used it again once i discovered serviio.
last week i got a new TV. a samsung UE46F6500 replaced my LE40C650. serviio worked pretty well with my old TV, but there seem to be some issues with the new one. i am using 1.2.1 and didn't change anything settingswise. just connected the new TV and still using C/D/E profile. i am aware some points or most of them might be porblems which need to be adressed by samsung. just listing them in case they ain't.
- no covers/artwork is shown with movies/tv-series (worked wirh c650). i can browse all folders and play all files, but no descriptive metadata is shown. please, please fix this :ugeek:
- no "real" fast forward. if i press the forward key only 10 second jumps are possible. with the old tv - if i kept the button pressed - the video jumped forward something like 5 minutes every few seconds. this worked with every file. didn't have to remux or something. never had a mkv which i couldn't fast forward. you can use the search function though from samsung to jump forward in the timeline.
- lip sync issues, but i guess that is a problem to be adressed by samsung (sound is about 150ms off with most video files)
- if i sort my movies in the "last viewed" folder on my samsung tv by date, the mediaplayer crashes and can't reconnect to serviio. i have to reset the tv to factorysettings in order to use serviio again. kind of stupid that the "last viewd" & "last added"section is in alphabetical order and can't be changed to sort by date. but i guess this is also a samsung problem.
- subtitles are automatically played by the tv if there are any in the mkv. you have to turn them off with every video and every time, which is super stupid. thxs samsung.
Post Mon Jul 29, 2013 10:14 pm
Misanthrop wrote:- no covers/artwork is shown with movies/tv-series (worked wirh c650). i can browse all folders and play all files, but no descriptive metadata is shown. please, please fix this :ugeek:
Do they work from any other server, especially AllShare?
For the other things, do you have the same problems with Generic profile?
Awesoft
Post Tue Jul 30, 2013 11:25 am
No thumbnails on my Samsung F6400.
ferrari987
Post Mon Aug 05, 2013 10:17 pm
I have a Samsung UE40-F6470 newest FW 1107.4. Video playback using Serviio 1.2.1 works, however the (for me very very important) navigation using folders causes an error (media play). Thus, i would like to test the newest beta version to see if that works better :)
shpak_evgen
Post Thu Aug 08, 2013 7:05 pm
Finaly! the new Servio 1.3 is relised! :-) great job, thank you!
but.......
still not working with my Samsung TV UE55F6400 !!!! :-( I can not understend, what the reason for that?!
my another samsung tv UE32D6500 work's good with serviio! and samsung AllShare also work's perfectly with both of them!
:-( very good servise, but that things above..... :-(
Post Thu Aug 08, 2013 7:51 pm
shpak_evgen wrote:Finaly! the new Servio 1.3 is relised! :-) great job, thank you!
but.......
What doesn't work for you? You didn't provide any details.
