1.3 Working Great For Me - Upgraded from 1.1 - But One Thing
ClockerXP
Post Fri Aug 09, 2013 2:34 am
Just wanted to provide some feedback.... 1.3 is working great for me on my WHS 2011. Autostart is working fine for me.
I could never get 1.2 or 1.2.1 to work for me so I had to stick to 1.1 for a while. But 1.3 is giving me no problems. I just installed 1.3 over top of my 1.1 install & am watching Blade Runner right now streaming to my Panasonic ST50 plasma.
One thing though.. I am seeing that the custom profile I created for my Arris Moxi media player boxes is now gone. So I guess I will have to recreate it?
Thank you for Serviio!
Sent from my cm_tenderloin using Tapatalk 2
WHS2011, Serviio 1.3.1 Free, 50" Panasonic TC-P50ST50, Arris Moxi Media Players (WOW Ultra TV), Sony BDP-S570 Blu-Ray Player - All Working with Serviio
pizzaguy541
Post Fri Aug 09, 2013 3:19 am
Re: 1.3 Working Great For Me - Upgraded from 1.1 - But One T
ClockerXP wrote:One thing though.. I am seeing that the custom profile I created for my Arris Moxi media player boxes is now gone. So I guess I will have to recreate it?
If you look in the config sub folder (\Serviio\config) you should find a backup of your previous profiles saved with a .bak extension.
Open that file in a text editor and copy over your changes to the new profile file.
Xmantium
Post Fri Aug 09, 2013 4:43 am
Yes it will be deleted unless zip added this device on the official 1.3 profiles.xml
The .bak extension will be for 1.2.1, just copy your device code from your custom profile to the new one as 1.3 profiles.xml been updated with new attributes such as HD Thumbnails and new devices
So best to add to the existing new profiles.xml that belongs to v1.3 if the device is not included
ClockerXP
Post Mon Aug 12, 2013 1:52 am
Thanks! Worked great!
Return to User experiences
