[SOLVED] Hebrew Subtitles problem with PS3
please help me what to do
Illico wrote:Read http://www.serviio.org/index.php?option ... icle&id=33
Check that Subtitle character encoding field is the same than your subtitle file (with notepad++ editor)
i123b456 wrote:ok , and how do i change the notepadd ++ file to windows -1255 ? what is that mean?
Illico wrote:i123b456 wrote:ok , and how do i change the notepadd ++ file to windows -1255 ? what is that mean?
- Open your file with notepad++ (make a backup before)
- Select Encoding menu : post here the value of the original file, should be encode in UTF-8
- Select Encoding menu -> Character set --> Hebrew --> Windows-1255
- Then save your file, the character encoding should be modified.
EDIT : For your information about character encoding : http://en.wikipedia.org/wiki/Character_encoding
For Hebrew : http://en.wikipedia.org/wiki/Windows-1255
i123b456 wrote:ITS WORKING !!!!!!!!!!!!! I LOVE YOU MY MAN ! ITS WORKING!! So now i need to do this to all my files? edit it with notepad ++?
Illico wrote:i123b456 wrote:ITS WORKING !!!!!!!!!!!!! I LOVE YOU MY MAN ! ITS WORKING!! So now i need to do this to all my files? edit it with notepad ++?
Just to be sure...
Could you retry with another file but before, disable all box on serviio console subtitle tab and retry ?
i123b456 wrote:disable all box ?
zip wrote:For PS3 you need burned in subs.
Users browsing this forum: No registered users and 51 guests
