Serviio 1.3 update - No longer auto starts
jeffshead
Post Thu Aug 08, 2013 11:47 pm
Just upgraded to 1.3 pro from 1.21 pro and Serviio no longer starts automatically. Now, I have to manually start Serviio after a reboot. It auto started before the update.
I have both 32 and 64 bit Java installed. I already uninstalled all Java and Serviio and re-installed but it made no difference.
The error below is from the Windows Event Viewer:
The Serviio service is marked as an interactive service. However, the system is configured to not allow interactive services. This service may not function properly.
- System
- Provider
[ Name] Service Control Manager
[ Guid] {555908d1-a6d7-4695-8e1e-26931d2012f4}
[ EventSourceName] Service Control Manager
- EventID 7030
[ Qualifiers] 49152
Version 0
Level 2
Task 0
Opcode 0
Keywords 0x8080000000000000
- TimeCreated
[ SystemTime] 2013-08-08T23:19:34.563989800Z
EventRecordID 27178
Correlation
- Execution
[ ProcessID] 768
[ ThreadID] 3568
Channel System
Computer No1
Security
- EventData
param1 Serviio
Post Fri Aug 09, 2013 6:17 am
Re: Serviio 1.3 update - No longer auto starts
Which version of Windows?
Also, let us know the state of your Interactive Services Detection (start service.msc) service - whether running or not and whether set to start Automatically, Manually or is Disabled.
jeffshead
Post Fri Aug 09, 2013 6:54 am
Windows 7 x64.
Interactive Services Detection service is disabled.
Serviio service is set to automatic.
After using ccleaner a couple of times and rebooting a couple of times it started working again. I don't know what causes this but I seem to remember it doing this last time I updated Serviio.
Post Fri Aug 09, 2013 7:06 am
Have three Windows PC's here (one 32 bit, two 64 bit) - on all of them the service is set to Manual (and this is something we would never have tinkered with). I think this may be the issue ... for next time it arises :D
jeffshead
Post Fri Aug 09, 2013 12:33 pm
That's the first thing I checked. It was always set to automatic so something else is causing this to happen.
jeffshead
Post Sat Aug 10, 2013 10:31 pm
Still not working correctly.
The console is no longer starting on boot. However, the Serviio service is running.
Post Sun Aug 11, 2013 8:07 am
But it has changed - originally the service wasn't starting..?
Post a detailed log showing when you are attempting to start the console. If it is only that the console is not starting with Windows, maybe the console is trying to start before the service has started? Do you get any messages? Leave detailed logging on and do a restart.
Users browsing this forum: No registered users and 55 guests
