Serviio 1.3: Samsung E-series subtitles stopped working
Manala
Post Thu Aug 08, 2013 10:58 pm
Have been using 1.2.1 for a long time now. Everything worked fine. Then I updated to 1.3 and many subtitles stopped working. My TV is Samsung ES7005.
I wrestled several hours with the issue but no avail. Oddly some lines of the particular subtitle file were rendered by the TV, but at least 90% of them were not. So when I watched a TV-series with a (.sub) subtitle, it showed one textline here and there, but maybe 9 lines out of 10 were not rendered at all. TV profile was set as it should have been and I tried "update install" and fresh install but this bug still persisted. Going back to 1.2.1 was the only option to fix this issue.
Post Fri Aug 09, 2013 5:09 pm
Re: Serviio 1.3: Samsung E-series subtitles stopped working
can you post detailed log of playing the file (with 1.3)?
ivan787
Post Sat Aug 10, 2013 5:46 pm
Im having same issues with the srt subtitles on my western digital tv live plus, none of them are readable only embebed ones
Antinontoxic
Post Thu Aug 15, 2013 5:53 pm
Same issue with F7005 Samsung. Everything was fine with the subtitles until the update, now I can not adjust any subtitle options when playing files. Also as mentioned, about 90-95% of the subtitles doesn't show, but sometimes there are random subtitles popping up.
Edit: Went back to old version and everything is fine again.
Post Thu Aug 15, 2013 6:30 pm
Antinontoxic wrote:Same issue with F7005 Samsung. Everything was fine with the subtitles until the update, now I can not adjust any subtitle options when playing files. Also as mentioned, about 90-95% of the subtitles doesn't show, but sometimes there are random subtitles popping up.
What subtitles settings do you have in the console? Turn off burned-in subtitles and embedded subtitles and try again
kerio
Post Sun Aug 25, 2013 4:39 am
Same here .sub and .srt stopped working. Tv is Samsung ue55es8005.
Log show:
2013-08-25 08:01:11,390 INFO [LibraryUpdatesCheckerThread] Updated '2013-02-26 18.18.30' (D:\shares\Videos\) in Library
2013-08-25 08:03:14,750 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2013-08-25 08:03:14,843 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2013-08-25 08:03:14,968 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-08-25 08:03:14,984 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2013-08-25 08:05:08,500 WARN [PortMapper] Could not add port mapping to the router: Connection refused: connect
2013-08-25 08:05:13,125 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2013-08-25 08:05:13,234 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2013-08-25 08:05:13,343 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-08-25 08:05:13,656 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
Same 1.3 and 1.3.1 but 1.2.1 works great.
bobsmo
Post Sun Aug 25, 2013 7:10 am
Odd.....srt files still work OK on my es8000......no subtitle processing selected as usual.....
Post Mon Aug 26, 2013 9:04 am
Make sure you use the C/D/E Samsung profile.
Manala
Post Fri Nov 22, 2013 4:06 pm
Workaround for everyone who drifts to here:
1. Install Serviio 1.2.1
2. Take a backup of ffmpeg.exe from [serviio 1.2.1 install directory]\lib\
3. Install serviio 1.3.1
4. Copy over the backup of ffmpeg.exe to [serviio 1.3.1 install directory]\lib\
Works for me.
liberty
Post Sun Dec 01, 2013 9:00 pm
I have a Samsung F TV and I am using Serviio for PC harddisk and Seagate NAS.
So far I have not seen any subtitles.
I use 1.3.1 where the size of ffmpeg is 14219 KB.
I searched on the net and found the latest version ffmpeg to be 9902 KB.
Is the latter the correct version to use?
What size have the 1.2.1 version talked about here?
On Samsung TV I have tried the Serviio, NAS and PC alternatives.
I have only Serviio running on the computer - not Samsung link which has been installed and set up.
No subtitles so far.
Please advise me. Thanks
liberty
Post Mon Dec 02, 2013 9:23 pm
Make sure you have selected the right profile for your TV and name the subtitles properly (same name as the video)
liberty
Post Tue Dec 03, 2013 8:49 pm
Thanks for your reply.
1. What do you mean by setting the right profile for Samsung? Where?
2. Yes the sudtitle files in this case are identical to the mp4-file except for the ending _eng or _swe. Is this correct?
3. Which of the files ffmpeg should I use or does it not matter?
I need help to solve this, thanks.
Post Thu Dec 05, 2013 9:03 pm
profiles - Getting started guide: http://www.serviio.org/index.php?option ... ticle&id=5
subtitles - http://www.serviio.org/index.php?option ... icle&id=33
You will have to use the language code in the console, unless you have a default file (without the _eng)
liberty
Post Fri Dec 20, 2013 8:57 am
Thank you very much.
It is working now after:
1. Moving all the subtitle files in a subfolder just keeping the used one in the video folder.
2. Not using any _eng endings. (Not very good because I use several languages).
3. I have some language profile settings - but exactly which setting do you mean?
4. With this It is also working for my NAS storage.
Manala
Post Wed Apr 09, 2014 3:42 am
Manala wrote:Workaround for everyone who drifts to here:
Works for me.
However this doesn't work with 1.4x anymore. With 1.4 I lost _all_ .sub rendering. Only .srt:s work anymore. Wasn't 1.4 supposed to have a better support for different encodings etc? I cant see _any_ line of _any_ .sub, neither with or without scandic characters. So... still stuck at 1.3.1 with ffmpeg from 1.2.
Post Sun Apr 13, 2014 5:16 pm
I think FFmpeg might have some issues when the encoding you provide in the console is different to the one of the file.
You could try the latest FFmpeg.
